Espritmodel.com Heli Air
Old Nov 18, 2012, 08:54 AM
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Just did a quick test...
Lots of weird lines on the screen
OSD test (0 min 14 sec)
Not perfect yet, but getting there.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Nov 18, 2012, 08:57 AM
rimshotcopter's Avatar
Joined Aug 2009
Dennis, you just LOVE toying with people's desires. Ha!!! Great Job and something that is vitally needed.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 18, 2012, 09:06 AM
Just another user
Joined Feb 2011
Well, a friend mentioned it would be nice when flying through clouds
Just need to test if an accelerometer is good enough.
Old Nov 18, 2012, 09:08 AM
Joined Aug 2009
The MPU6050 are very cheap and there is a Gyro all in one package.
Old Nov 18, 2012, 09:54 AM
Just another user
Joined Feb 2011
Ordered... At that price I can just as well use both accelerometer and gyro
Old Nov 18, 2012, 10:03 AM
United States, AZ, Prescott Valley
Joined Feb 2012
http://www.youtube.com/watch?v=lAFR7...ature=youtu.be
Dennis,
Is this still the same project that we started this thread with as in this schematic? -
Rick
RickEis is offline Find More Posts by RickEis
Old Nov 18, 2012, 10:05 AM
Just another user
Joined Feb 2011
Originally Posted by RickEis View Post
Dennis,
Rick
No sorry, it's with a MAX7456 OSD chip instead. It gives a lot of extra CPU-time to do whatever you want
Old Nov 18, 2012, 10:19 AM
Joined Feb 2012
Hi Dennis,
Would it be possible for you post the schematic and code you are working with so far, even though it is not polished ?
Even though it is not perfected....it is fun to follow
I have a https://www.sparkfun.com/products/9168 so maybe I could incorporate it also for others to follow
Thanks again for sharing,
Rick
Old Nov 18, 2012, 10:30 AM
Just another user
Joined Feb 2011
Hi Dennis,
Rick
The breakout-board from sparkfun will be compatible and just needs a few wires to an Arduino or similiar
I'm not quite sure what I'll do with the project yet, but there is already quite a few MAX7456 OSD's out there if you need some inspiration.
Old Nov 18, 2012, 11:02 AM
Joined Feb 2012
Dennis,
Your open source work inspires me (not sure about the others !! -
I have been looking for a simple schematic (as you say "needs a few wires" ) and small piece of code (that works to connect an arduino to this sparkfun board to get me started. Can't find one !
Rick
Old Nov 18, 2012, 11:04 AM
Joined Aug 2009
Dennis,
Rick
+1 to that!
Old Nov 18, 2012, 11:13 AM
Joined Feb 2012
I would like to know how to connect the few wires from the MAX7456 to an uno and a very simple code that would insert something like "hello world" onto the screen.
Old Nov 18, 2012, 11:18 AM
Just another user
Joined Feb 2011
Dennis,
Rick
Remember the reset-line must be pulled high on your board.
The code from Sparkfun gives a good idea about the communication with MAX7456. It's not copy-paste compatible with Arduino, but close
I plan to release everything sooner or later, but not until I have a descent version available.
Schematic will be available when the PCB arrives and have been confirmed to work
Old Nov 18, 2012, 11:19 AM
Joined Aug 2009
Listed at the bottom of the page is some sample code and a schematic.
Old Nov 18, 2012, 11:37 AM
Joined Feb 2012
Well, I have looked at the schematic and code at the bottom of Sparkfuns page but it appears I am missing some knowledge on connecting it and getting the code to compile with the arduino - So I am looking for some help Have you got something that works with the arduino and sparkfuns board?
Old Nov 18, 2012, 11:38 AM
Joined Aug 2009
I looked also and was disappointment. My Bad.
Old Nov 18, 2012, 11:42 AM
Joined Feb 2012
That Ok rimshotcopter
So can you show a schematic and write a code that will compile and make my screen say "hello world" ?
Old Nov 18, 2012, 11:44 AM
Joined Aug 2009
Sorry I do not have one but here is another ODS with open source code: http://code.google.com/p/rushduino-osd/
Old Nov 18, 2012, 01:32 PM
Just another user
Joined Feb 2011
Sorry, but I don't have a simple code available - only the mess I'm working on
Old Nov 18, 2012, 03:23 PM
Just another user
Joined Feb 2011
narh, what the heck.. For those of you who want to have a look, feel free. But please be aware that it's in no way meant as a release-version
It should by no mean be used as a fully working version (though it most likely does work flawless ).
