Old Sep 24, 2011, 09:53 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Originally Posted by msev View Post
Anybody tried the gps on this site: http://ohararp.com/products.html
10Hz refresh rate for 25$ not bad ..
You can always get one from DIY Drones for $35 with the breakout board and cable.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Sep 25, 2011, 06:30 AM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
looks like this osd suffers from the same problem than simpleOSD XL
characters are always dancing, never rock solid like they are for example on DragonOSD or RVOSD....
no way to make them stable?
wallaguest1 is offline Find More Posts by wallaguest1
Old Sep 25, 2011, 08:38 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
In my limited experimentation, that dancing is caused but voltage variances and heat from the components. I think what is needed is really good voltage regulator at the 5 volt input to the circuit.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Sep 25, 2011, 09:15 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Have you tried the hardware/schematic in this thread?
You should be able to get very solid characters. With the DIY hardware I have been able to get perfect sync.
I will maybe upload a video later with a better recorder.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Sep 25, 2011, 09:18 AM
Just another user
Joined Feb 2011
The supply-voltage shouldn't have any major influence on the sync-detection. The reference-voltage is generated by a diode with the same voltage-drop independent of the input voltage.
Old Sep 25, 2011, 09:24 AM
Joined Aug 2009
Interesting, reason I say this is, I have built two now and there is a huge difference in the lettering quality depending upon the power source. The newest build, I am using a 5 volt source from duemilanove and getting near perfect video snyc however, it will deteriorate (not much) over time.
I will attempt to do a time-lapse recording today however, even with the minor deterioration, I am a very HAPPY CAMPER.
Old Sep 25, 2011, 09:37 AM
mrfliboy is online now
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
QuadGPS.mp4 (3 min 45 sec)
Skip to 2:00 for the good stuff. Still using the 38400 gps. No dancing here. My groundstation is inside with omni antenna only.
mrfliboy is online now Find More Posts by mrfliboy
Old Sep 25, 2011, 11:21 AM
Joined Nov 2006
mrfliboy thats what you call a "no dancing" osd ? it never stop dance to my eyes.
Old Sep 25, 2011, 12:26 PM
Joined Jan 2007
It's most likely the fact that he's transmitting on a wireless video transmitter that's making it "dance," not the OSD itself. That you can't do much about.
Old Sep 25, 2011, 12:51 PM
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Yes thats the wireless link, not the osd itself. The OSD is very solid IMO
Old Sep 26, 2011, 08:58 AM
alex57russ is offline
Find More Posts by alex57russ
alex57russ's Avatar
Россия, Москва, город Москва
Joined Sep 2011
Originally Posted by Sleurhutje View Post
Starting to build mine tonight. Got all the big parts, the small parts are somewhere around. Using a Arduino Mini v4 instead of a Pro but it's also 16MHz, only 16kB of memory but that should do fine (does it?).
Only have to find my compiler.
Hello, Sleurhutje
It was possible to you to make teamwork GPS em-411 and arduino?
Question for all:
With the help of what program to stitch Arduino (.txt a file)?
I have program AVR studio or Algorithm builder, it works with .hex a file
alex57russ is offline Find More Posts by alex57russ
Old Sep 26, 2011, 09:08 AM
AuzzeMit is offline
Find More Posts by AuzzeMit
Joined Jan 2010
HI..
I wonder if diy-OSD could be used for a ROV ???
AuzzeMit
AuzzeMit is offline Find More Posts by AuzzeMit
Old Sep 26, 2011, 03:02 PM
carlonb is offline
Find More Posts by carlonb
Italia, Lombardia, Milano
Joined Jun 2010
Hi Dennis,
I've built the Diy osd with your original diagram and is working well but not yet tested in flight, I will test soon, BTW i'd like to built also an OSD using LM1881 changing some pins in the sketch.
My question is VSYN out and SYN out how are connected to Int0 and Int1 pins ?
I want see the difference using arduino voltage comparator or using synchro separator with LM1881.
carlonb is offline Find More Posts by carlonb
Old Sep 26, 2011, 03:15 PM
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
[QUOTE=alex57russ;19424495
Question for all:
I have program AVR studio or Algorithm builder, it works with .hex a file[/QUOTE]
http://arduino.cc/en/Main/Software
and change the ext. from .txt to .pde
Old Sep 26, 2011, 05:42 PM
Just another user
Joined Feb 2011
When I get time I will upload a clip as well, my new video-grabber is a lot better than my previously USB grabber. It should show pretty solid characters
Originally Posted by AuzzeMit View Post
HI..
AuzzeMit
The OSD doesn't really care if you mount it in a sub, a car or a plane (as long as you keep it dry )
But it will probably be difficult to find a GPS working under water. Also, the heading is calculated from the movement, so you have to move a couple of km/h to get a good reading.
Originally Posted by carlonb View Post
Hi Dennis,
When using LM1881 you just have to choose the controller SimpleOSD OPEN. Only difference is the use of the LM1881 synch detector. Atmega 328p only supports interrupts on digital pin 2 and 3 - so you will have to use these pins.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
