Old Jul 21, 2011, 12:39 AM
shimniok is offline
Find More Posts by shimniok
mostly newbie
shimniok's Avatar
United States, CO, Centennial
Joined May 2011
Wow that is nice work!! Thanks for posting this and sharing the info/code/schematics!
shimniok is offline Find More Posts by shimniok
Old Jul 21, 2011, 05:49 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
I don't expect anyone have used the code yet, but;
Please be aware - in code version 0.01 "mahtemp" is defined as an integer (16 bit) and not a long (32 bit). When the total mAh consumed exceeds 3276.7 mAh it will give overflow. This will cause the 17. bit to be written "somewhere". In most cases nothing will happen - but it's not a good idea to write bits at random addresses.
Updated code will follow after further testing.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jul 21, 2011, 06:21 AM
evvaldis is offline
Find More Posts by evvaldis
evvaldis's Avatar
Lithuania
Joined Jan 2007
Nice. Will try to build it soon.
evvaldis is offline Find More Posts by evvaldis
Old Jul 21, 2011, 09:07 AM
Just another user
Joined Feb 2011
Anyone who have used the Allegro current sensors (ACS755)?
it seem to have about 600 mv offset - and until 5-10 amps load it stays at 600 mv. Any good ideas? Hopefully it's the last thing that needs to be fixed before I can make the final installation in my plane.
It's all connected and works fine so far - except for the current sensing.
EDIT; Tested and calibrated on breadboard - works fine. Will do another test in plane later
Old Jul 21, 2011, 11:27 AM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Congratulations on a successful and quick build!
Very cool, thank you.
CheckSum is offline Find More Posts by CheckSum
Old Jul 21, 2011, 01:39 PM
Just another user
Joined Feb 2011
Found the problem with the current-sensor. This is what the output signal looks like. That will make the micro-controller will read more or less random values.
A descent lowpass-filter or some extra capacitors in front of the ESC should do the trick.
Old Jul 21, 2011, 02:27 PM
flipflap is online now
Find More Posts by flipflap
Joined Mar 2009
Notice that this part is no longer in production. From datasheet, it has good linearity (2.8% over full range), and 60mV/A sensitivity.
The datasheet gives an offset of 600mV as you've measured. You have to substract it. So for example 600mV is 0A, and 600mV+60mV = 1A, 600mV+120mV=2A etc.
There is also 68 mV noise, but it should be easily reduced with some filtering.
flipflap is online now Find More Posts by flipflap
Old Jul 21, 2011, 02:37 PM
Just another user
Joined Feb 2011
Year, the 600 mv offset is no problem at all - the problem was, that it couldn't measure 0-6 A. The capacitor removed the ripple from the ESC, but the current sensor wasn't too happy about the large capacitance. A normal lowpass-filter with a low capacitance works better .
Old Jul 21, 2011, 03:57 PM
vipix is offline
Find More Posts by vipix
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
Maybe later arduino autopilot?
vipix is offline Find More Posts by vipix
Old Jul 21, 2011, 04:18 PM
Enthlapy is offline
Find More Posts by Enthlapy
Team White Llama
Enthlapy's Avatar
United States, IL, Addison
Joined Dec 2010
I <3 you, was going to do the same. Subscribed!
Enthlapy is offline Find More Posts by Enthlapy
Old Jul 21, 2011, 05:44 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Dennis,
In your schematic, what values for R1 and C1 ? as I don't see it anywhere else in the thread.
See, I am paying attention
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Jul 21, 2011, 07:22 PM
Just another user
Joined Feb 2011
I will maybe make an autopilot later, but I don't plan to do anything official, as projects like ardupilot etc. is probably a better choice if you just want to use a finish code.
Originally Posted by Devonboy View Post
Dennis,
Nigel.
Please play a bit with the circuit yourself. You might want to take a look here aswell;
http://www.viennawireless.org/balloo...rlay/index.php
But i strongly recommend to use a pot as voltage-divider.
If I make another one I will consider a diode with a little higher voltage drop and much lower R2 value. Might also add the capacitor as well.
R2 is 220 ohm (Written in schematic, but not very clearly). The value is not very important, you can try a few different and pick the value/brightness you prefere.
C1 is 0.1 uF, but other values should work fine. I actually tried something like 25 uF capacitor which worked without problems (but not recommended )
Old Jul 22, 2011, 03:56 AM
Devonboy is offline
SW England
Joined Aug 2009
Ok, thanks.
I was asking about R1 (not R2 as it is defined in your schematic) but from your link I see 680k is suggested for R1 and I know I have a 1M pot in my parts bin...
Nigel.
Old Jul 22, 2011, 04:13 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
This would be also a compatible board right: http://www.seeedstudio.com/depot/see...?cPath=132_133
msev is offline Find More Posts by msev
Old Jul 22, 2011, 06:15 AM
Just another user
Joined Feb 2011
Ok, thanks.
Nigel.
arh sorry. I have used a 50K pot. 1M pot should work, but it will probably be more sensitive to RF-noise etc.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 01:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 01:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 02:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 07:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 08:47 AM