A few notes on schematic...
- MAX7456 crystal must be 27 MHz,
- C5 and C6 must be 47 uF
- Crystal-caps depends on the crystal.
- RSSI, current-sensor and RX+TX series resistor is just "random value" to get the footprint.
- Decoupling capacitors on Vcc (buttom right) is just to get the footprint for PCB-design. I will use what I have around and find suitable.
R5 and R6 should be 75 ohm resistors (video-impedance). I just put 82 ohm as the 75-ohm value wasn't in my library.
A few notes on firmware
- Very early version not tested very well.
LOS limit moved to around 50 kilometers
LOS will change from meters to km when above 10 km
UART uses interrupt for best performance.
Serial.print can't be used
Only ~30% memory used so far, plenty of space left.
If you have any questions or need help with the code, please wait until an actual release with a bit of explanation etc
https://dl.dropbox.com/u/3947315/MAX7456_OSD.rar
PCB-design etc. will most likely be available later.
The main firmware is pretty much done - so I'm open to ideas
Old Nov 18, 2012, 04:45 PM
Joined Feb 2012
Awesome work Dennis
Attached is a picture of the components which would be awesome to use if compatible with your program !
I'm hoping one of your (smarter then I) readers can use this image to sketch in the wires illustrating the connections, while you are continuing to polish your project.
Rick
Old Nov 18, 2012, 10:43 PM
Joined Feb 2012
Dennis,
Your program is the first larger program for this MAX7456 that compiled for me.... and I have tried a lot, attempting to get this up and running -
Looking forward to hooking it up soon
Rick
Old Nov 19, 2012, 01:33 AM
Joined Jul 2008
I see code for artificial horizon, but see no hardware to support it?
And I'll repeat my self, add possibility to send data to the ground, please
dziedrius is offline Find More Posts by dziedrius
Old Nov 19, 2012, 01:52 AM
Just another user
Joined Feb 2011
The code for artificial horizon is not done at all. The rounding-errors should be fixed and tilt should be implemented with better resolution - but it's a start.
I will later add some gyro and accelerometer support and a little filter to keep it running smooth.
Sending data to the ground is not really an option with MAX7456. Using the audio-channel is a possibility, but as I use Lawmate, I don't really have good audio-channel to use.
Old Nov 19, 2012, 02:09 AM
Joined Jul 2008
Why it is not an option with MAX7456? At the moment I don't see how those two things correlate, I just thought that MAX7456 will offload main processor, so it will be easier to add.
Haven't checked, but I think MAX7456 does not support VBI, so there's no ability to send data through video channel also - and I guess that cheap EasyCap ripoffs will struggle with VBI decoding.
Old Nov 19, 2012, 04:23 AM
Just another user
Joined Feb 2011
MAX7456 is designed to overlay graphics in the video. When using a part of the video-signal to transmit data, it would be preferable to "hide the data". Sure, you can still use a microcontroller to output some data, but atm SPI is used by MAX7456, serial by GPS and I2C by extra sensors. Not saying it ain't possible, just not straight forward. As I personally don't use antenna-tracker etc. I don't care too much about extra downlink information. My videolink will provide the necessary information.
Old Nov 19, 2012, 05:14 AM
Just another user
Joined Feb 2011
Awesome work Dennis
Rick
Hook it up and let us know how it works
You should note that you will get some chinese-characters, until you load my character-set for MAX7456 (included in the code but out-commented as they only have to be uploaded once).
Connect it like this, upload the code and you should see the magic start . You don't need a camera connected, it will automatic generate sync-pulses etc. if no video-signal is present.
MAX7456 -> Arduino
CS - > PB2 (10)
SDIN - > PB3 (11)
SDOUT - > PB4 (12)
SCLK - > PB5 (13)
GND - > GND
5 V - > 5 V
Reset - > Vcc
- if anyone plan to actually test the software, please let us know how it works
Old Nov 19, 2012, 03:00 PM
Joined Feb 2012
Dennis,
Again, it all compiled first time !!!! - amazing job !!! You would not believe how many things I have tried that would not compile.
This evening, if all goes well, I plan to hook it up like this (see attached photo), unless I have something wrong ?
Rick
Old Nov 19, 2012, 03:10 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Your drawing looks right - just remember to connect GPS TX and RX to RX and TX on Arduino to get data. The signal from the current-sensor should also be connected, but start with just Arduino and MAX7456 shield.
