The config is set to 1 (NTSC)
The camera out is also set to NTSC @ 4:3 aspect ratio. I briefly came across a post last night where someone else had similar issues, said it had something to do with the latest version of code not working well. All of the previous versions are in .doc format for some reason so until I get the chance to sit down at one of my other computers I'm at a stand still. |
Danmark, Midtjylland, Galten
Joined Oct 2011
Line 154 in config. If you can please try to change "#if (video_system == 0)" to:
#if (VIDEO_SYSTEM == 0) This is the code-part where it's used: #if (video_system == 0) // PAL #define toplinetext 41 #define toplinenumbers 51 #define butlinenumbers 271 #define timer_line 252 #define gps_nmea_line 32 #define summaryline 102 #define current_calc_line 292 #else //NTSC #define toplinetext 24 #define toplinenumbers 34 #define butlinenumbers 229 #define timer_line 210 #define gps_nmea_line 15 #define summaryline 100 #define current_calc_line 260 #endif |
Successful build
Hi
I would like to thanks Dennis Frie and other contributors for such great project! I realized DIYOSD with LM1881 on breadboard from bare components (no stupid arduino pro mini), recycled GPS module from remzibi and it simply works! Next time I would design proper PCB, probably cheap single sided without mask, as breadboard is too laborious and not pretty at all. ![]() Can't wait to try it in air. Thanks! |
![]() Here is my LM1881 bread boarding project based upon Dennis' design, it sits on top of an Arduino ATMEGA1280 and run MultiWii Firmware. The OSD is mobiDroneOSD. There is STILL Life in the LM1881 design. |
Joined Jan 2013
I've been testing DIYOSD on a breadboard with an Arduino UNO and an old TV. I had to adjust the line settings pretty dramatically for it to all show up on the screen. I thought I would post this for those having trouble with the top/bottom being cut off.
Here are my NTSC settings: Code:
//NTSC #define toplinetext 54 #define toplinenumbers 64 #define butlinenumbers 214 #define timer_line 195 #define gps_nmea_line 45 #define summaryline 90 #define current_calc_line 260 ![]() Cheers, - Jason |
Latvia, Riga
Joined Jan 2012
I cann't get it to work with baud rate 115200. Is it even possible? I cann't change my baudrate because I need it to use with multiwii, my general purpose for this was to have one gps for multi wii and osd.. now it is not working with that rate.. :/
![]() On a more serious note - it's awesome to see the projects be used like that. Really nice and clean setup with a PCB. Can't really say anything but great work ![]() You should give the version with MAX7456 a shot if you solder PCB anyway |
I was not going to sell them. I made this just because I wanted (liked). I don't have time even to test it.
I am also going to make one 25x25mm powered from RX 5v without USB with Bat, Current and RSSI inputs ![]() When I will test them I will think about expenses and maybe sell some. |
OK
I will solder some more of these after I will successfully test it. My friend also asked. I summed components, board, soldering... and seems I could give away these for 29$ shipped worldwide with tracking. (I wish i could get components as cheap as Chinese and some Chinese to solder this )If someone interested I will count people and solder that quantity. Can't give any date but hope this would not take long (count people interested + order components + solder) Please don't be angry if I will find out that something is not OK with resign. USB and OSD works fine, need to test all ADCs and serial port |
Joined Mar 2008
hello,
I would like to join this thread and enjoy this great OSD, but my OSD does not work properly. Attached pictures of my circuit, the only thing that shows the screen output is a snapshot that lasts a few milliseconds, and appears in different horizontal position every 10 or 15 seconds. I've tried with the following changes in the code: # define CONTROLLER 0 or 1 # define VIDEO_SYSTEM 0 or 1 (do not know the camera system as it is reused) # define align_text_ 1 to 22 (I tested all intermediate values) And the result is always the same. I can not find the error. Thanks and sorry for my English |
Joined Mar 2008
hello,
After many hours and testing, the result is that multiple cirtuitos not fail, but fails to VGA Adaptor AV: http://www.ebay.es/itm/290694941022?...ht_4555wt_1397 Connecting the circuit to capture it works correctly. Now the problem is that this model does not detect GPS: http://www.ebay.es/itm/271079582518?...ht_1886wt_1163 I do not know how to set it from the code, and how they connect BACKUP and 1PPS signals. Thank you. |
A better option would be to replace this part of the code:
It would be a good improvement to put this into the shipping version of the code, just to remove some of the issues with the occasional stock GPS incompatibility. It sets the baudrate 57600, which should always work (as opposed to using the gps' stock 115200 baud, which can be flaky with this OSD). It would be a good improvement to put this into the shipping version of the code, just to remove some of the issues with the occasional stock GPS incompatibility. |
Joined Mar 2008
thanks for the replies.
