Old Jul 19, 2011, 08:57 PM
livnpaintball is offline
Find More Posts by livnpaintball
Joined Aug 2010
Easy fsa and thrust tube calculator?
Can someone post on here a method to find the FSA of any given EDF and how to calculate the Thrust Tube diameter? Help please....
search engine here kinda sucks
livnpaintball is offline Find More Posts by livnpaintball
Old Jul 19, 2011, 09:04 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
What fan do you have?
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jul 20, 2011, 10:00 AM
SMorrisRC is offline
Find More Posts by SMorrisRC
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
FSA is as easy as PI*r^2 of the fan (so, for a 70mm fan, r would be 35) minus PI*r^2 of the motor (70mm fan is usually around 28mm motor, so r would be 14).
The exhaust diameter is then usually around 85% FSA as a rule of thumb for general performance. (so take FSA *0.85, divide by PI, square root it to get r).
Simples!
SMorrisRC is offline Find More Posts by SMorrisRC
Old Jul 20, 2011, 10:38 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Leave it to a UK guy to make it simple.
How about defining the algebraic formula, that would be simple.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Jul 20, 2011, 10:40 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
It is simple! It just doesn't look it!
Old Jul 20, 2011, 10:45 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
C'mon, a dump truck driver doesn't know what Pi is?
I'm an accountant and I just barely remember what Pi is? 3.14 I think.
OK, so in what order in the algebraic formula solved?
Pretend it's Algebra 101 and list each step to solve the equation, that would be simple.
Old Jul 20, 2011, 11:08 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
Ok.
The FSA is the area of the fan itself, minus the area of the motor (because it blocks the air).
The area of the fan is: 3.14*r*r
where r is the radius of the fan (so a 70mm fan would be 35, a 90mm fan 45 etc. etc.)
The area of the motor is, by the same logic, 3.14*r*r
where, r is now the radius of the motor (so, a 70mm fan motor is typically 28mm, so r would be 14)
If you then want an 85% FSA thrust tube, the exit diameter is then calculated as follows:
You take the FSA that we just calculated and multiply it by 0.85.
This then gives you the area of the exit you want.
To find the diameter, divide this 85% FSA area by 3.14. Then square root it, which gives the radius. The exit diameter you want, is then simply double the radius. Make sense??
Old Jul 20, 2011, 11:09 AM
Joined Aug 2010
The EDF in question is a 90mm Midi Pro and ARC 36-65. Thank you all for the replies!
Old Jul 20, 2011, 11:18 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
Here you go, I just knocked up a quick spreadsheet to do it for you. Only type in the green boxes. (For 90mm fan, motor diameter is usually around 36mm).
Old Jul 20, 2011, 11:33 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
Thank You SCMorrisRC, you made my day.
Old Jul 21, 2011, 06:24 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Does the F in FSA refer to the fan rotor or the complete fan unit?
What happens if I have a rotor with negligible size hub, then a motor mount with a motor tube, and then further back in the air stream sits an outrunner motor. The outrunner bell is wider than the motor tube.
Is the FSA then the rotor area minus the motor tube area, or minus the outrunner bell area?
MegaTesla is offline Find More Posts by MegaTesla
Old Jul 21, 2011, 08:45 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
Hmmmmm. A bit of a grey area. I would personally assume the outrunner bell if the duct is still the same diameter as the rotor at that point.
Old Jul 21, 2011, 09:24 AM
gapple12 is offline
Find More Posts by gapple12
gapple12's Avatar
Joined May 2009
Awesome post. Thanks for doing that. I just figured mine and will probably make it out of a fountain drink cup.
gapple12 is offline Find More Posts by gapple12
Old Jul 21, 2011, 10:02 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
No problem.
Old Jul 21, 2011, 07:02 PM
gapple12 is offline
gapple12's Avatar
Joined May 2009
How does the length of the tube come into play ? Does it matter how long if you have the right opening on the end and at the fan ?
Help! Thrust tube repair? Kenta78 Foamy EDFs 2 Jun 05, 2011 06:56 AM
Question Efflux velocity from thrust & FSA? meteor Electric Ducted Fan Jet Talk 20 Jul 14, 2005 11:37 AM
EDF thrust calculator Doc Watson Electric Ducted Fan Jet Talk 8 Mar 07, 2002 09:43 AM