Old Nov 19, 2012, 08:35 PM
Joined Aug 2011
wow, that looks nice. Its been like 2 years since I first looked at this project, and I still haven't implemented this osd on my plane due to so many problems
FPVdude is offline Find More Posts by FPVdude
Old Nov 19, 2012, 09:57 PM
Joined Feb 2012
Dennis,
I came home and wired it up. Before I plugged the OSD into the video stream, I made sure I had a good picture with the camera etc. Then I plugged in the OSD and no change. So I redid the diagram just to be sure and rewired it....still no numbers etc.
Hmm...I'm suspicious of the connections to the mini pro.
I can't make sense of the your original schematic verses what you emailed me here?
Looks like HSYNC, VSYNC and LOS all need to go to VCC through 1K resistors ....yes?
MAX7456 -> Arduino
CS - > PB2 (10)
SDIN - > PB3 (11)
SDOUT - > PB4 (12)
SCLK - > PB5 (13)
GND - > GND
5 V - > 5 V
Reset - > Vcc
Old Nov 20, 2012, 12:34 AM
Joined Feb 2012
Hey Dennis,
It also compiled first time with Arduno Uno V3
However same results - ie. no numbers
Hooked it up as follows
MAX7456 -> Arduino UNO
CS - > PB2 (2)
SDIN - > PB3 (3)
SDOUT - > PB4 (4)
SCLK - > PB5 (5)
GND - > GND
5 V - > 5 V
Reset - > Vcc
Rick
Old Nov 20, 2012, 01:51 AM
Just another user
Joined Feb 2011
Dennis,
MAX7456 -> Arduino
CS - > PB2 (10)
SDIN - > PB3 (11)
SDOUT - > PB4 (12)
SCLK - > PB5 (13)
GND - > GND
5 V - > 5 V
Reset - > Vcc
In that drawing you should connect 5 v directly to Vcc and not Raw (Raw should only be used if you connect a supply > 5 volt). If you connect to Raw it will use onboard voltage regulator. With just 5 volt input it will only give ~4 volt out. MAX7456 can't run below 4.75 volt.
When you tested with Uno, did you connect directly to the USB-port (for power) or same problem with 5 volt connected to Raw?
I will just check my connections when I get home..
(Just to be sure, you should be using 16 MHz crystal and not 8MHz)
Old Nov 20, 2012, 01:57 AM
Just another user
Joined Feb 2011
Just checked schematic..
http://arduino.cc/en/uploads/Main/Ar...-schematic.pdf
The pro mini schematic don't use the same pinout.. Explains the problem.
I think your Uno is a better candidate.
Old Nov 20, 2012, 01:54 PM
Joined Feb 2012
Uno and MAX
Dennis,
OK...when I get a few minutes I will hook it all up like this (see pict) and power it from the USB for now. I'll let you know what I find
Rick
Old Nov 20, 2012, 02:31 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Where did you find those connections? I doubt that's right, the picture you made earlier looked right for Uno (except for 5 v connected to Raw).
Old Nov 20, 2012, 02:35 PM
Just another user
Joined Feb 2011
Just a few quick picture...
Long story short - it's alive (have been tested)
A few prints (only some of them is the OSD project)
- and the first test-version mounted with just the minimal required components. The missing components is extra capacitors, voltage-divider etc.
Old Nov 20, 2012, 02:50 PM
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
Dennis,
Rick
One thing to try out is to use a 10kOhm pullup resistor between 5V and the RESET pin. This is something I picked up from the Aeroquad forum which uses the same board for OSD. WIthout it the MAX board keeps resetting.
If you can't get it working, lI can try to dig out some of the old code I have laying about for arduino. Its been over a year since I played with the MAX board, but it shouldn't be that difficult to get a picture from it when hooked up to the DUE.
- Thomas
thnilsen is offline Find More Posts by thnilsen
Old Nov 20, 2012, 02:53 PM
Just another user
Joined Feb 2011
- Thomas
10K pull-up resistor is the "normal" thing to do with reset-pins etc. but as the direct connection to Vcc is recommended in the datasheet, I would be surprised it that's the problem.
Nevertheless - it's worth a try
Old Nov 20, 2012, 03:17 PM
Joined Feb 2012
OK - hooked it up as in the last schematic - started with a good video - then I inserted our project - no difference - I did note that when only the output to the screen was connected the screen went from no signal to a gray screen when connected - then when I hook up the camera the screen shows what the camera see's - no OSD yet ?
Old Nov 20, 2012, 03:19 PM
Joined Aug 2011
can I buy that, please?
what about a kickstarter like they did with the CC3D?