I've changed the lines indicated in the file DIY_OSD_v0_18.ino But the result is the same. SAT: 00 NO GPS FIX The GPS blue LED flashes every second. I have checked the connections: Tx GPS >>>>> Rx OSD (with transistors to increase voltage to 5V) Tx OSD >>>>> Rx GPS (with diodes 3.3v) thanks again for your time and help |
Are you indoors? For me, even though I'm on the highest floor of my house, I don't get gps lock at all. Try the same thing you're doing, but go outside.
Some things that you may want to consider. The arduino doesn't need transistors to increase the voltage to 5v, because the logic high threshold of the Atmega is 3v; if the GPS is supplied with a solid 3.3v, there will be no problem with that. Another thing is that you should really use a regulator to get the 3.3v for the GPS, its just a more stable voltage. It should never require more than 50ma, so for GPS regulators I like to use the TI TPS77033, but any 3.3v regulator will work well. And I have to say, that's a really expensive GPS module. |
Joined Mar 2008
Thanks Legot.
I've been testing for more than an hour on the outside with the new code, but not working. I tested with a 3.3 V regulator with a diode in series and removing the transistors, but no way. I tried on the computer with the program MiniGPS_v1.7.1 and everything works fine. I do not know what else I can try. I'd appreciate if you show me where to buy some GPS economic model that works well with this OSD. Regards |
I'm using the Locosys LS20031, it's a MediaTek MT3329-based setup. It's not the cheapest ($50 at polulu.com), but it works well with the OSD. It's 3.3V, so you either have to change the settings external to the OSD (I used my PC with a usb->serial adapter) or have a logic level converter so that you don't write to the GPS serial channel at 5V. It's very sensitive, I get good lock inside my house, and it has a battery backup to keep the ephemeris for quicker acquisition. It's slightly power hungry, but I think most GPS chips are during acquisition.
Joined Mar 2008
hello again,
After many changes in the code I can not find the solution, because with the code mentioned in the line: Serial.print ("$ PMTK314, 0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 * 28"); Crack! and the execution does not continue. I'll try to set Handmade gps with miniGPS program, but has too many values I do not know how to fill, I have tried many options but not working. I put a screenshot of my gps with possible options. Thank you. |
That is so strange. I use a 3329 based module as well, but the 3339 is supposed to be functionally identical. There's no reason to change modules if yours works with the MiniGPS program, I was just making a comment.
Try setting up the module for 57600 baudrate, GGA: 1, RMC:1 (all others:0), DGPS doesn't matter, and 5hz fix update rate through the Mini GPS program. Another possibility, is it at all possible that your RX and TX wires to the GPS are swapped? (I have problems with this all the time.) That's the best I can come up with at the moment, sorry and best of luck. Ooohh! something else that may or may not be worth a try is changing that line of code to: Quote:
Joined Mar 2008
hello,
First of all, I forgot to mention that the module is cheaper, this is the actual link: http://www.ebay.es/itm/Very-Small-MT...#ht_1905wt_917 item code, after much reading in various forums, attached what I think would be a correct settings, but for some strange reason, if I put more than two sentences, execution stops and the program crashes. Code:
Serial.print("$PMTK251,57600*2C\r\n"); // // Set NMEA port baud rate 57600 baud
delay(100);
Serial.write(13);
Serial.write(10); //57600 baud
Serial.print("$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n");
delay(100);
Serial.write(13);
Serial.write(10); //Sets GPGGA and GPRMC to update once every fix
Serial.print("$PMTK220,200*2C\r\n"); // //5Hz refresh rate = 200(millisecond) = 0.2(sec) 1/0.2 = 5 Hz
delay(100);
Serial.write(13);
Serial.write(10); //5Hz refresh rate
Serial.print("$PMTK300,200,0,0,0,0*2F\r\n");
delay(100);
Serial.write(13);
Serial.write(10);
Serial.print("$PMTK313,0*2F\r\n"); // Disable to search a SBAS satellite.
delay(100);
Serial.write(13);
Serial.write(10);
Serial.print("$PMTK301,0*2C\r\n"); // Disable to search a SBAS satellite.
