Old Nov 12, 2013, 09:40 AM
CAYESA is offline
Find More Posts by CAYESA
Joined Dec 2009
Thanks, and about amperimeter?
CAYESA is offline Find More Posts by CAYESA
Old Nov 12, 2013, 02:36 PM
Cuchivasrt is offline
Find More Posts by Cuchivasrt
Uruguay, Canelones
Joined Nov 2013
I have a spy hawk, is there any way to record the data on the display of the OSD?
Cuchivasrt is offline Find More Posts by Cuchivasrt
Old Nov 13, 2013, 02:33 PM
mrmidi is offline
Find More Posts by mrmidi
Team WarpSquad
Joined Nov 2013
Video picture runs through
Hello,
I flashed E-OSD-GPS, but the picture on the monitor runs through (like it lost sync?)
Without E-OSD video comes in fine.
Previous E-OSD original SW was also fine.
I also tried inserting a capacitor in the video line after the camera but no luck.
The CL-OSD runs, LED slowly flashing, on the monitor I can see the OSD screen, picture just glitching through.
Setup: 420TVlines Hobbyking camera (PAL)
E-OSD flashed to latest CL-OSD GPS r111 (I tried original hex and my own compilation, removed //#define COLORSYSTEM_NTSC)
Monitor is Renkforce 9" T-900B.
Does somebody know what's the cause?
Regards,
Simon
mrmidi is offline Find More Posts by mrmidi
Old Nov 14, 2013, 03:10 AM
CAYESA is offline
Joined Dec 2009
I'm sorry, but this project would be good if it have good documentation. I've send emails to flytron to have support but no reply, 39 USD to the rubish
Old Nov 18, 2013, 04:51 AM
mattyttv is offline
Find More Posts by mattyttv
Joined Mar 2012
I agree - have spent days of my life on this all because the documents reflect the old version.
no info on rssi or black background for new version. I have cooked my unit trying to work it out.
thumbs down for me to
mattyttv is offline Find More Posts by mattyttv
Old Nov 18, 2013, 10:39 AM
schugabe is offline
Find More Posts by schugabe
Joined Jul 2011
What firmware did you flash exactly? The e osd is from hobbyking and there exists an open source firmware for the e osd but I have never heard that it is compatible with the diy osd.
schugabe is offline Find More Posts by schugabe
Old Nov 21, 2013, 03:23 PM
mrmidi is offline
Team WarpSquad
Joined Nov 2013
Hello schugabe,
sorry I googled into the wrong thread - I built the DIY OSD and works fine! Thank you, Dennis!
I used ATmega328 (non "P"), flashed the Arduino-Bootloader and copied the fuse settings from the makefile. All this is included in the Arduino-Download. Programmer-Tool is AVR Dragon @ISP.
Then I connected the FTDI-Dongle (from HK) and used Arduino to compile and flash the DIY OSD "sketch". The rest was simple bread board work.
GPS works, the MT3329 even locks onto Sats indoors!
I still have to connect the current sensor and change the ratios in the config. Also the top lines have to move down a bit.
Old Nov 22, 2013, 03:46 AM
mrmidi is offline
Team WarpSquad
Joined Nov 2013
Just a simple question:
What is the number above mAh? On my screen it shows at the time of the photo "945". In the video from Dennis at the beginning of this thread it jumps quite randomly.
Greetings,
Simon
Old Nov 22, 2013, 03:51 AM
schugabe is offline
Joined Jul 2011
It can be configured to show the current mah/km or the rssi of the rx.
Old Nov 22, 2013, 05:32 AM
mrmidi is offline
Team WarpSquad
Joined Nov 2013
Ok, in config.h is show_rssi 0 and show_mah_km 1, thank you!
Old Nov 27, 2013, 09:28 AM
Uruguay, Canelones
Joined Nov 2013
Anyone know why my sensor reads 0 mah and 0 volt?.
something needs to change in the code?.
i'm using version 0_18
Old Nov 27, 2013, 09:33 AM
schugabe is offline
Joined Jul 2011
Post a wiring diagram+photos of your setup otherwise it is hard to guess what might be wrong
Old Nov 27, 2013, 10:19 AM
Uruguay, Canelones
Joined Nov 2013
This is the connection
Old Nov 28, 2013, 02:58 AM
schugabe is offline
Joined Jul 2011
you connected the rx to the current sensor? the current sensor should be connected to the esc directly and the rx must be connected to the esc.
you can check the current sensor itself by measuring with a dvm the voltage on the signal pin.
Old Nov 28, 2013, 07:12 AM
Uruguay, Canelones
Joined Nov 2013
Thanks schugabe for reply,
I check the voltage between ground and signal, is 0.01 V.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
