Old Apr 11, 2014, 01:32 AM
ATARI-2600 is offline
Find More Posts by ATARI-2600
Heli-Maniac :P
ATARI-2600's Avatar
São Paulo - Brasil
Joined Aug 2004
Originally Posted by schugabe View Post
I added this offset to my version: https://github.com/schugabe/DIY-OSD
In config.h the UTC_OFFSET must be set accordingly e.g. -3
I did not test it on my osd so maybe it isn't working correctly
I will try
ATARI-2600 is offline Find More Posts by ATARI-2600
Old Apr 19, 2014, 02:39 PM
bparini is offline
Find More Posts by bparini
bparini's Avatar
Paraguay, Central, Lambare
Joined Mar 2013
Hi schugabe,
Lipo bat: 8,23V
Between the current sensor IN and GND: 8,23V
current_cal= 0.49
Regards,
Bruno.
First step is to measure the voltage with the multimeter between the current sensor input and gnd.
What is the value of current_cal?
bparini is offline Find More Posts by bparini
Old Apr 20, 2014, 01:56 AM
Heli-Maniac :P
ATARI-2600's Avatar
São Paulo - Brasil
Joined Aug 2004
any possibility to anyone mix these 2 projects?
Diy OSD + naza adapter
its a perfect project
Old Apr 22, 2014, 04:44 AM
schugabe is offline
Find More Posts by schugabe
Joined Jul 2011
Originally Posted by bparini View Post
Hi schugabe,
Lipo bat: 8,23V
current_cal= 0.49
Regards,
Bruno.
This makes no sense? The current sensor delivers a signal in the range 0V-5V. Are you sure you measured the correct output?
schugabe is offline Find More Posts by schugabe
Old Apr 22, 2014, 11:15 AM
bparini is offline
bparini's Avatar
Joined Mar 2013
Hi schugabe;
You say between current sensor IN and GND?
I put my multimeter in the Voltage IN and GND like the picture attached. Obviously give the same voltage as the battery.
Apparently I understood your instructions wrong. They want to measure between "Signal" and "GND"?
Regards,
Bruno.
Old Apr 22, 2014, 11:21 AM
schugabe is offline
Joined Jul 2011
I meant to measure this:
Old Apr 22, 2014, 09:32 PM
bparini is offline
bparini's Avatar
Joined Mar 2013
Hi schugabe,
With motor speed at 100% and 3.0A my multimeter reading 0,327 V
Regards,
Bruno.
Old Apr 25, 2014, 03:43 AM
schugabe is offline
Joined Jul 2011
To summarize the situation:
At full throttle the multimeter measures a current of 3A and the voltage between the signal and gnd is 0,327 V.
This sounds good... the value 0,327V is the correct value for 3A current. Please set current_cal to 1 and report back what values are shown in the OSD at full throttle.
Old May 04, 2014, 02:30 PM
kize37 is offline
Find More Posts by kize37
Ohio
Joined Apr 2009
Flytron Current Sensor Readings
Using a Arduino 328 and taking the voltage out on current sensor to power Arduino with 5 volt regulator.
I'm just using a 3 cell lipo to test osd with no load on the current sensor and I'm getting 49 amps displayed.
I set the current_cal to .49 but having trouble figuring out the offset. I measured 4.3 volts dc on the current sensor signal out. If I take the current sensor signal out of the circuit (pin A2) it displays the battery voltage 12.3v.
Any help would be greatly appreciated.
kize37 is offline Find More Posts by kize37
Old May 04, 2014, 05:59 PM
kize37 is offline
Ohio
Joined Apr 2009
Got it working.
Old May 27, 2014, 11:10 AM
GPeti is offline
Find More Posts by GPeti
Joined Nov 2011
I start to write the diyosd for PIC32 microcontroller, use MPIDE which like Arduino but compile for PIC not AVR, PIC32 is 80MHz clock and 32 bit, content DMA, if succes maybe can develope a simple open source autopilot.
GPeti is offline Find More Posts by GPeti
Old Jun 12, 2014, 06:44 PM
novian89 is offline
Find More Posts by novian89
novian89
Indonesia, Jakarta
Joined Sep 2012
Originally Posted by Dennis Frie View Post
Better late than never....
Here goes...
The normal hardware version is more or less the same as earlier.
With my cheap china cam I had to use a diode with a little higher forward voltage drop, or increase R3 to get a stable sync.
More or less the same as here
http://www.viennawireless.org/balloo...rlay/index.php
  • R1 - Controls brightness of the text. Around 100 - 300 ohm recommended.
  • R2 - Control dimming. Feel free to try whatever resistor-value you like.
  • C1 - 0.1 uF is the standard value used to AC-couple video, but other values should work fine. I have even used sround 25 uF capacitor
  • R3 - a part of the climping circuit. Around 10K should do it.
  • R4 - The diode (in this case D5) will always have a voltage drop of 0.6-0.7 V. R4 is just used to limit the current flowing from VCC. Values from a few thousand ohms to 100K should work.
  • R5 pot is used as a simple voltage-divider. The value is not very critical, but I wouldn't recommend very large (1M) and very low (100 ohm).
In this version the fast PWM is used to generate the DC-voltage used for bias and reference voltage.
  • R4 and C2 is used as lowpass-filter.
Simple version - I wouldn't recommend it, but I think it's a cool way to do it
I have been able to get a good sync, but it's a bit easier and more precise with a pot.
- off cource you can change the circuit as you want. You can also use the pot as voltage-divider for the biasing voltage and leave reference voltage at ground etc. Do whatever you prefer.
If any hardware-guys can improve the circuit - go ahead
and wich port to conect gps ..? i have mtk gps with 10hz
thanks before
novian89 is offline Find More Posts by novian89
Old Jul 10, 2014, 02:10 PM
jabu32 is online now
Find More Posts by jabu32
Who put that tree there?!?!
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
can someone post a parts list and wiring diagram for this diy osd.
jabu32 is online now Find More Posts by jabu32
Old Aug 08, 2014, 01:30 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Subbed Dennis please clear your inbox.
flohio117 is offline Find More Posts by flohio117
Old Nov 22, 2014, 02:38 PM
reefrider is offline
Find More Posts by reefrider
Joined Feb 2011
Hi!,
Somone knows to change big numbers and put all small numbers?
i'd like to see all small characters on the simply osd x2 .
thanks!
reefrider is offline Find More Posts by reefrider
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
