Old Sep 20, 2011, 10:39 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Drawing a line
Dennis,
Please I hope you don't mind discussing your code and techniques here. I see how you are defining the progression bar (loadbar), are the numbers here ASCII code? I wish to be able to draw a simple line but I am not sure how this is done. I understand how you are loading the buffers, I just don't understand how the image is created.
Code:
unsigned char loadbar[]={29,27,27,27,27,27,27,27,27,28};
Edited: I got it now, those numbers are pointers to a bit map.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Sep 20, 2011, 11:48 PM
android78 is offline
Find More Posts by android78
Australia
Joined Mar 2010
Originally Posted by ferdous7466 View Post
This diy kit is available anywhere yet? I'd like to get one. Anyone can provide? I do not have required stores in here.
I'd search ebay... All parts are readily available, I think.
android78 is offline Find More Posts by android78
Old Sep 21, 2011, 05:22 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
Hi Guys,
SimpleOSD OPEN in Stocks!!!
Today we finished the production of first 20 units of SimpleOSD OPEN boards.
The Boards looking same with our SimpleOSD XL but have some differences;
- 16Mhz Crystal
- 5V 16Mhz Arduino 328 Pro Mini Boot
- Green Status LED (it is RED on XL version)
I will share the circuit schematic soon.
Product Link:
http://store.flytron.com/osd-headtra...uino-boot.html
Cheers
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Sep 21, 2011, 06:49 AM
galaeta is offline
Find More Posts by galaeta
galaeta's Avatar
Joined Dec 2005
Originally Posted by MelihK View Post
Hi Guys,
- 16Mhz Crystal
Product Link:
Cheers
Melih
Great Melih! I was looking foward for it.
meanwhile, how about the available ports?
Cheers, Enrico.
galaeta is offline Find More Posts by galaeta
Old Sep 21, 2011, 07:59 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Hi Enrico,
It's including
- 2x current sensor input (direct analog input)
- 2x voltage input (one from supply battery and another for external battery) divider is 1/11
- 1x serial in/out for GPS or telemetry
- 1x PWM Audio output with capacitor isolation
- 2x standard in-out
- 2x Analog input (RSSI and AN marked)
Voltage regulator handling GPS and OSD for 2-4S batteries.
Cheers
Melih
Site Sponsor
Old Sep 21, 2011, 09:19 AM
galaeta is offline
galaeta's Avatar
Joined Dec 2005
Hi Enrico,
It's including
Cheers
Melih
Thank you Melih. I think SimpleOSD OPEN will be a standard like Arduino way.
i'm following close your web site.
Cheers, Enrico.
Old Sep 21, 2011, 10:03 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
No there are not any kits etc. available, but as it can be made with just "standard components", you should be able to get the parts in more or less all electronic-shops (except the Arduino board).
You should be able to get all parts from for example Sparkfun, Ebay etc. A cheap Arduino can be found on dealextreme (linked earlier in this thread).
Originally Posted by rimshotcopter View Post
Dennis,
Code:
You are more than welcome to ask about and discuss the code. I'm not exactly a software engineer, so I'm sure quite a few things could have been done smarter
Hi Guys,
- 16Mhz Crystal
Product Link:
Cheers
Melih
What can I say, sweet
Dennis Frie is offline Find More Posts by Dennis Frie
Old Sep 21, 2011, 10:22 AM
Joined Aug 2009
Well, you are doing one heck of a job there Dennis, very Inspiring as well.
Old Sep 21, 2011, 02:56 PM
thnilsen is offline
Find More Posts by thnilsen
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
Hi Enrico,
It's including
Cheers
Melih
I've been looking for an OSD which we could use together with a Quad based on flyduino or similar arduino boards. Since most quads already have GPS/IMUs it would be very cool if we could just feed the data from the quad board to be displayed on the OSD, rather than having to rely on a second GPS etc attached to the OSD.
The Flyduino has a few serial ports which can be used for this. I was going to try and get a MAX7456 chip hooked up to it via a Serial -> Arduino Nano -> SPI, since the MAX chip require SPI - and the flyduino board currently doesn't expose those pins. However, if the OPEN board can be used with a serial in I might just go down that route instead and try to make some OSD code for the MegaPirate quad software.
Thomas
thnilsen is offline Find More Posts by thnilsen
Old Sep 21, 2011, 03:16 PM
Funky Diver is offline
Find More Posts by Funky Diver
Look Sideways at Polarisation
Funky Diver's Avatar
United Kingdom, England, Darlington
Joined Jun 2011
Thomas
And you could incorporate some code for one of these for real time HFC (Height From Crash :P) http://www.sparkfun.com/products/8959
Funky Diver is offline Find More Posts by Funky Diver
Old Sep 21, 2011, 03:28 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
MegaPirate/Multiwii already support a few ultrasonic range finders - "HFC" - sensors so it shouldn't be difficult to get the data relayed to the OSD. Although these sensors doesn't help much once you're more than a few meters above ground.
- Thomas
Old Sep 21, 2011, 03:38 PM
Just another user
Joined Feb 2011
Thomas
It should be pretty easy to send the necessary info over serial and just change the serial-reading on the DIY OSD to accept a single string containing all the necessary info from flyduino or whatever
Old Sep 21, 2011, 05:05 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
I have placed an order for the SimpleOSD OPEN to have a a play with. Hopefully we can make something useful out of it for the Megapirate code.
- Thomas
Old Sep 21, 2011, 06:12 PM
Joined Jun 2011
- Thomas
True enough Thomas, although personally I wouldn't be so much bothered about how far away from the ground I was in FPV mode, more how close I was to crashing, lol.
Old Sep 21, 2011, 06:39 PM
Joined Aug 2009
Makes me think about the old Lunar Landing game.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
