Old Jul 18, 2011, 10:38 AM
bowhunter911 is offline
Find More Posts by bowhunter911
bowhunter911's Avatar
United States, IN, Portage
Joined Jul 2011
HZ Champ battery questions
Hi, i just ordered a hz champ and am getting ready to order some batteries from hk. the 160 mah nanos look like a good deal and i will order some of those. what are the biggest batteries i can use in the champ? i saw the 300mah nanos....will those fit? also i want bigger wheels, i saw the 35mm ones and they look good. what thickness do i need? ive never use an rc plane before and dont know much about what i should buy. Thanks, Dennis
bowhunter911 is offline Find More Posts by bowhunter911
Old Jul 18, 2011, 11:12 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
1. Dubrow 1.23 wheels
2. Hyperion 500 mah.
A peice of foam in the battarea. Done.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Jul 19, 2011, 05:22 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
With the 500mah batt, your feet will get tired before the battery does.
The 160s will let you fly absurdly long.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Jul 19, 2011, 05:50 PM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Holy Crap, 500mAh - you may wear out a set of brushes before the battery gets tired!
flyeraroo is offline Find More Posts by flyeraroo
Old Jul 20, 2011, 12:00 PM
artisan23 is offline
Find More Posts by artisan23
Spain, Aragón, Huesca
Joined Apr 2011
I use 500mah lipos (from my blade 120sr heli) in my Champ all the time. The little bit of extra weight helps when conditions are not dead calm. Flights of 20-25 mins can be achieved easily but I limit myself to 15 mins so not to over stress the lipos.
artisan23 is offline Find More Posts by artisan23
Old Jul 20, 2011, 12:39 PM
Joined Jul 2011
adapter
can you tell me what adapter i need to use for the 420 and 500mah batteries? i am brand new to R/C planes and it doesnt seem like there is a standard for the plugs. i have seen on ebay the jst plugs, the mini jst plugs, another that starts with an "s", a dean style plug and the little plug on the champ that i havent found the name for. does anyone know what the champ one is called? Thanks, Dennis
Old Jul 20, 2011, 12:41 PM
Joined Jul 2011
also
a link to the plug adapter i need to use the bigger batteries would be great. Thanks,Dennis
Old Jul 20, 2011, 05:15 PM
Joined Oct 2006
http://www.bladehelis.com/Products/D...ProdID=BLH3126
sells around $1.50 as well comes wth the E-flite battery as a combo if not that is the one
Old Jul 21, 2011, 06:03 PM
Joined Jul 2011
battery
do you think this is the right plug to connect to the champ? if so i want to order a few http://cgi.ebay.com/3-7V-420mAh-15C-...item3f04ac81bf
Old Jul 21, 2011, 06:06 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
No that plug will not fit the champs battery plug.
Ridgewalker
ridgewalker is offline Find More Posts by ridgewalker
Old Jul 21, 2011, 06:08 PM
Joined Aug 2008
The plug in the link fishycomics gave is the adapter plug needed to run the 500 mah battery.
The 500 mah battery is the only size battery i use in my micros,the one that came with it just won't cut it for me.
Ridgewalker
Old Jul 30, 2011, 05:50 PM
newflyer100 is offline
Find More Posts by newflyer100
Anyone know the cheapest/quickest place to get the Hyperion 500 battery (or an equivalent)? Thanks!
newflyer100 is offline Find More Posts by newflyer100
Old Jul 30, 2011, 07:17 PM
Joined Oct 2006
http://cgi.ebay.com/E-Flite-Blade-12...item43a65ab8a0
Ebay 8.00 plus good luck
Old Aug 02, 2011, 06:54 PM
New Hyperion G3 3.7v 550mah 25c/45c battery and the little plug adapter both ordered from quantumhobby.com for $7.44 total plus shipping...and is scheduled for delivery this Thursday! Quick question...I've seen on another forum that the E-flight 500mah battery actually fits in the existing Champ battery slot...is this true also with the Hyperion?
(Although I'm sure I'll have to cut out the compartment towards the nose of the Champ since with all the added weight of the battery, the cog will be affected since the battery is longer...right? Any trial and error tips for when I start cutting (if needed) the battery compartment? Thanks!)
Old Aug 03, 2011, 05:32 PM
Can you use an E-flite Celectra 0.3a charger to charge a Hyperion 550mah battery?
Uggg...I just got my new Hyperion 3.7v 1 cell 25C 550 mah battery in the mail today, and just realized I have nothing to charge it with!
I was planning all along to use my E-flight Celectra 4 port charger, but it says on the charger it is 0.3a, which is 300mah, right? Does that mean it will never fully charge my 550 mah battery? Or does it just mean with will take twice as long to charge it?
Hoping not to have to go buy another charger for this one battery...can anyone answer if that charger will charge my new battery?
Discussion HZ Mini Super Cub battery questions Downstream Beginner Training Area (Aircraft-Electric) 12 Jan 14, 2012 10:43 AM
Question First Plane - HZ Champ or HZ Mini Super Cub? NVFlyAngler Beginner Training Area (Aircraft-Electric) 32 Jul 31, 2011 10:56 PM
Question What motor can I put in my HZ Champ without having to change anything else? newflyer100 Micro Ready-to-Fly 8 Jul 27, 2011 12:39 AM
Question Can I Use This Battery In a HZ Champ? astronaut Micro Ready-to-Fly 19 Apr 20, 2011 06:03 AM
Wanted WTB - HZ Champ or HZ Super Cub cardinalsfan Aircraft - Electric - Airplanes (FS/W) 6 Feb 10, 2011 11:24 AM
