Old Oct 26, 2011, 08:10 PM
Team White Llama
Enthlapy's Avatar
United States, IL, Addison
Joined Dec 2010
Enthlapy is offline Find More Posts by Enthlapy
Old Oct 26, 2011, 08:12 PM
Team White Llama
Enthlapy's Avatar
Joined Dec 2010
Originally Posted by Dennis Frie View Post
Sorry to hear about the current sensor, but hopefully the new one will be plug-n-play
Remember voltage-divider if you want to read battery-voltage.
Yea hope so too. Im actually reading on how to calculate it. Also talked to MrFliBoy on his setup.
Old Oct 26, 2011, 08:17 PM
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Thanks for the schematic
A voltage-divider can simply be calculated by:
R2 / (R2+R1)
If you use 3S lipo something like 1:3 should do it. I would go with 1:4
R1 = 6K
R2 = 2K
That will give you 0.25 times the actual voltage.
(picture from wikipedia)
Dennis Frie is online now Find More Posts by Dennis Frie
Old Oct 26, 2011, 08:22 PM
Team White Llama
Enthlapy's Avatar
Joined Dec 2010
I think this is a stupid question, but in the code:
// Arduino
#if (controller == 0)
// Input from current-sensor and voltage-divider
#define voltage_divider_input 1
#define current_sensor_input 3
1 = A1
2 = A2
3 = A3
4 = A4
5 = A5
Example " #define voltage_divider_input 1" with voltage divider connected to A1 on the Pro Mini?
Old Oct 26, 2011, 08:25 PM
Team White Llama
Enthlapy's Avatar
Joined Dec 2010
R2 / (R2+R1)
R1 = 6K
R2 = 2K
LOL thats where i was looking too! There is also a good video on YouTube:
Voltage divider tutorial (3 min 53 sec)
Looks like i got alot to read during winter. I'm also gonna get the SparkFun's beginer Arduino kit.
Old Oct 26, 2011, 08:27 PM
Just another user
Joined Feb 2011
1 = A1
2 = A2
3 = A3
4 = A4
5 = A5
Exactly, you just write the pin-number you wanna use
And yes;
0 = A0
1 = A1
... and so on
Old Oct 26, 2011, 08:28 PM
Team White Llama
Enthlapy's Avatar
Joined Dec 2010
And yes;
0 = A0
1 = A1
... and so on
Fantastic! Thank you!
Old Oct 26, 2011, 10:09 PM
Yhdysvallat, CA, Irvine
Joined Nov 2007
I might be wrong, but you seem to be using the wrong pins. It uses the analog comparator, so you should use pin 6 and 7 for video and reference voltage as shown in the schematic:
As far as I can see you have connected the video-signal to the normal ADC input (named pin A0, A1, A2 etc).
Also, please see first 10 lines in the code for pin's:
// Notes on DIY hardware pins:;
// pin 6 = PD6 / AIN0 (Reference voltage)
// Pin 7 = PD7 / AIN1 (Video)
// Pin 11 = MOSI (SPI) used for pixel-generation.
// Pin 8 = Dimming (Optional)
// Pin 9 = Fast PWM (Optional)
Can I ask why you have used A0 and A1? If it's an error in a schematic I would like to fix it
Thank
It works now !!!
Next thing is to connect the GPS
p3jpaavi is offline Find More Posts by p3jpaavi
Old Oct 27, 2011, 12:10 AM
Team White Llama
Enthlapy's Avatar
Joined Dec 2010
Originally Posted by p3jpaavi View Post
Thank
It works now !!!
PIC's or it didnt happen! Nah j/k. Glad to hear you got it. What GPS you gonna use?
Old Oct 27, 2011, 12:13 AM
Joined Nov 2007
I will put some pics tomorrow. I use this gps http://www.flytron.com/osd-headtrack...ps-module.html. Somehow I cant get to work with the OSD. The gps is working fine 9600 with anothet script. Any ideas what might be wrong ?
You connect the gps to RXI and TXO pins ?
Old Oct 27, 2011, 05:04 AM
Just another user
Joined Feb 2011
I use the exact same GPS, and the code have more or less been written with that GPS as reference. It should definitely work.
You just connect ground and 5 volt to GPS.
And connect like this:
GPS TX -> Arduino RX
GPS RX -> Arduino TX
Old Oct 27, 2011, 03:13 PM
Joined Nov 2007
Does the GPS rx need also be connected ? Or is it anought that the Tx is only connected ?
Old Oct 27, 2011, 04:02 PM
Just another user
Joined Feb 2011
Only if you need to config the GPS. I use it (included in the code) to automatic set update-rate and NMEA-string settings everytime it start up.
Old Oct 27, 2011, 08:02 PM
Joined Nov 2007
Wohoo everything is working now !
Next step is to solder a board and mount it to the plane
Old Oct 27, 2011, 08:07 PM
Just another user
Joined Feb 2011
That's great
You might want to add the dimming-resistor as well. The dimming makes it a lot easier to read the text on a bright sky etc. You can always turn it off in the software if you don't like it.
Discussion Diy osd karl k Video Piloting (FPV/RPV) 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 Video Piloting (FPV/RPV) 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca Video Piloting (FPV/RPV) 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak Video Piloting (FPV/RPV) 6 Jan 31, 2008 07:47 AM
