Joined Feb 2013
Hi Sorry for the newbie question, but I am toying with the idea to get started with the RC plane hobby. I thing the NE Sky Surfer might be a good candidate to start (after having spent some serious time on the simulator that is on its way).
I have a question for the Sky Surfer owners. How can you tell when the battery in the plane is low? Is there some circuitry that cuts off power before the battery goes depleted beyond recovery? Is there any sort of alert in the remote? This is the quote from Wikipedia: Quote:
Thanks, Luca |
United Kingdom, England, Keighley
Joined Nov 2012
Hi Luca,
The sky surfer was (and is) my first glider. I know very little of other gliders but am getting on just fine with it. I do have lots of experience with lipo's though. The transmitter does have a low voltage warning, but only for the AA batteries in the transmitter, not the lipo. A couple of thoughts on running your lipo down: If your anything like me, your first flights won't be long enough to run it completely flat - I got over an hour on my last outing, which included a lot of on motor time. It takes relatively little power to glide and operate the servo's and receiver compared to the motor. If you start to run low on juice, the first sign is that the motor won't provide much thrust. I found that when this happened, there was still plenty in the tank to glide gently back down to earth where I can recharge the battery. Replacement batteries are very cheap. It's worthwhile buying a spare or two so you can play all day. If you're worried about the running it down too low, bring it in after an hour and swap over. Given the choice, I think I'd rather not have a LVC - if I were ever in the situation of running out mid air, I'd want the glider to stay active till the very end whilst I try to bring it home, rather than shut off in mid air, even at the expense of busting a $4 battery. Hope that helps! Stu |
United States, UT, Salt Lake City
Joined Aug 2012
Twitching aileron servo
I just got the sky surfer out for the first time this spring only to find the aileron servo twitching. It worked fine when I last flew it in the Fall. Battery is charged. Rudder and elevator servos are working normally.
Any thoughts? |
Joined Nov 2012
Mine started twitching one time I put the wing on. I think that the rx antenna was just touching the servo and making it grump. I put the wing back and it cured it.
On a separate note, does anyone know how the spinner and prop detach? After a week in a tree she's been recovered today, but needs a new prop. I see there's a screw in the very middle of the prop which I've removed, but it still doesn't want to budge. I don't want to break anything! |
Joined Feb 2013
Hi guys, I received my new NE Sky Surfer last night. This is my very first plane so it is hard to tell what is normal and what is not, because I do not have other planes I can compare.
The first impression is not of overwhelmingly good quality. The servos feel on the cheap side, as well as the tiny wires and connector for the ailerons servo on the wings. What does not look too reassuring is that it feels that aileron do not have the same range of movement. Giving full right ailerons makes them flex more than when giving full left ailerons (or maybe the other way round, I do not recall it exactly). Anybody noticed this as well? I do not think that mine is a defective version it does not seem broken and it responds to the commands, it just feels a bit flimsy. On the other side, I generally read good reviews about this plane, so I guess I just need to be reassured. Maybe I got spoiled by the simulator, that, being virtual, shows smooth control surfaces movements, when maybe in real life things are more jerky. I have a question for the group. I expect that I will have to do regulations before it will be ready to fly. The obvious one is the CoG that I understand is regulated mainly by placing correctly the battery, but what about the control surfaces? Apart using the trim buttons on the transmitter is there any regulation that can be performed directly on the plane? The servos are a kind of worm drive (http://en.wikipedia.org/wiki/Worm_drive), where it is very easy to turn the worm by hand. Is it how trimming on the plane is performed? Looking forward to trying it during the week end. Thanks, Luca |
Joined Nov 2012
Lucas, I had unequal aileron movement too. it turned out that mine hadn't been put together correctly - there's a plastic piece shaped a bit like a bow tie that moves the ailerons - check that the metal wires for the ailerons are inside the slots on the plastic piece.
Hopefully that makes sense, if not I'll take a picture |
| Thread Tools | |
| New Product Nine Eagles Sky Runner | deadduck | Foamies (Kits) | 150 | May 19, 2013 12:53 AM |
| New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) | SoloProFan | Micro Helis | 1644 | May 17, 2013 03:46 PM |
| New Product Nine Eagles Sky Climber | chuckf | Electric Sailplanes | 414 | May 05, 2013 08:05 AM |
| Discussion Nine Eagles Sky Runner Trimming | brawl100 | Beginner Training Area (Aircraft-Electric) | 5 | May 29, 2011 09:52 AM |
| Discussion Nine Eagles Sky Eagle | chris_wade | Beginner Training Area (Aircraft-Electric) | 3 | Apr 28, 2011 03:50 PM |