Old Nov 20, 2012, 03:23 PM
Just another user
Joined Feb 2011
But SCK, MISO, MOSI and SS is still on pin 13, 12, 11 and 10? I don't quite understand why you use pin 5, 4, 3 and 2?
Old Nov 20, 2012, 03:26 PM
Just another user
Joined Feb 2011
I don't really think it's worth starting production, but I don't mind to share the PCB-design etc. if anyone can solder the parts
It's mainly the MAX7456 chip that's a bit tricky.
I have a new PCB-design that was ordered some time ago. It have been shipped and will hopefully arrive next week.
Old Nov 20, 2012, 03:30 PM
Joined Feb 2012
Dennis,
So you like this one
Rick
Old Nov 20, 2012, 03:40 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Just checked the connections again and compared with Arduino Uno schematic, my schematic and the breakout-board for MAX7456. As far as I can see that should be correct.
If you see a few posts back (okay, perhaps a lot) you can see that I also had the MAX7456 connected to the same pins on my Arduino-board
Edit:
Hard to see the exact connections, but as you can see I used pin 13, 12, 11 and 10.
Old Nov 20, 2012, 03:44 PM
Joined Feb 2012
Dennis,
Got it !! The last schematic was it
Rick
Old Nov 20, 2012, 03:48 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Perfect
I'll later post a little more details etc. on the project - mind if I use your picture now that you have confirmed that it works?
Now, to get rid of the chinese-letters, in the main function you can find 3 if-sentences called
if (1==0) {
bla bla
If you first change the 2 first to 1==1 upload the code and wait 10-20 seconds (it will upload text-characters etc). Make them 1==0 again and then do it with the last one upload and set it to 1==0 again. Not user-friendly, but hey, you are using a pretty early version
Old Nov 20, 2012, 03:49 PM
Joined Aug 2009
I can only dream at this point. Wow!
Old Nov 20, 2012, 04:18 PM
Joined Feb 2012
Perfect
if (1==0) {
bla bla
Dennis,
Of course you can use any of these pictures - I consider them more yours then mine anyway I could never have done this !! I'll keep updating the schematic as we add the components.
What do you mean, "you are using a pretty early version". If you are talking the MAX7456, it is new ! - just received it a few days ago for this project
Ya this Chinese letter thing is not too friendly - let me try and see if I can do it
I see you included a bunch of stuff for it in your download. We really need to make it easier for simple folks like me
Rick
Old Nov 20, 2012, 04:22 PM
Just another user
Joined Feb 2011
Dennis,
Rick
No worries, it's easier in the next version.
You don't need all the extra material I have included, all the characters, arrows etc. is already included in the code
By pretty early version I referred to the software-version
Old Nov 20, 2012, 04:54 PM
Just another user
Joined Feb 2011
Rick, you can upload this version.
It will automatic upload the characters for MAX7456. Just note that MAX7456 must be connected while you program the controller
https://dl.dropbox.com/u/3947315/MAX7456_OSD_2.rar
Old Nov 20, 2012, 05:08 PM
Joined Sep 2010
Looks sweet DF!
msev is offline Find More Posts by msev
Old Nov 20, 2012, 05:19 PM
Just another user
Joined Feb 2011
Originally Posted by msev View Post
Looks sweet DF!
Thanks. I just measured the weight, its around 6 gram atm. Not bad at all.
Old Nov 20, 2012, 05:20 PM
Joined Feb 2012
Dennis,
Easy enough!!! (see pict ! )
This was with the old version and your instructions -
I'll try your new version in a bit .
Rick
Old Nov 20, 2012, 05:24 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Haha, great!
The new version just does it all automatic first time it boots.
There is also a lot of minor changes, but it looks the same
Old Nov 20, 2012, 05:49 PM
Joined Feb 2012
We need this to work with the Pro Mini also - You thinking it won't ?
I can't figure the pins - guess I need to study them a bit more ?
For example
GPS -> Arduino UNO
GND - > GND
5 V - > 5 V
IN - > PD1 (??)
OUT - > PD0 (??)
Rick
Old Nov 20, 2012, 06:06 PM
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
GPS -> Arduino
GND - > GND
5 V - > 5 V
IN - > TX
OUT - > RX
Note that in some designs the TX and RX may need to be reversed.
Legot is offline Find More Posts by Legot
Old Nov 20, 2012, 08:08 PM
Goiânia - Brasil
Joined Jan 2009
Does SimpleOSD Open works with ArduCam Configurator OSD? Can i load minimOSD firmware on it?
