Espritmodel.com Heli Air
Old Jul 22, 2011, 07:10 AM
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
It will make a difference, you want a gradual reduction to the exit. I think you'll be more limited by cg requirements, so just have the tube as long as will fit into the plane. I think any differences between that and optimum will be quite small.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Jul 22, 2011, 08:38 AM
gapple12's Avatar
Joined May 2009
Ok, I'm putting it on a 70mm HET setup and it will have about an 8 inch long thrust tube. Do these thrust tubes improve top end only or overall performance? Thanks for your help, greatly appreciated.
gapple12 is offline Find More Posts by gapple12
Old Jul 22, 2011, 08:55 AM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
well, that's a good question. a thrust tube can do both for you. it deffinitely increases top end if you use a restricted opening of anythig less than 100% FSA. 85-90% is a good compromise. it also increases performance by focusing the efflux column. take for example a profile F-22 that a buddy of mine has. it's basically a profile jet, with a 64mm fan right in the center of the airframe. the performance was marginal at best. he asked me why and I told him to put a thrust tube on there. he tried one at 100% FSA and the performance was much better. then he gradually decreased the orrifice to about 88% and it flew even better. so the answer to your question is "both".
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jul 22, 2011, 08:57 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
In theory, 100% FSA exit gives maximum static thrust. As you reduce the exit diameter from there, static thrust drops off, but efflux velocity (hence, top end speed) increases. The trick is to find the balance that works for you. The typical exit diameter as a good balance is around 80%-85% FSA.
SMorrisRC's Avatar
UK
Joined Jan 2010
Beat me to it Rich!
Old Jul 22, 2011, 09:02 AM
Joined Jan 2009
don't you have a plane you shoudl be building, or something? hahahahaha.
Old Jul 22, 2011, 09:03 AM
gapple12's Avatar
Joined May 2009
Ok, makes sense to me. I will go with the 85% since I want the most on top end.
Old Jul 22, 2011, 09:16 AM
Joined Jan 2009
good choice.
Old Jul 22, 2011, 09:26 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
I'm on holiday!
Old Jul 22, 2011, 09:35 AM
Joined Jan 2009
pfffffft. excuses. LOL.
Help! Thrust tube repair? Kenta78 Foamy EDFs 2 Jun 05, 2011 06:56 AM
Discussion Equation for figuring the thrust tube on an edf?... FSA?! turbored21 Don's RC 22 Oct 27, 2010 06:55 AM
Question Efflux velocity from thrust & FSA? meteor Electric Ducted Fan Jet Talk 20 Jul 14, 2005 11:37 AM
EDF thrust calculator Doc Watson Electric Ducted Fan Jet Talk 8 Mar 07, 2002 09:43 AM
