Old Feb 02, 2012, 05:01 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
When talking about ubec's how critical is it if the ubec does not provide exactly 5V to the gps and arduino, for example this one http://www.hobbyking.com/hobbyking/s...V_5A_UBEC.html (as told in the reviews) provides 5,5V, is that 0,5V going to ruin the gps?
This one is also a bit too high: http://www.hobbyking.com/hobbyking/s...23v_Input.html
I'm looking at the ones that are currently in stock now...If someone from EU has one that is more accurate spare I would buy one (can paypal the needed amount).
msev is offline Find More Posts by msev
Old Feb 02, 2012, 05:06 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
This is why I oped for the voltage regulator on board verse using a UBEC. Would have like to have used a switching regulator but I used what I had on-hand.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Feb 02, 2012, 05:07 PM
msev is offline
Joined Sep 2010
Which one did you buy? I think Dennis is using a ubec without problems, but I just wanna know if I should wait for that 3A ubec the most popular one, if that one is more accurate?
Old Feb 02, 2012, 05:12 PM
Joined Aug 2009
I am using a LM7805 regulator that I built. I have not flown or had any problems with anything at this point, just over designing.
When powering the Arduino ProMini with 6 or higher volts to the RAW Pin, the 5 volts out is regulated. So if the circuity is powered from the 5 volt pin of the ProMini, there should not be a problem.
Old Feb 02, 2012, 05:22 PM
msev is offline
Joined Sep 2010
So can you feed the power to the gps maybe from the arduino? ubec->arduino->gps?
Old Feb 02, 2012, 05:28 PM
Joined Aug 2009
That would depend upon the current requirement of the GPS unit. The Specs for the ProMini doesn't really state how much current it can supply for powering external devices but I would ASSUME 200ma would be OK. Don't hold me to this please.
Old Feb 02, 2012, 05:32 PM
Joined Aug 2009
P.S. BUT you have to make sure the voltage to the RAW pin remains above 6 volts, they suggest 7 in the specs. I have set the UBEC to six volts and never had a problem that way.
Old Feb 02, 2012, 05:35 PM
msev is offline
Joined Sep 2010
there isn`t a 7V ubec...thanks for the answers anyway, gotta wait on how Dennis has the power made before proceeding...i have every other part except power for it
Old Feb 02, 2012, 05:41 PM
Joined Aug 2009
You can also connect the RAW Pin directly to the battery.
Old Feb 02, 2012, 05:56 PM
msev is offline
Joined Sep 2010
I need 3S on the plane for the vtx...thats gonna probably be too high...about your voltage regulator is that just mounting that "chip" on a pcb or did you have to add some additional components.
Old Feb 02, 2012, 06:30 PM
Joined Aug 2009
I posted pictures here: http://www.rcgroups.com/forums/showp...postcount=1282
The specs for the ProMini states 5-12 volts and you maybe right, I have seen some 3S Lipos run close to 13 volts fully charged.
Old Feb 02, 2012, 07:16 PM
vasago17 is offline
Find More Posts by vasago17
United States, ID, Fruitland
Joined Apr 2008
The Arduino Pro Mini from Sparkfun.com uses a Micrel MIC5205 voltage regulator.
The schematic for the Pro Mini is here: http://dlnmh9ip6v2uc.cloudfront.net/...o-Mini-v12.pdf
and the datasheet for the MIC5205 is here: http://www.micrel.com/_PDF/mic5205.pdf
The MIC5205 can source up to 150mA and has a normal operating input of +2.5 to +16v.
I think Arduino states max of 12v just to be on the safe side but the absolute maximum input for the MIC5205 is +20v. Other Arduino boards may use a different voltage regulator as well so that may explain the difference.
vasago17 is offline Find More Posts by vasago17
Old Feb 02, 2012, 07:20 PM
Joined Aug 2009
Thanks for sharing that information, very good indeed.
Old Feb 02, 2012, 07:26 PM
vasago17 is offline
Joined Apr 2008
No problem
Here's a link to the Sparkfun.com Pro Mini page: http://www.sparkfun.com/products/9218
and I was looking at the link to the Arduino page you referenced above. It does look like there are some differences between Sparkfun's and the official Arduino.
Sparkfun's uses a 328 chip and Arduino's uses a 168 Atmel. As far as I know, this only affects the amount of program memory and what not.
Also, Arduino's schematic, here: http://arduino.cc/en/uploads/Main/Ar...-schematic.pdf
doesn't list the actual part number for the voltage regulator...so if you're using Sparkfun's, you can rest assured that it's 150mA and up to +16v but if you bought your Pro Mini elsewhere, you might want to read the part number on the board you have and try to find the datasheet.
Old Feb 02, 2012, 07:27 PM
Joined Aug 2009
Agreed.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
