Old Jul 19, 2011, 06:08 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
Build Log
Creep 2.0 - Tricopter
Building on the success of the Creep 1.0 Tricopter, here is the newly designed Creep 2.0. Airframe is made of laser cut light plywood, nylon motor mounts and arm clamps produced in a 3D Laser Printer (Laser SLS ) and 450 heli tail booms.
Highlights
-Airframe parts are laser cut or laser printed
-DT-750 motors are modded with thrust bearings for maintenance free flight
-1.9 lbs. total weight (configured with Paris Wii, AR8000 Receiver and TM1000 telemetry unit)
-Airframe has pre-cut holes for Paris Wii board
-Arms are standard 450 heli tail booms
-Yaw mount is mid frame and entire rear arm rotates on precision bearings for smooth operation
-All three motor mounts are identical/interchangeable
-Rear motor sits as the same height as the front motors for more uniform control
-Nylon arm clamps and motor mounts naturally absorb motor vibrations so no extra vibration dampening hardware is required
-All motor/ESC wiring is internal to the arms for a super clean look
-Custom wiring harness allows for motors, ESC or entire arms assemblies to be removed and replaced easily and quickly
-Arm clamps and motor mounts can also work for a quad, hexa or octo copter. Motor mounts can be set at any angle to help with poor yaw tendencies of hexa and octo copters (no need to add expensive angled shims)
It all started with a CAD drawing.
Files are emailed off and airframe parts are produced. (this is actually the first design but they weren't good enough. A redesign was done and parts reordered)
Airframe parts are painted.
DT-750 motor mounts are installed with nylon screws and nuts. Screw heads are blackened with a Sharpie.
Skids and arm clamps are mounted on the main board. Arm clamp screws are installed from the bottom during the wiring and electronic install process.
Nylon standoffs for the Paris board is installed. NO EXTRA ANTI-VIBRATION HARDWARE REQUIRED.
The heli booms can be used "as is" if a stock gyro only configuration is used, but if a Paris board is used then the rear arm needs to be cut 18mm so it will sit flush with the inside of the arm clamp like the front arms do.
Here is a gyro/Flymentor install where the rear arm does not have to be cut.
Test fit of Paris board and arms.
Wii components are installed on the Paris board and then installed on the nylon standoffs.
The top plate gets the receiver, servo and telemetry unit installed and a custom wire harness made for the receiver.
The rest of the wiring is completed to include the battery to ESC wires.
Here's a great photo of the rear arm, yaw assembly and the wires that travel through the rear arm. The entire arm will rotate.
Wiring/connections are prepared at each motor mount. The ESC signal wire connection will be tucked into the end of the arm. The small red and black wires will be cut off except on the rear arm. The rear ESC BEC will power the electronics.
The top plate is installed on the upright screws. Then one by one each screw is removed and reinstalled from the top.
The excess screw length is cut to allow the battery mount to be installed and reduce weight.
All the screws are installed with a nut, tightened and then blackened. Here you can see the blue wires that make up an umbilical chord for the USB programmer.
Receiver wiring harness is connected to the Paris harness.
Motor and propellers are installed. Wiring is tidied up. Motors are modified with thrust bearings that won't wear out like the stock ones. (Note: this same motor mod reduced current draw by 3 amps on my quad and makes the motors wicked quiet ).
Here is the rear motor and mount. It is identical to the front motors except for the 2 extra (red and black) wired that run from the BEC to the electronics.
The battery mount is installed.
The canopy magnets are epoxied onto the top plate and the canopy. Here, extra magnets hold the canopy magnet in place while the epoxy dries.
The servo wire is cut short and a connector is installed. This allows for the top board to be removed much easier.
Thanks HK for laser engraving my tail boom!
Build complete!
Weight = 1.9 lbs (configured with Paris Wii, AR8000 Receiver and TM1000 telemetry unit)
johnorama is offline Find More Posts by johnorama
Site Sponsor
Old Jul 19, 2011, 06:28 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
Creep 2.0, Tail # 1101
Here is the test flight of the very first Creep 2.0 airframe. This is a gyro and Flymentor configuration. It was extremely smooth even in the high winds (watch the trees towards the end).
