Old Jul 19, 2011, 08:32 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Build Log
Speedfire HV
Fun steps first... I bought a neu 1512 2.5d on clearance and just slapped on a spare 6.7 p32 box I had around. It took some grinding, but it seems to be in good shape.
I also needed a new esc, so I picked up a 160hv. The hv lite was way too $$$, so I thawed the regular one into a lite.
Pics of plane to follow!
la528it is offline Find More Posts by la528it
Old Jul 20, 2011, 08:42 AM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Wow Rich! That's a lot of ingenuity. I had a chance to run one of the newer designed Neu rotors and pinions recently. It was kind of a crazy hot liner set up; small light weight motor spinning very high rpm. 1508.5 1.5D; 4800 kv / 6.7 gear ratio, 15x18 inch prop, on 6S 2700. Now that's asking for trouble and more of a 4s kind of set up normally, but it survived and peaked at 5500 watts using throttle delay and max brake. From this test, I see that the new pinion is very well worth it. I mention this in case you have the older style pinion, in which case you might want to use a soft brake. Can't wait to your see the HV rocket! E
epwierman is offline Find More Posts by epwierman
Old Jul 20, 2011, 09:11 AM
jjmouris is online now
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Hey Rich, are you going to support those thin motor wires with something? Just asking cause compared to the 8 AWG wires on the ICE they are a bit on the thin side.
Remember this?
http://static.rcgroups.net/forums/at...6-DSCF8602.jpg
Should be a fun setup! What plane?
jjmouris is online now Find More Posts by jjmouris
Old Jul 20, 2011, 11:11 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
Eric, I have no idea if this is newest pinion or rotor, all I know is that the pinion was just purchased new, and the box came from an 1107 I had laying around. BTW, its not ingenuity, its frugality!
Josef, I will mount the esc on a Popsicle stick, I just need to develop an appetite for grape Popsicle which is all I have in the freezer at the moment.
Going on the latest and greatest f5b to emerge from cz... the speedfire
Old Jul 20, 2011, 02:05 PM
combatflier is offline
Find More Posts by combatflier
silicon valley CA
Joined Mar 2004
I wish Steve would still sell the 6.7:1 with pinion for his motors that don't have a gb on his clearance page. I was going to buy a clearance motor but he wouldn't sell me a gb for it... bummer. Looking forward to see where this goes.
combatflier is offline Find More Posts by combatflier
Old Jul 23, 2011, 09:29 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
That is one beautiful plane.
Is it the pre installed wing servo version?
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 23, 2011, 10:54 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Yes, it goes together fast... the horns are in very low though, I may bore them out and raise them if the servos demonstrate any play... too early to tell. I just finished shaving the clevises and filing away one wiper...
Discussion F5B - SpeedFire GeorgiMirov High Performance 495 Mar 02, 2015 11:26 PM
Wanted CC 85 HV or CC 110 HV esc AIR SALLY Aircraft - Electric - Power Systems (FS/W) 4 Jan 14, 2009 11:37 PM
Wanted Phoenix HV 85 or HV 110 N99JH Aircraft - Electric - Power Systems (FS/W) 4 Aug 21, 2008 05:07 AM
Sold Phoenix 45 HV and Phoenix 85 HV arclite5 Aircraft - Electric - Power Systems (FS/W) 0 Dec 19, 2007 03:35 AM
New CC HV controllers - CC 110 HV "the beast" Protocooler High Performance 11 Jun 23, 2007 05:58 PM