delay(100);
Serial.write(13);
Serial.write(10);
If I set it to hand, how I can I remove the connection that goes from Tx OSD to Rx GPS? The output signal of the GPS module working properly measured with an oscilloscope. This is the output: $GPRMC,183242.000,A,4138.0757,N,00445.6716,W,0.38, 246.22,010213,,,A*70 $GPGGA,183243.000,4138.0758,N,00445.6712,W,1,6,1.1 7,748.1,M,51.6,M,,*4B $GPRMC,183243.000,A,4138.0758,N,00445.6712,W,0.43, 246.22,010213,,,A*76 $GPGGA,183244.000,4138.0758,N,00445.6710,W,1,6,1.1 7,748.1,M,51.6,M,,*4E $GPRMC,183244.000,A,4138.0758,N,00445.6710,W,0.45, 246.22,010213,,,A*75 $GPGGA,183245.000,4138.0759,N,00445.6708,W,1,6,1.1 7,748.1,M,51.6,M,,*47 $GPRMC,183245.000,A,4138.0759,N,00445.6708,W,0.53, 246.22,010213,,,A*7B $GPGGA,183246.000,4138.0759,N,00445.6706,W,1,6,1.1 7,748.1,M,51.6,M,,*4A $GPRMC,183246.000,A,4138.0759,N,00445.6706,W,0.69, 89.76,010213,,,A*4F $GPGGA,183247.000,4138.0758,N,00445.6702,W,1,6,1.1 7,748.1,M,51.6,M,,*4E $GPRMC,183247.000,A,4138.0758,N,00445.6702,W,0.68, 103.24,010213,,,A*7E $GPGGA,183248.000,4138.0755,N,00445.6697,W,1,6,1.1 7,748.1,M,51.6,M,,*41 $GPRMC,183248.000,A,4138.0755,N,00445.6697,W,0.73, 104.27,010213,,,A*7F This can not be so complicated .... |
Wait wait wait... Is that the exact code your uploading to the OSD?
Because the entire setup routine for the GPS is commented out... Before and after the serial.print section that you've been working with, erase the /* and the */ Maybe that's the problem? If it isn't, then I have absolutely nothing left to try. |
Joined Mar 2008
hello Legot
Thanks for your time to check my code, actually, all code to configure the GPS is commented. If I do not comment, program execution stops and the OSD stops working. So I manually configure the program MiniGPS GPS (attached image above) and battery backup saved settings. I have also flashed the GPS to the latest version, but still not working. I ordered some optocouplers to connect GPS and OSD, I do not know what else to try. Too bad it does not work, it is a good and cheap GPS ideal for an interesting project like this. : (: (: ( Thank you very much to all for your time |
Joined Jun 2010
Hey guys i have a problem here.
I want to use this one without any gps module like one of those "Simple OSDs" showing only time and voltage. So i stripped the "output.ccp" to only show voltage and time. So far so good works as expected. Now the problems starts. As time is calculated my the gps in need to find another way to calculate the time. I guess the best way to do this is using the Arduinos millis() command. So i added this to the calculation part of the output.ccp. Code:
flight_timer2[0]=((flight_time2/1000)/600)+3;
flight_timer2[1]=(((flight_time2/1000)%600)/60)+3;
flight_timer2[2]=(((flight_time2/1000)%600)%60)/10+3;
flight_timer2[3]=(((flight_time2/1000)%600)%60)%10+3;
Code:
flight_time2 = 1415000; Code:
flight_time2 = millis(); Here is what i have done so far |
Joined Mar 2008
Hi all!