Creep 2.0 Tricopter, Tail #1101 (2 min 54 sec)
Site Sponsor
Old Jul 19, 2011, 07:55 PM
Huskiemuskie is offline
Find More Posts by Huskiemuskie
Explore the Unknown
Huskiemuskie's Avatar
Berlin Center, Ohio
Joined Oct 2010
http://vimeo.com/25989864
Nice work JJ ! It is looking real good!!! Flies great!
tz
Huskiemuskie is offline Find More Posts by Huskiemuskie
Old Jul 19, 2011, 09:30 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
Universal Camera Mount for Creep 2.0
Camera/Battery Mount replaces the stock mount. Adds .06 lbs to the total weight. Rubber tubing connects the mount to the aircraft to further reduce vibrations from motors, winds and pilot control inputs.
Site Sponsor
Old Jul 20, 2011, 09:40 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
wow really well done...
the motor mounts for those booms. are they available to buy off the shelf?
I'd like one for a standard sized motor with a + mounting plate.
captaingeek is offline Find More Posts by captaingeek
Old Jul 20, 2011, 09:53 AM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
I do plan on making these parts available for sale. I would need the specifications of the hole pattern for your motor to include a center hole for the shaft/bearing to breathe.
Site Sponsor
Old Jul 20, 2011, 09:54 AM
Kilby is offline
Find More Posts by Kilby
Joined Nov 2010
Nice work, John! That looks great.
Kilby is offline Find More Posts by Kilby
Old Jul 20, 2011, 10:02 AM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
Thanks. But it flies better than it looks!
Site Sponsor
Old Jul 20, 2011, 11:59 AM
MrDusanmandic is offline
Find More Posts by MrDusanmandic
Closed Account
Joined May 2011
Where do you send off to have your parts cut? Are you sending them a CAD file?
MrDusanmandic is offline Find More Posts by MrDusanmandic
Old Jul 20, 2011, 12:17 PM
Kilby is offline
Joined Nov 2010
John, if I get around to building another tricopter anytime soon this will be the airframe for me. Right now I'm working on a quad and hexa, plus still flying the Creep 1.0 that you modded for me.
Old Jul 20, 2011, 12:48 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
Lasercutusa.com cuts my ply. And yes, I just send them the CAD file.
Site Sponsor
Old Jul 20, 2011, 12:51 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
I can get you an airframe pretty quick. A ready to fly may not come for awhile. And I don't plan on taking orders for these. If I have something ready I will advertise it. I will keep a waiting list for those who want something.
Site Sponsor
Old Jul 20, 2011, 06:15 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
Very nice John, a real proffessional build. Hope to see it flying one of these days.
I also think those motor mounts would be real popular.
capt is offline Find More Posts by capt
Old Jul 21, 2011, 02:05 AM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
Thanks. The mounts appear to be getting some attention. Private messages are coming in.
I flew it this morning at the new field. it does well with the stock settings. I have of with in Oregon...it has been a long day driving. 9 of 10th hours down.
Site Sponsor
Old Jul 21, 2011, 10:55 PM
UAV Dude KF7HYV
johnorama's Avatar
Joined Mar 2007
DT-750 Motor Mod
I do want to share the bearing modification that I am using. After all the help I have received from others in the Tricopter community, it's the least I can do to give back. When I do the next mod I will photograph the steps but for now, here is the short version.
The heart of the mod is a 4x9x4mm thrust bearing. You need to add this to the bottom of the motor. Here are the basic steps:
1. dismantle the motor
2. loosen the set motor shaft set screw on the motor bell
3. use a small file to flatten a spot on the motor shaft 4mm above the point where the set screw currently makes contact with the shaft.
4. push the motor shaft down at least 4mm
5. lubricate the stock bearings
6. reassemble the motor just like it was but do not install the bottom e-clip
7. slide the thrust bearing onto the motor shaft at the bottom of the motor and lubricate it
8. install the e-clip
9. thread a 4mm nut onto the motor shaft all the way to the bottom
10. tighten the nut slowly until the e-clips removes all the slop from the thrust bearing. Spinning the shaft will cause the bottom race of the thrust bearing to spin twice as fast as the middle bearing when installed properly.
11. tighten the motor shaft set screw
12. remove the 4mm nut
13. don't over tighten the prop nut or you could compress the thrust bearing. I install an upside down flange nut finger tight first, then the prop and then another flange nut. Then tighten the top flange nut while holding the bottom flange nut.
Note: this only works with the newer style DT-750 motors
Site Sponsor
New Product Tricopter - The "Creep 1.0" johnorama Multirotor Talk 439 May 16, 2012 09:24 AM
Discussion 12FG Software version 2.0/2.1 Manual Needed skyboyken Radios 2 Jul 02, 2011 12:30 PM
Build Log Tricopter v1.0 3qUInOc Multirotor Talk 10 Dec 27, 2010 11:04 PM