Snaydher is offline Find More Posts by Snaydher
Old Nov 20, 2012, 10:14 PM
Joined Feb 2012
Dennis,
V2 compiles first time with both mini pro and uno and looks excellent as in the pict I posted previously
I'm assuming V2 loaded the English text with the mini pro because I had only done it manually with the Uno - so I think it worked perfectly
When I input video, it threw the text around (see Pict).
- problem maybe ntsc verses pal?
Also I hooked gps-out to rx0 uno and gps-in to tx1 uno and "still waiting"
I believe the baud rate for my gps is 38400 - change the 9600 in config.h
//#define BAUD 9600
#define BAUD 38400
not sure if that was the right place to change things ?
Tried mini pro again - tried to read Arduino Mini Pro schematic -
(hard to understand for me
UNO -> MINI PRO
cs=pb2=pin 10 -> pin 12 ?
sdin=pb3=pin 11 -> pin 11 ?
sclk=pb5=pin 13 -> pin 9 ?
sdout=pb4 =pin 12 -> pin 10 ?
Didn't work - gray screen
// General configuration
#define VideoSignalType_PAL
//#define VideoSignalType_NTSC
// Unit system
#define UnitSystem METRIC
///#define UnitSystem IMPERIAL
// gps baud rate
Rick
Old Nov 21, 2012, 01:27 AM
Joined Feb 2012
Dennis,
Is this looking correct for the UNO ?
I have a hayday reading these arduino schematics
Probably because I never have
Rick
Old Nov 21, 2012, 03:42 AM
Just another user
Joined Feb 2011
For example
GPS -> Arduino UNO
GND - > GND
5 V - > 5 V
IN - > PD1 (??)
OUT - > PD0 (??)
Rick
GPS should be the same for all boards.
TX -> RX
RX -> TX
The pin-config for MAX7456 is the same for most Arduinos, just to mention the most used boards; Arduino Uno, Arduino duemilanove and Arduino Nano (which I would pick).
Arduino mini pro uses pin 9, 10 and 11 - but it doesn't seems like SS is available. It can probably be fixed with another software-version, but I would suggest using Arduino Nano instead.
Old Nov 21, 2012, 03:55 AM
Just another user
Joined Feb 2011
Dennis,
Rick
GPS is correct, but I would prefer if you connected the sensors like this:
(just move all 3 connections 1 place)
A0 = Battery voltage (from resistor divider)
A1 = RSSI
A2 = Current sensor
It can be changed in software, but that's what I'll be using as default.
Please be aware that the voltage you have connected from the current-sensor MUST be connected with a voltage-divider. Otherwise you will end up with a dead Arduino.
(Vin is battery-voltage, Vout goes to A0 pin on Arduino. For max 4S li-po, with good safety margin, something like R1= 10K ohm and R2 = 3.3 K ohm could be a possibility)
Old Nov 21, 2012, 04:19 AM
Just another user
Joined Feb 2011
Dennis,
//#define BAUD 9600
#define BAUD 38400
UNO -> MINI PRO
// Unit system
// gps baud rate
Rick
Yup, just define another baud-rate in the config-file
The "jumping text" is caused by wrong PAL/NTSC settings.
NTSC/PAL settings is not implemented, same goes for unit-system
If you actually plan to hook it up and do a real test - please let me know and I'll fix you a software-version with NTSC ASAP.
Old Nov 21, 2012, 09:20 AM
Joined Feb 2012
TX -> RX
RX -> TX
How does this schematic look for the Nano?
You said, "If you actually plan to hook it up and do a real test - please let me know and I'll fix you a software-version with NTSC ASAP."
A Nano should be here Monday and I hope to have everything running with the Uno, then I can load it all onto the Nano and fly -
Any other ideas beside the baud rate that would prevent the gps from working now?
I have a couple of these http://www.digikey.com/product-searc...ds=620-1238-nd
Do you think one of these would work better then the other sensor I have been showing in the schematics? Not sure what size Cf and Rf is supposed to be?
Rick
Old Nov 21, 2012, 04:38 PM
San Marcos, CA
Joined Aug 2009
Daniel, are you experimenting with the Max7456 yet?
Did you notice that coordinate 0/0 are out of the screen?
flyandi is offline Find More Posts by flyandi
Old Nov 22, 2012, 12:51 PM
Just another user
Joined Feb 2011
Daniel? Do you refer to me?
In that case, yes .
The hardware and software is pretty much ready for a test-flight, just need some sparetime
If you look at the last couple of posts you'll notice, that I have done a little more than a quick test.