I've got some more time to try to solve my problems with gps. First I changed the setup code for this: Code:
#define MTK_SET_NMEA "$PGCMD,16,1,1,1,1,1*6B\r\n"
#define MTK_SET_NMEA_SENTENCES "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n"
#define MTK_OUTPUT_4HZ "$PMTK220,250*29\r\n"
#define MTK_OUTPUT_5HZ "$PMTK220,200*2C\r\n"
#define MTK_OUTPUT_10HZ "$PMTK220,100*2F\r\n"
#define MTK_NAVTHRES_OFF "$PMTK397,0*23\r\n" // Set Nav Threshold (the minimum speed the GPS must be moving to update the position) to 0 m/s
#define SBAS_ON "$PMTK313,1*2E\r\n"
#define WAAS_ON "$PMTK301,2*2E\r\n"
#define SBAS_OFF "$PMTK313,0*2F\r\n"
#define WAAS_OFF "$PMTK301,0*2C\r\n"
#define SBAS_TEST_MODE_1 "$PMTK319,0*25\r\n" //Enable test use of sbas satelite in test mode (usually PRN124 is in test mode)
#define SBAS_TEST_MODE_0 "$PMTK319,1*24\r\n"
#define GPS_SERIAL_SPEED 57600
uint32_t init_speed[5] = {9600,19200,38400,57600,115200};
for(uint8_t i=0;i<5;i++){
Serial.begin(init_speed[i]); // switch UART speed for sending SET BAUDRATE command
#if (GPS_SERIAL_SPEED==19200)
Serial.write("$PMTK251,19200*22\r\n"); // 19200 baud - minimal speed for 5Hz update rate
#endif
#if (GPS_SERIAL_SPEED==38400)
Serial.write("$PMTK251,38400*27\r\n"); // 38400 baud
#endif
#if (GPS_SERIAL_SPEED==57600)
Serial.write("$PMTK251,57600*2C\r\n"); // 57600 baud
#endif
#if (GPS_SERIAL_SPEED==115200)
Serial.write("$PMTK251,115200*1F\r\n"); // 115200 baud
#endif
delay(300);
// at this point we have GPS working at selected (via #define GPS_BAUD) baudrate
Serial.begin(GPS_SERIAL_SPEED);
Serial.write(MTK_NAVTHRES_OFF);
while (Serial.available() != 0) {Serial.read();}
Serial.write(SBAS_OFF);
Serial.write(WAAS_OFF);
Serial.write(SBAS_TEST_MODE_0);
Serial.write(MTK_OUTPUT_5HZ); // 5 Hz update rate
Serial.write(MTK_SET_NMEA_SENTENCES); // only GGA and RMC sentence
Serial.write(MTK_SET_NMEA); // Si no lo pongo no continua
Now looking at the code, I have a couple of questions, I would like to see on screen data received by arduino, but I can not find this function in your code, there is no (Serial.read) On the other hand I have doubts with external button, there are several lines of code like this: Code:
if (CONTROLLER ==1 | Usebutton == 1) {
if (digitalRead(Buttonpin)==LOW) {
Thank you very much. |
Joined Jun 2010
Hey,
thanks to a tip from Dennis i could fix my problem. I did myself a power distribution board for small quads with an onboard diy osd which shows only time and voltage. The OSD is also able to control the quads leds to make them blink when battery is low:
Joined Apr 2011
Hi!
This is my 1st post on rcgroups, i try the code and works perfect. A video of my first test using diy-osd:
My next test must include: more light, a better camera, a more portatile tv, and then i try gps first and then current/voltage sensors. Thanks a lot!! regards from chile, |
Hello Everyone,
A good news about SimpleOSD Open. As you know, we didn't produce it since few months because of new design and production. My plan was making it smaller, lighter and cheaper ![]() After few PCB design problem and reproduction now I did it. This is new SimpleOSD X2 ![]() It is coming with useful features for opensource programmers. And best news it is only 39.90$ ![]() The product page: http://www.flytron.com/osd-headtrack...l-edition.html Schematic: http://www.flytron.com/pdf/SimpleOSD_X2.pdf Features:
You can use a standard FTDI cable to programming it. I just add some lines into the DIY-OSD 0.18 firmware for compatibility. You can download it from the attachments. @Dennis: You can track the differences into the code with "X2" keyword. Can you update your original for the future updates? Here is the list: config.h Replaced line Code:
//Arduino = 0, SimpleOSD OPEN = 1, SimpleOSD X2 = 2 #define CONTROLLER 2 Added this line because of different dim, voltage and current pins Code:
// SimpleOSD XL OPEN 16 mhz
#elseif (CONTROLLER==1)
// Input from current-sensor and voltage-divider
#define voltage_divider_input 7
#define current_sensor_input 4
#if (dim_on == 1)
// This is used for dimming. can be changed to another pin if you want.
