Old Jul 18, 2011, 04:12 PM
ServoCity is offline
Find More Posts by ServoCity
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
New Product
NEW! Servo Reverser on ServoCity.com - $39.99
The SR10 Servo Reverser from Futaba uses a one-channel output to drive two servos, and is used in models that require one servo to operate in reverse. Since two servos can be simultaneously driven, the affect of the servo operation delay can be minimized compared to using the transmitter mixing function to use two channels to drive two servos. Transmitters without mixing functions can also be used. Use of a precision power supply and temperature compensation circuit makes circuit operation stable. The SR10 trimmer allows neutral adjustment of the reverse servo and simplifies the linkage. Filter reduces interference with the receiver antenna. The SR10 Servo reverser measures 38 x 23 x 10mm (excluding projecting parts and connection cord) and weighs 24 grams.
IN STOCK at ServoCity.com:
http://www.servocity.com/html/sr10_servo_reverser.html
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
New Product 180 Degree Servo Stretcher - $19.99 at ServoCity.com ServoCity ServoCity.com 0 Jul 14, 2011 10:15 AM
Mini-Review Antenna Tracker from ServoCity.com - FPVManuals.com Review ServoCity ServoCity.com 0 Jul 11, 2011 04:01 PM
New Product New Vertical Aluminum Servo Mounts from ServoCity.com ServoCity ServoCity.com 1 Jul 01, 2011 09:04 PM
Discussion $39.99 for spektrum ar6110e with bonus at targethobby.com keytech Foamies (Kits) 11 Aug 09, 2010 02:25 AM
Discussion Hitec HS-55 $10.99 11/16-11/25 ONLY at ServoCity.com! cynjon Hot Online Deals 2 Nov 16, 2006 07:49 PM