Old Nov 22, 2012, 12:56 PM
Just another user
Joined Feb 2011
Rick
Sorry, been busy the last couple of days...
The schematic you have drawn for Arduino Nano should be right
Nano uses same pins as Uno, duem etc:
D13 = SCK
D12 = MISO
D11 = MOSI
D10 = SS
The voltage-divider is also connected right
You can connect the voltage from urrent-sensor to Vin (called Raw sometimes) if you want to use the onboard regulator.
The current-sensor from Allegro is pretty bad at driving capacitive load, so you will need a large capacitor and pretty small capacitor. Can't remember the values, but did a quick calculation and showed a simulation a while ago.
Old Nov 22, 2012, 02:38 PM
Joined Feb 2012
ACS756 verses Sparkfuns AttoPilot 90A
Old Nov 22, 2012, 03:40 PM
Legot's Avatar
Joined Nov 2009
Looks good. If you can get both, I'd love to see the performance differences.
Old Nov 22, 2012, 03:45 PM
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Interesting, I actually have the AttoPilot 90A. I've started to add some code to the Multiwii to use it but haven't finished. I found it actually to work quite well.
IceWind is offline Find More Posts by IceWind
Old Nov 22, 2012, 04:56 PM
Joined Feb 2012
Legot,
I have both and just soldered the ACS756 as you see in the pict. I need to solder the capacitors ect after I figure which size CF and RF as in the schematic (see report 2164 above)?
The specs say, "CF is for optimal noise management, with values that depend on the application". So what does that mean ?
Not sure if it would wire up the same nor if the code would work as is.
And I'm not sure how we would compare ?
Rick
Old Nov 22, 2012, 07:20 PM
Joined Feb 2012
D13 = SCK
D12 = MISO
D11 = MOSI
D10 = SS
Dennis,
You said, "You can connect the voltage from urrent-sensor to Vin (called Raw sometimes) if you want to use the onboard regulator."
Are you suggesting powering the Arduino's with a 3 or 4 cell ~ 11 + Volts? I guess I have been concerned about frying the little guys. And I heard switching BEC's are more efficient (for the larger V drops) then the linear voltage regulators (used by the Arduino's). So,,,,I have been using switching 5 ~ 5.5 V BEC regulators to power Arduino's. I got concerned and looked into when I saw folks frying their $200 APM2 boards Maybe my concern is not valid ?
Don't linear voltage regulators get hot going from 11 + down to 5 ?
Rick
Old Nov 22, 2012, 10:06 PM
Legot's Avatar
Joined Nov 2009
Legot,
Rick
CF is basically a smoothing capacitor. Its placement between VOUT and GND allows it to fill in dips in the analog signal (which is a voltage) that comes from VOUT so that the readout can be more reliable and accurate.
In the Performance Characteristics charts on the datasheet it shows that using a 10nF capacitor for CF, there is a maximum of 10mv noise (pretty much nothing since the Atmega328 ADC has increments of about 40mv). In the Common Operating Characteristics chart, it shows that the Output load capacitance shouldn't exceed 10nF, so CF should be 10nF or lower.
RF seems to be a simple current limiting resistor so the output of the IC doesn't burn. I would just use something around 1k ohm, its not a particularly critical value at all (correction, see post 1944).
Old Nov 23, 2012, 03:47 AM
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
Legot,
Rick
Rick...
Have a look here:
http://www.rcgroups.com/forums/showp...postcount=1944
Looks like a 10 nF capacitor and a 10 K resistor will be close.
HOL is offline Find More Posts by HOL
Old Nov 23, 2012, 04:41 AM
Just another user
Joined Feb 2011
Dennis,
Rick
A seperate 5-volt BEC/UBEC is probably the best idea, if you also use it for MAX7456 and GPS
They do get hot, but it depends a lot on the load and input-voltage.
But just stick to the BEC/UBEC, that's the best solution
Old Nov 23, 2012, 12:08 PM
Joined Feb 2012
Having trouble getting MAX7456_OSD_2.rar to see gps - The gps is working fine with the "TinyGPS" program -
I have set the baud rate in V2 to 38400 as in the "TinyGPS" program.
This is the gps I have (see attached). Maybe there is the DIYdrone firmware that is allowing it to work with the TInyGPS but not the MAX7456_OSD_2.
I see if working with Remzibi's OSD that DIY says one should install the Factory default firmware - It says, "Factory default firmware (If you're using Remzibi's OSD, you should use this!" maybe the problem?