//define SimpleOSD OPEN's dim pin C5
//SimpleOSD OPEN XL
#define DimOn DDRC |= 0b00100000;
#define DimOff DDRC &= 0b11011111;
#else
#define DimOn DDRB |= 0b00000000;
#define DimOff DDRB &= 0b11111111;
#endif
#define little_delay _delay_loop_1(13);
// SimpleOSD X2 16 mhz
#else
#define voltage_divider_input 0
#define current_sensor_input 1
#if (dim_on == 1)
//define SimpleOSD X2's dim pin B1
#define DimOn DDRB |= 0b00000010;
#define DimOff DDRB &= 0b11111101;
#else
#endif
#endif
Replaced Line into SETUP section Quote:
Please feel free to any question. Cheers Melih |
Hi Melih
It looks good ![]() I've been busy with the MAX7456 OSD project lately and not been around much here (you have probably noticed, that I have bought a few GPS-units and current-sensors). I will try to get some time and update the software sooner or later. By the way, send you an e-mail long time ago regarding the MAX7456 version. You are also welcome to use that for anything you like. |
Hi Dennis,
Yes i noticed your GPS+Current sensor orders and I tried to making a surprise to you and put few units SimpleOSD X2 into your pack but didn't finish it in time :/ Anyway, now they are ready to shipping ![]() Personally i don't like complicated electronics like MAX based OSD devices but of course i will glad to subscribe you. Have you got any group for MAX based OSD project? |
![]() The extra components needed on the MAX7456 version is not exactly an advantage, but the overlay looks better and there is a lot more processing-time left. But the simple design here is really nice. I will test the OSD ASAP and report back and have an updated software-version compatible
Joined Jan 2013
Joined May 2009
Technical question here... please help meee! I'm killing myself trying to figure out whats right...
You say there is a negative part in the pal signal, which is backed up here: http://en.wikipedia.org/wiki/File:PAL_2_lines.png But then this guy is generating PAL with just 0-1v: http://www.rickard.gunee.com/project.../pic/howto.php How does it work if the Sync level is suppossed to be -1.5v ?!?!?!?! I'd really appreaciate it if you could help me... I live in a NTSC country but I'm thinking about developing a PAL OSD that's plug and play with Multiwii and can get the Gyro-Accel-Magnetometer-altimeter data straight through serial... Of course it would be open source Any help appreciated! I need this confirmed so that I can start developing while the PAL gear I ordered is on its way. |
I think I saw also MinimODS code for MultiWii somewhere. |
The simple solution is to AC couple the video signal; which just means feeding it through a large value capacitor. This passes the high frequency video signal to the next stage but blocks DC. The signal reference level is shifted positive or set above 0V by the next stage . Now it can operate from a simple single supply. There are some minor problems introduced by the AC coupling. Quality is reduced and the average DC level is all over the place, which can affect the ability of the next stage to lock onto and track the video signal when it's less than idea; which is often the case with FPV. I had this problem a while back and added a DC correcting amplifier to the groughd station. This made previously crappy cameras look quite good. Paul |
Yes I did. But it is not an open product. You can also do that with DIY-OSD, I can only show the way to you. Just download the ArduPilot project and isolate the altitude calculation code. Or maybe you can find BMP085 library with temperature compensated altitude calculation code on the net. Then you can integrate it into the DIYOSD code. Sorry for this close code things but HobbyKing copying our all projects and we have to do this for surviving and supporting future projects ![]() thank you for your understanding. Melih |
Regards, Carl |
Joined Mar 2009
Here's some arduino code and detailed explanations on using bpm085 here :
http://www.sparkfun.com/tutorials/253 |
Joined Jun 2012
Hi i tried your scheme with arduino mega 2560, but there is mosi in pin 51 not 11, where i must make change in code ? i make change in pinMode(11,OUTPUT); to pinMode(51,OUTPUT); it's everything ? Thanks...
i tried non changed code, but display nothing show. I tried now in this scheme ![]() Thanks for any idea. |
Joined Jun 2012
Ok, i tried on iduino nano http://www.ebay.com/itm/190746782529...84.m1439.l2649
but nothing show i tried turn slowly left or right with potenciometer but nothing happend.Any idea ? Thanks for reply I use version 0,18 without changes... |
Joined Oct 2011
NOOOO, I bread boarded it. worked perfectly, made a protoboard to fit onto my mini pro and nothing haha, back to the drawing board.
Has anyone made a protoboard like the Denis did, if so is there any chance I can see your design? with some close up pics of the front and back ? |
Joined Oct 2011
Yew got it, now I need to work out powering a 3.3v gps, sigh!
