Old Mar 14, 2012, 04:34 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by msev View Post
So lets say for example your 2.4ghz rf chip is that like a 2.4ghz equivalent of rfm22b?
Can you tune your 2.4ghz antennas with that or is a swr meter the way to go?
I'm using an RF-chip to generate the desired frequency, a SWR-meter to get the reflected power from the antenna and a microcontroller to control the RF-chip (the frequency) and measure the reflected power from the antenna (using the SWR-meter).
Dennis Frie is online now Find More Posts by Dennis Frie
Old Mar 14, 2012, 04:36 PM
Just another user
Joined Feb 2011
Originally Posted by rimshotcopter View Post
Did a field test this morning, the choice of location was not the best because I believe the interference was from the power lines. Secondly, the Resistor I added between the video feed line and ground, I believe is causing problems with the Picture HUE. Going to remove it and test again. Another issue is, when I focused the FOV lens, I used features close by, I need to figure out how to set it for infinity. Funny how these problems don't show up during ground testing.
http://www.youtube.com/watch?v=9wvahPgSrDM
Wow, quite different from what you showed yesterday. i have no clue whether that's caused by the resistors etc. or heavy interference.
Old Mar 14, 2012, 04:38 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I agree, I think before I pull that resistor, I will go back to the other park in the hills to make it was not the power lines.
Thanks.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 15, 2012, 01:54 AM
alex57russ is offline
Find More Posts by alex57russ
alex57russ's Avatar
Россия, Москва, город Москва
Joined Sep 2011
Hello, Dennis!
How to me to change a code in the program? I have a current a sensor on 100 A. To datasheet it is written:
0v =-100A, 2.5v=0A, 5v=100A
alex57russ is offline Find More Posts by alex57russ
Old Mar 15, 2012, 10:59 AM
vasago17 is offline
Find More Posts by vasago17
United States, ID, Fruitland
Joined Apr 2008
Here's a video from my FPV plane with the DIY OSD:
FPV Flying Through a Canopy (8 min 26 sec)
I didn't have the current sensor hooked up with I took this video so it's just showing random numbers. Everything else should be accurate...with the exception of the altitude drift on my GPS.
vasago17 is offline Find More Posts by vasago17
Old Mar 15, 2012, 11:19 AM
Just another user
Joined Feb 2011
Originally Posted by alex57russ View Post
Hello, Dennis!
That should be possible. If you set offset to 512 and use it as a 200A current sensor you should be able to get acceptable readings.
http://www.youtube.com/watch?v=AcmucsHrekI
Looks really good, thanks for sharing.
- But I have never seen a GPS with an altitude jumping that crazy, WOW. My altitude-reading is more or less completely stable.
Old Mar 15, 2012, 11:52 AM
HOL is offline
HOL
Find More Posts by HOL
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
Cool video, vasago17...
HOL is offline Find More Posts by HOL
Old Mar 15, 2012, 01:41 PM
vasago17 is offline
Joined Apr 2008
Thanks guys
As for the GPS drift, I was able to fix it a little bit by setting my set home delay to 100. This gives the GPS a little longer to find more satellites before setting my home position. I should point out that my unit of measurement on the DIY OSD is in feet, not meters...so my GPS drifts about 10 meters.
The shade canopy I flew through in the video is about 10' wide and my wingspan is about 6'. Luckily I made it through the first time! It's only foam, right? The fly through is at about 6:25 in the video.
Old Mar 16, 2012, 01:19 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Similair project to your Dennis - http://www.rcgroups.com/forums/showt...6#post21010334
Maybe I could take some code from there...I like your data layout way better, but I would like that artificial horizon,..would you help me implement it into your code for our hardware?
He is reading data over the serial port from MultiWii...I'm planning to use Multiwii for flight stabilization..
msev is offline Find More Posts by msev
Old Mar 16, 2012, 01:29 PM
Just another user
Joined Feb 2011
I don't mind to help and answer questions, but at the moment I don't develope much on the OSD. If I continue to work on the OSD, it will probably be integration with OpenLRS multirotor receiver.
At the moment I work a bit on antenna measurements and spectrum scanning etc. instead
Made this yesterday, almost have a working test-version
http://www.rcgroups.com/forums/showa...=4711182&stc=1
Old Mar 16, 2012, 01:42 PM
msev is offline
Joined Sep 2010
Nice gui!
Old Mar 16, 2012, 03:22 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Looking forward to that: RX, MultiWii and OSD all-in-one.
CheckSum is offline Find More Posts by CheckSum
Old Mar 16, 2012, 03:34 PM
Just another user
Joined Feb 2011
Nice gui!
Very simple so far, but it should be an easy and cheap way to use an OpenLRS receiver as a descent spectrum analyzer
So do I
I have ordered a barometric pressure sensor and will try to write some altitude-hold.
Old Mar 16, 2012, 03:51 PM
msev is offline
Joined Sep 2010
So do I ...Altitude hold for planes? I assume you bought the bmp085...Cool
Old Mar 16, 2012, 03:53 PM
Joined Aug 2009
I just had a look at the schematic and the firmware should load on Dennis' design with the LM1881. I will give it a test later today.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
