This thread is privately moderated by myrcmart, who may elect to delete unwanted replies.
Old Jul 18, 2011, 02:37 PM
myrcmart is online now
Find More Posts by myrcmart
Joined May 2009
New Product
RCX S9257 High Speed Digital Servo (4.5kg / 25g / 0.07sec / Tail & Rudder Servo Suita
RCX S9257 is a high speed, high torque digital servo suitable for 450 & 500 series helicopters. It is an excellent tail locking servo for 3D flight.
http://www.myrcmart.com/rcx-s9257-hi...le-p-3600.html
Equipped with two ball bearings.
For use with the Futaba GY401 (FUTM0807, FUTM0808) and the GY502 gyros.
Does not work with these Futaba radios (4FG, 5FG/K, 6FG, 6FG/K, 7FG/K New Terratop, 3EGX, 3PGE, 2NL, 2LGX, 2FR, 2PK series) These radios have a servo neutral signal of 1310us not compatible with this servo.
Do not use with AM radios.
Specification
* Dead band: 0.002ms (Default)
* Control System: +Pulse Width Control
* Working Frequence: 1520μs / 80hz Digital mode/Analogy mode
* (RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
* Operating Voltage: 4.8~6.0 Volts DC
* Operating Temperature Range: -10 to + 60 Degree C
* Operating Speed (4.8V): 0.08 sec/60 degrees at no load
* Operating Speed (6.0V): 0.07 sec/60 degrees at no load
* Stall Torque (4.8V): 3.8 kg.cm
* Stall Torque (6.0V): 4.2 kg.cm
* 360 Modifiable: NO
* Motor Type: Coreless Motor
* Potentiometer Drive: Indirect Drive
* Driver Type: FET
* Bearing Type: Dual Ball Bearings
* Gear Type: Plastic Gear
* Programmable: YES
* Connector Wire Length: 18.0
* Dimensions: 35.5mm x 15.0 x 28.6mm
* Weight: 25 g
Package Included
* 1 X RCX S9257 High Speed Digital Servo (4.5kg / 25g / 0.07sec / Tail & Rudder Servo Suitable)
* 1 X Set of Servo Arm
myrcmart is online now Find More Posts by myrcmart
Sold INO-LAB D201-HB 9g ULTRA SPEED 0.07sec/60 DIGITAL SERVO w/ AL HEATSINK tail servo Sonex128 Aircraft - General - Radio Equipment (FS/W) 1 May 25, 2011 11:12 PM
Discussion GWS Mini Digital LXF 4.5Kg/ 0.073sec at 4.8V; 5.1Kg/0.065sec at 6.0V GWS4CEO 3D Flying 1 Apr 26, 2011 11:53 PM
For Sale Futaba S9257 Digital Heli Rudder High Speed Servo RCDXER Aircraft - General - Radio Equipment (FS/W) 0 Jul 20, 2009 08:46 PM