Joined Oct 2010
I am going to rebuild the project again and use an oscilloscope to find out what's wrong.. |
Joined Oct 2011
What Arduino are you using? I had a very similar issue with the UNO but got it working just fine with a Mini Pro |
St. Pete, FL
Joined Feb 2006
The Arduino Micro is another very small board and is conveniently available at Radio Shack. I tried building the code for it, but for the Micro (essentially the same as the Leonardo) a number of constants used had to be changed because the Serial IO and timer are different from other boards. Also, the Micro has only about 28K available because the boot loader steals about 4K from flash memory and the compiled program is a bit too large to fit. (Maybe there are some tricks that can be done to reduce the memory taken up by the ASCII file.)
Has anybody else tried building this project for the Arduino Micro board? --Van |
St. Pete, FL
Joined Feb 2006
I decided to try the Arduino Uno board and got better results with the compiler. The version 18 code compiled as-is but I cannot seem to get the sync to stabilize. The camera is a Sony 600TVL Super HAD that outputs NTSC video. The OSD display looks very similar to that in post #2271. I've tried 10K, 50K and 100K pots with similar results. The USB is being used for power source (5V).
TIA for suggestions, --Van |
Joined Nov 2011
Hey guys is there any simple way in the code to remove\disable the GPS and related text? Just point me in the right direction so I don't have to reverse engineer all the code here. I'm looking to just show pack v and mah at this time and add the GPS later if needed.
Joined Nov 2010
NEO-6M GPS from Hobby King. How to make it work?
I just received the inexpensive NEO-6M module from Hobbyking- $21.99. I had the OSD working with an Adafruit breakout board, but when I attached the NEO-6M instead, I got nothing. The LED on the GPS flashes at about 1 second intervals. Testing with a simple Arduino Adafruit program shows the GPS putting out something, but not intelligible. The unit comes pre-set to 38400 baud. Can someone tell me how to make this GPS work?
Thanks Dick |
Joined Jun 2013
Remove or disable the GPS related text
This is not a pro solution but it worked for me (until someone tells me how to do it properly) I just moved the text away from the visible area. In the config tab. Change the values as follows (maybe other values for NTSC). #if (video_system == 0) // PAL #define toplinetext -100 #define toplinenumbers -100 #define butlinenumbers 271 #define timer_line -100 #define gps_nmea_line -100 #define summaryline -100 #define current_calc_line 292 Now I only see volts, amp and mah. //Antonov www.fpvteamsweden.com |
Joined Jan 2012
Well, maybe it's because i'm just a noob in electronic and µC programming (actually, i wrote my first blink sketch on arduino 1 month ago
), but i tried to write my own OSD prog based on the atmega328/LM1881, and it's really a pain in the ass ! All what i can do is some flickering lines. I tried with timers, SPI and asm delay (i used your delayX functions Dennis, as i don't know asm), and i can't make a single clean lettre that doesn't flicker like hell !So Dennis, please allow me to express my respect for your work and my thanking to share it (even if i still don't understand half of your code). u rox. |
I've been thinking, and I don't think its possible with this particular hardware just because of the limits on timing that were mentioned.
On the implementation end of it you would need a gyro stabilized gimbal that's capable of 360 degree continuous motion (with continuously varying speeds) so that you can have an ultrasonic sensor or the like spinning at a constant speed on a level plane. In software you would have to take the continuously changing range data from the Ultrasonic sensor and plot it as polar coordinates around a little stationary image of the multirotor. This polar graph would then have to spin in relation to the multirotor's orientation (from a magnetometer, which would also determine the speed of rotation for the sensor). Overall, the hardware is a little tricky but pretty simple. The software is where it gets difficult, you would definitely need allot of power and speed to make it useable. Maybe in some other graphical OSD designed by a legend? |
| Thread Tools | |
| Discussion Diy osd | karl k | Video Piloting (FPV/RPV) | 2 | May 03, 2011 12:31 AM |
| Idea New DIY OSD? | atari7202 | Video Piloting (FPV/RPV) | 1 | Mar 25, 2011 12:08 AM |
| Discussion see my own diy OSD video | Passion | Aerial Photography | 7 | May 27, 2010 01:28 AM |
| Discussion REAL homebrew DIY OSD - Check it out! | jafoca | Video Piloting (FPV/RPV) | 8 | Jun 29, 2009 06:52 PM |
| Discussion picoOSD DIY PIC12F683 based OSD in C | kbosak | Video Piloting (FPV/RPV) | 6 | Jan 31, 2008 07:47 AM |
