United States, MO, Grandview
Joined Feb 2012
Hello, I have not seen that case but I really like how good the box works as a case. I also really like this battery. http://www.hobbyking.com/hobbyking/s...dProduct=22906 I'm going to get another one on my next order. I am also looking to order some carbon fiber and an aileron servo replacement. I need some advice on what to get and how to install reinforcement so my wing doesnt v like that picture above. Also I think my aileron servo is bad and I would like to replace it with a micro servo like skydvjam but keep the rest of the electronics. is this possible? the plug might not match up but maybe I can solder it? I have had some of the same problems as others with the aileron plug coming loose and prop flying off. I unfortunately lost mine and already got a replacement which I applie krazy glue to the shaft first and has worked fine.
Joined Nov 2008
Edmond |
Joined Apr 2012
I`m going on your modification and the motor fits great really, but the question is on the shaft long, on the inrunner is 4.8mm and the stock motor has a 7mm. In my opinion that those 2mm might be missing. Did you secure the stock prop with epoxy or CA? It will be enough? Thank you for response. |
I had a bad crash with my Sky Surfer (all stock) and a couple of pieces broke off of the front of the fuselage.
Wing, motor, and electronics are all fine. I want to try to repair it, and I want to use the hot water/steam method to reshape it. My question is, should I glue it back together before or after I reshape it? I would think before. Also, any suggestions on what glue to use? I have several types, including regular CA, canopy glue, Gorilla Glue, and Stik N Seal.I also want to slow it down a little, will adding weight to the back help with that? Thanks! |
Joined Jan 2011
I use a E10-36 L from Hacker for my little skysurfer.
E10-36 L Use less 4 amp => install thunderbird 6amp. AR6310 2gram RX with DMSX perfect for FPVsystem no interference and no worry about crashes. Total weight 101 gram Fuselage = 59 gram Thunderbird 6amp = 4 gram E10-36 L = 14 gram AR6310 = 2gram Ultra-Micro Digital Servo 1.9g / 0.04sec / 0.17kg = 4x 2gram Turnigy nano-tech 260mah 2S 35~70C = 14 gram The Hacker motor has 150grams punch. 45W 4300KV extra punch to fly 90° up to skyward. And fits perfect in the motormount. Ca glue for the folding prop is necessary. I try it without and I saw the prop flying away. Hacker motors are much better then made in HK junk. Fly speed above 70kmh!!! |
| Thread Tools | |
| New Product Nine Eagles Sky Runner | deadduck | Foamies (Kits) | 150 | Yesterday 12:53 AM |
| New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) | SoloProFan | Micro Helis | 1644 | May 17, 2013 03:46 PM |
| New Product Nine Eagles Sky Climber | chuckf | Electric Sailplanes | 414 | May 05, 2013 08:05 AM |
| Discussion Nine Eagles Sky Runner Trimming | brawl100 | Beginner Training Area (Aircraft-Electric) | 5 | May 29, 2011 09:52 AM |
| Discussion Nine Eagles Sky Eagle | chris_wade | Beginner Training Area (Aircraft-Electric) | 3 | Apr 28, 2011 03:50 PM |