Old Nov 23, 2012, 12:12 PM
Just another user
Joined Feb 2011
The OSD expects standard NMEA-strings. If the GPS uses some binary protocol, Sirf or something else, it will simply be ignored. I think Remzibi uses same GPS-settings, so that's most likely your problem.
Old Nov 23, 2012, 05:51 PM
Joined Feb 2012
Got it !
Thanks Dennis
Updated the gps firmware.
It appears V2 see's the gps now (see pict)
I'm hoping the flight video w/coordinates will help if the copter/plane goes down in the woods
Can we toggle on/off?
Rick
Old Nov 23, 2012, 05:58 PM
Just another user
Joined Feb 2011
Got it !
Thanks Dennis
Rick
Looks good
The delay is mainly to make sure the GPS have a good fix before setting home-postion. It can be changed in config-file.
GPS-coordinates is not exactly on top of the TO-DO list. It will require a lot of new small characters (or using same large font as the one that's used now).
Old Nov 23, 2012, 06:10 PM
Joined Aug 2011
On this DIY OSD, is everything connected the same way as the Minim OSD?
Like, would this work?
http://dx.com/p/minimosd-ardupilot-m...rotocol-149351
its only $27, with FTDI!!!!!!!!!
Old Nov 23, 2012, 11:11 PM
San Marcos, CA
Joined Aug 2009
MinimOSD is for Mavlink only .. it doesn't have any processing .. it's just a display board and all data needs to be transmitted calculated...
I am currently in the process of hacking the MinimOSD and rewrote the entire software :-) Tested today and I flew 22000mph :-D I got a the wrong conversion value .. hehe .. more in my thread "Hack the MinimOSD" - search on RCG .. it's late and I am lazy :-D
Happy Holidays!
Old Nov 24, 2012, 12:17 AM
Joined Feb 2012
A1 = RSSI
A2 = Current sensor
Dennis,
I hooked things up as in the schematic for the UNO and plugged a 3 cell into the current sensor after I soldered in the resistors (see Pict). On the other end of the sensor I plugged in a 5 volt BEC which powered the UNO, GPS and MAX.
The CUR on the OSD=0.0 ...maybe it is too small to measure? but I would think it might be 0.1 or something. I'll have to hook up a motor tomorrow to see if it measures any higher current.
The MAH is 0.0 . I'll leave this connected for a while to see if it measures anything
The VLT on the OSD =4.8 ~ 4.9.
I was expecting it to be the pack voltage + 12 Volts?
Any ideas?
Rick
Old Nov 24, 2012, 07:05 AM
Just another user
Joined Feb 2011
Happy Holidays!
Yes, all the pin-config etc. should be the same for MinimOSD. I have one one my desk and just did a very quick test. Firmware loads fine etc. - but the MAX7456 have another character-set loaded and some settings have been changed.
It behaves a little weird, but I believe that's just caused by the settings on MAX7456
Old Nov 24, 2012, 07:06 AM
Just another user
Joined Feb 2011
Rick, in config you have to change
#define VOLT_GAIN 1
It should match your voltage-divider. If you used 3.3K and 10K try with something like 5.12
The value is calculated something like this;
// Calculated by (1024)/(50*divider)
Edit: Think I might have done it different this time, might by 1/x instead. That gives something like 0.195 in your case
Old Nov 24, 2012, 08:13 AM
Just another user
Joined Feb 2011
Guys, to keep this thread on track for those making the OSD this thread was originally about, I've created a new thread for the MAX7456 version.
A lot earlier than planned, but the last many pages of this thread is MAX7456 talk
http://www.rcgroups.com/forums/showt...0#post23349412
Old Nov 25, 2012, 03:19 PM
Germany, Berlin
Joined Aug 2012
Hi Dennis!
Thanks for your time that takes this project.
My question is, if you could give some short advice to me for exploring the distorted display like in the attached picture.
The artificial horizon is okay even the attitude (0 0 0 °) - so what can i do?
cbob is offline Find More Posts by cbob
Old Nov 25, 2012, 03:39 PM
Just another user
Joined Feb 2011
Originally Posted by cbob View Post
Hi Dennis!
It's not my software you are using. Perhaps a heavily modified version, but not mine
What hardware do you use? LM1881 or analog comparator? If you use LM1881 it should do all the work. If it's the analog comparator, have you checked the potentiometer etc?
Old Nov 25, 2012, 03:46 PM
Germany, Berlin
Joined Aug 2012
I use the LM1881 on a breadbord.
I wonder, why a "middle" area is working but not the upper and the lower?! Could that be a timing problem? I use the newest (repacked) software.
