Old Oct 09, 2011, 09:23 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
I can see that quite a few comments etc. is not updated very well
I will try to go over the code and update a bit
Dennis Frie is offline Find More Posts by Dennis Frie
Old Oct 09, 2011, 10:19 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
Originally Posted by Dennis Frie View Post
Chances are you just ruined the rest of my spare-time
No, it would be fun, it have quite a few possibilities.
OpenLRS is a very nice initiative, and it should give a lot of opportunities. I have considered to make a cheap IMU with gyro and accelerometer from nunchok and wiimotion plus. Could make an interesting and pretty cheap receiver and autopilot based on OpenLRS.
I just tested your gps code with OpenLRS. I used your arrow variable as a rudder control and GPS emulator of Happykillmore. Results was very funny, the servo following the home direction now
I will release a new firmware with RTH(return to home) function in this week
If you dont have spare time for osd integration dont worry, i can help about that.
Thank you very much.
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Oct 09, 2011, 10:48 AM
Just another user
Joined Feb 2011
Melih
I should have plenty of spare time to play with this and make some integration
Can I ask how you have made RTH at the moment? I was thinking about 3 axis gyro + accelerometer, a descent kalman-filter and a PI or PID regulator to control the servos.
Old Oct 09, 2011, 11:31 AM
carlonb is offline
Find More Posts by carlonb
Italia, Lombardia, Milano
Joined Jun 2010
Hi Dennis and Melih, go on with improvements
Now, after some troubles with very strong light loosing text sinc I solved, was my mistake with R3, I used 10K instead of 100K.
For all interested I upload this oscilloscope traces that I used to debug my hardware.
Bye, Carlo
carlonb is offline Find More Posts by carlonb
Old Oct 09, 2011, 12:21 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
About a suitable cheap acc, these two come in mind (successfully used in multiwii project) - http://www.ebay.com/itm/Arduino-MMA7...-/250888793245
and
bma020 - reselled from kinderkram on rcgroups..
For a gyro an original or suitable clone wm+..
msev is offline Find More Posts by msev
Old Oct 09, 2011, 12:41 PM
MelihK is offline
MelihK's Avatar
Joined May 2008
Basic RTH functions using only throttle, elevator and rudder. Stabilization/autopilot is an extra feature and not the part of RTH. you dont need a stabilizer for self-stabilized planes or you can use thermopile or imu based stabilizers for acrobatics.
For a real autopilot, You need gyro+accelerometer for stabilization and a magnetometer for flight direction. I'm strongly suggesting RazorIMU codes.
Site Sponsor
Old Oct 09, 2011, 12:45 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
and
IMO, that Accelerometer is analog and would require three of the Analog ports on the Arduino, the MMA7455 is just as cheap if not cheaper on ebay and is I2C. Alex has written code for the Multiwiicopter to access the I2C bus interrupt free. I believe this would be a better way to go. The Great thing about the MMA7455, the calibration only requires recording the offset and to write this offset to a reg upon boot up.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Oct 09, 2011, 12:51 PM
msev is offline
Joined Sep 2010
Maybe I wrote the wrong number ...I meant that one that Rich uses...yes, the 7455.. Thanks for the correction.. Best thing is its really cheap .
Old Oct 09, 2011, 05:10 PM
Just another user
Joined Feb 2011
Bye, Carlo
Good to hear you found the error
A scope is a great help, it have helped me a lot.
No for a self-stabilized plane you should be able to to make RTH based on GPS, but it will need a pretty good trimmed plane and good conditions. RazorIMU is just the hardware sold by sparkfun, right? Using cheap sensors like those found in wii-remotes etc. would be a lot cheaper.
Old Oct 09, 2011, 05:13 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
I too thing that wii sensors are the way to go. Look at wii-copter it is a opensource project and it flies beautiful.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Oct 09, 2011, 05:17 PM
Just another user
Joined Feb 2011
And a little update. I'm done for today, so I will just put it up as a beta. I haven't tested much.
I also tested a menu which seems to work fine. Unfortunately I just made it quick - so it takes up quite a lot of space.
An early test done with 10 ohm dimming-resistor. The sync-detector doesn't really like it
Only to show the idea
http://vimeo.com/30280532
pass: osd
This have been updated:
  • Test-menu (for simpleOSD or extra button on Arduino. For now, only saved on volatile memory (fixed, will be included later))
  • US units (Please note, altitude offset must be 1 to show altitude in feet as well)
  • Dimming removed from top-characters when not active (Speed, LOS and altitude)
  • Version-number added on boot-up
  • Plane-position added as an option (will show in degrees) - Please note, not completely verified
Edit; The file is > 100 kb, so I had to rename it .doc. Just change that
Settings are now saved on permanent none volatile memory, so settings can be saved.
Old Oct 10, 2011, 02:10 AM
SouthPawPaul is offline
Find More Posts by SouthPawPaul
Electronics slayer
SouthPawPaul's Avatar
Reading, UK
Joined Jul 2008
Dennis is it worthwhile now that there are multiple versions in setting up a google code project and using that for the code repository?
Just an idea.
SouthPawPaul is offline Find More Posts by SouthPawPaul
Old Oct 10, 2011, 03:16 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
I'm not talking about hardware, you can make your own hardware with wii or other sources. But razorIMU's soruce code is ver good example about EULER Angle calculations. including matrix based calculation codes. Just replace the analog gyro and adc values with your digital ones
PS: i'm agree with SouthPawPaul, you must set up a google code page for this project
Site Sponsor
Old Oct 10, 2011, 06:31 AM
Just another user
Joined Feb 2011
Just an idea.
Year, guess I should consider to put it on google code projects sooner or later
But you should always be able to find the newest completed version in post #1.
Now that makes more sense. I will have a look at the code later
P.s. A few changes have been made from diy osd software 15 beta - so you might wanna wait for the completed version. Hopefully I can upload tonight or tomorrow.
Settings can now be saved in none volatile memory and most things can be configured from the menu
Old Oct 10, 2011, 03:06 PM
android78 is offline
Find More Posts by android78
Australia
Joined Mar 2010
But you should always be able to find the newest completed version in post #1...
From a coding perspective, I think it would be good to break the code into several files to make it easier to maintain as the project becomes larger too. For instance, it would be good to have a separate file for the sensors, one for the display, etc. This way, people with different sensors know that they can mess with the one file without messing up the display module.
The overhead with doing this shouldn't be too much, and it would make it much more readable.
Just my personal opinion though.
android78 is offline Find More Posts by android78
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
