Old Mar 09, 2012, 11:26 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Dennis,
Based upon your experince with writing the overlay routine, do you think it is possible to modify this TV out Library to function as Overlay?
http://code.google.com/p/arduino-tvout/
rimshotcopter is online now Find More Posts by rimshotcopter
Old Mar 10, 2012, 03:54 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by rimshotcopter View Post
Dennis,
You probably have to take a closer look at the code, to get an idea of the changes needed. But yes, it should be possible. It looks pretty nice.
If I start to work on OpenLRS and SimpleOSD merging, I might change/update the OSD output section.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Mar 10, 2012, 07:22 AM
Joined Aug 2009
Thank you Dennis.
Old Mar 10, 2012, 07:43 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Dennis what about that question of mine about connections?
msev is offline Find More Posts by msev
Old Mar 10, 2012, 07:46 AM
Just another user
Joined Feb 2011
Originally Posted by msev View Post
I started to assemble it on the breadboard.
I need a little help, on my dealextreme arduino nano there isn't vcc written...So is the vcc pin the same as 5V pin on my nano? And is Vin the same as raw pin on pro mini?
And I also have two grounds (GND) written, one is on the side where A1-A7 are written, and the other is on the side that D2-D12 are written...So which ground is the correct one ? Please see attached pics.
Do I connect to the same ground as power and video ground also the gps module ground? Or to the different ground?
Yes, I think Vcc = 5 volt input and Vin = Raw. But better check the datasheet or schematic to be sure.
The 2 ground are the same, it doesn't matter which pin you use. Same goes for video/GPS/camera etc - same ground.
Old Mar 10, 2012, 03:26 PM
vipix is offline
Find More Posts by vipix
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
New WMC copter controler have GPS possibility.
Because i have using yours OSD, i want to ask if it is possible to connect this OSD as slave to I2C and provide all info for another arduino?
By now is required seperate arduino to make Serial GPS work with WMC I2C ports. I want to make simplier and use your OSD to display info and use as RTH in WMC.
Thanks for answer.
Edit: this is seperate arduino code to get GPS to I2C.
http://code.google.com/p/i2c-gps-nav...2C_GPS_NAV.ino
And there WMC part: http://code.google.com/p/i2c-gps-nav...e-snipplet.txt
vipix is offline Find More Posts by vipix
Old Mar 10, 2012, 03:38 PM
Just another user
Joined Feb 2011
Thanks for answer.
To be honest, I don't know. The timing is pretty critical and you don't have much cpu-time left. You probably have to do a test. Just be aware, that you can't use interrupts (you might be able to use interrupt if you use LM1881. Please see interrupt-priority in datasheet).
I working on a few other projects at the moment, so haven't done much with the OSD lately. I just use it :P
Old Mar 10, 2012, 07:35 PM
Joined Aug 2009
Dennis, just wanted to say thank you again for your work on this fantastic OSD. I did my first ground recording (No Virtual Glasses). I now need to test for distant and check for noise. I am using one battery source and will try using a separate battery for the OSD tomorrow, hopefully that will improve picture quality.
http://www.youtube.com/watch?v=mZ9aFY-yPHc
Old Mar 10, 2012, 07:52 PM
Just another user
Joined Feb 2011
Great to see some video, thanks
Can I ask what you have connected as GPS? It doesn't really update, and the values seems to be off quite a bit.
Old Mar 10, 2012, 07:56 PM
Joined Aug 2009
I am using some 4800 baud GPS, not sure of the brand. I remove a chunk of the code that sets the values to zero and home in order to make room for some things I want to add. The Values do update, not sure why they are not in this video.
Old Mar 11, 2012, 10:12 PM
Joined Aug 2009
I have a question please, with the aircraft stationary, how much drift or variants in the altitude reading is possible? I know my GPS is cheap, but I will like to know what you are getting.
Thank you.
Old Mar 12, 2012, 03:15 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Thank you.
10 meters and more is normal. Thats why some autopilotes have a pressure sensor on board.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 12, 2012, 05:24 AM
Just another user
Joined Feb 2011
The GPS altitude is not very accurate. It helps a lot to wait for extra satellites, but normally I don't really care if it shows +/- 10 meters or more. I just wanna know if I'm at ~500 meters or ~1000 meters
Just quickly had a look at my ground-recordings, this is the difference:
- 3.8 meters
- 2 meters
0 meters
-0.1 meters
- 6 meters
I have also had a couple being way off as home position was sat very quickly with few satellites.
Old Mar 12, 2012, 08:05 AM
Joined Aug 2009
Thank you Guys.
Old Mar 12, 2012, 10:06 AM
Henry. is offline
Find More Posts by Henry.
Chilled and served
Henry.'s Avatar
Sweden
Joined Mar 2005
I just saw on the picture on the OSD on the first page that there was a number right above the mAh reading, what does that show?
Would the Arduino be able to keep up if the GPS update rate was set to 10Hz and maybe also increased the baudrate a little? 10Hz is most likely more then normally needed but just in case i might need it some day.
And btw would also the update rate of everything else be at this speed then or is it only the GPS part?
I have ordered a small neat PA6B GPS some week ago and hoped it would work but i think i read here sometime that the GPS programming part pretty much had been made for this? Just want this confirmed so i know that this GPS would work right away.
The resistor divider for the battery voltage, for whatever the battery you hook up so should this net be calculated so it would always put out a voltage between 0-5V no matter the battery input voltage? And i know you will have to check any regulators so they could cope with the voltage you put on them if higher then normal.
Henry. is offline Find More Posts by Henry.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