Ah, and maybe this is important: I do not have no "sensores" attached to Conn2 - no battery no gps, no rssi.
Old Nov 25, 2012, 04:04 PM
Germany, Berlin
Joined Aug 2012
Hm, interesting thing: with mobidrone version 2.0 it works ?;-/
Maybe I have to adjust some parameters? Number of lines? It depends on the video signal?
Old Nov 29, 2012, 11:28 AM
Joined Aug 2009
Dennis, please may I ask you to give me an example of how to set up a Pin change Interrupt handler within the DIY ODS code? I know about using external Pins two and three but I also understand any of the other pins can be configured for an internal interrupt on change.
Here is an Library for Pin change however, I don't want to use the library but inline C code. Hope that makes sense.
http://arduino.cc/playground/Main/PinChangeIntExample
Thank you.
Old Nov 30, 2012, 07:52 AM
Joined May 2010
Hi Dennis!
I had this problem when I started using an edited version of the 0.18 firmware. The problem is that your lines are too "wide" - you are drawing pixels outside the screen. Decrease some delays, remove pixels, or remove som time consuming calculations to fix it.
XDreamer is offline Find More Posts by XDreamer
Old Dec 09, 2012, 11:28 PM
Legot's Avatar
Joined Nov 2009
This thread got quiet, is anyone still using it?
Old Dec 10, 2012, 12:12 AM
bob4432's Avatar
United States, AZ
Joined May 2010
morphed to this
bob4432 is offline Find More Posts by bob4432
Old Dec 10, 2012, 12:14 AM
I = V/R
Tw34k's Avatar
United States, FL, Jacksonville
Joined Aug 2012
I am, I've been trying to figure this out myself but I can't get the video tracking quite right.
I'm using the lm1881 and it's all just breadboarded up now, source camera is a keychain 808 #16v2, new firmware, all that jazz. I cannot seem to get the current and voltage reading section onto the screen, I've seen it down there with flickering but when everything clears up its gone. Is there a certain line of code I need to alter in order to, well, decrease vertical spreading?
What's the reasoning for moving on to this later MAX7456 in a nutshell?
Tw34k is online now Find More Posts by Tw34k
Old Dec 10, 2012, 09:01 AM
Joined May 2010
I'm using the original OSD, and the only thing I don't like is the dimming that is needed to show white text on bright backgrounds. My dimming is not dark enough, which makes the text hard to see sometimes. I think the MAX7456 is using a black border around the outline of the characters.
The code for the original OSD is also quite messy and takes up a lot of space. It consists of a lot of "should I put a pixel here or not?". In some cases this is nice, as you can draw anything on the screen. But you don't have time or space to do more advanced things.
Old Dec 10, 2012, 09:26 AM
San Marcos, CA
Joined Aug 2009
The Max7456 char set can also be easily modified. You can create your own symbols and letters.
Old Dec 10, 2012, 09:39 AM
Joined Sep 2010
I'm still using it, but I believe most of new features will be only introduced for max7456 osd since it has more code space
Old Dec 10, 2012, 10:00 AM
Joined Feb 2012
In a nut shell:
They are two separate OSD projects. This one is very simple, inexpensive and limited while still being an excellent DIY Open source OSD - (if it fails the rest of the system can keep running ie very safe)
The other project, the DIY MAX7456 OSD is almost unlimited, with a lot of extra CPU-time to do whatever you want. It incorporates a different set of hardware and various optional sensors. (If if fails most likely your flying craft will too
Both excellent and amazing projects and both can be built by a novice such as myself
Old Dec 10, 2012, 09:30 PM
Legot's Avatar
Joined Nov 2009
Yeah, I know about the MAX based one.
Just wondering if everyone has abandoned the tried and true 1881 based so quickly.
Old Dec 10, 2012, 10:43 PM
I = V/R
Tw34k's Avatar
Joined Aug 2012
I haven't, but I cannot seem to understand what is causing my 'screen fitment issue'. The circuit is breadboarded so connections are of course not ideal, once powering up the OSD I get this overlay with a constant flicker.
As you can sort of see the current and voltage line that's normally along the bottom has offset and started showing from the top of the screen.
Once I "jiggle my connections" I will eventually get this image which comes in clear but is missing the bottom portion of the overlay.
Any ideas?
Discussion Diy osd karl k Video Piloting (FPV/RPV) 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 Video Piloting (FPV/RPV) 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca Video Piloting (FPV/RPV) 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak Video Piloting (FPV/RPV) 6 Jan 31, 2008 07:47 AM
