Old Mar 17, 2013, 12:34 PM
RFnoise is offline
Find More Posts by RFnoise
RFnoise's Avatar
Sweden
Joined Mar 2010
Originally Posted by MelihK View Post
Hi Carl,
Yes I did. But it is not an open product.
You can also do that with DIY-OSD, I can only show the way to you. Just download the ArduPilot project and isolate the altitude calculation code. Or maybe you can find BMP085 library with temperature compensated altitude calculation code on the net. Then you can integrate it into the DIYOSD code.
Sorry for this close code things but HobbyKing copying our all projects and we have to do this for surviving and supporting future projects
thank you for your understanding.
Melih
No problem! I support you! Thanks for pointing me at the right direction.
Regards,
Carl
RFnoise is offline Find More Posts by RFnoise
Old Mar 17, 2013, 04:00 PM
flipflap is offline
Find More Posts by flipflap
Joined Mar 2009
Here's some arduino code and detailed explanations on using bpm085 here :
http://www.sparkfun.com/tutorials/253
flipflap is offline Find More Posts by flipflap
Old Mar 17, 2013, 04:03 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Otherwise, feel free to copy-paste from the MAX7456 OSD project where BMP085 is implemented and OpenSource.
The altitude calculation is a linear approximation atm
Dennis Frie is online now Find More Posts by Dennis Frie
Old Mar 20, 2013, 05:36 AM
njosef is offline
Find More Posts by njosef
Joined Jun 2012
Hi i tried your scheme with arduino mega 2560, but there is mosi in pin 51 not 11, where i must make change in code ? i make change in pinMode(11,OUTPUT); to pinMode(51,OUTPUT); it's everything ? Thanks...
i tried non changed code, but display nothing show.
I tried now in this scheme
Thanks for any idea.
njosef is offline Find More Posts by njosef
Old Apr 10, 2013, 11:48 AM
njosef is offline
Joined Jun 2012
Ok, i tried on iduino nano http://www.ebay.com/itm/190746782529...84.m1439.l2649
but nothing show i tried turn slowly left or right with potenciometer but nothing happend.
Any idea ? Thanks for reply
I use version 0,18 without changes...
Old Apr 10, 2013, 12:09 PM
njosef is offline
Joined Jun 2012
Ok, now works. but no readable text same as this picture
i use 50k potenciometer(try 100k but nothing), diode 1N4148, i use scheme on page 1. firmware 0.18
Old Apr 12, 2013, 11:57 AM
sarky1 is offline
Find More Posts by sarky1
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
NOOOO, I bread boarded it. worked perfectly, made a protoboard to fit onto my mini pro and nothing haha, back to the drawing board.
Has anyone made a protoboard like the Denis did, if so is there any chance I can see your design? with some close up pics of the front and back ?
sarky1 is offline Find More Posts by sarky1
Old Apr 12, 2013, 09:40 PM
sarky1 is offline
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
Yew got it, now I need to work out powering a 3.3v gps, sigh!
Old Apr 18, 2013, 07:28 AM
emerge is offline
Find More Posts by emerge
Joined Oct 2010
I did not try again, but I just set up a new quadcopter and I really want an osd!! did you fix this?
I am going to rebuild the project again and use an oscilloscope to find out what's wrong..
emerge is offline Find More Posts by emerge
Old Apr 18, 2013, 09:56 AM
sarky1 is offline
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
Hey Emerge.
What Arduino are you using? I had a very similar issue with the UNO but got it working just fine with a Mini Pro
Old Apr 20, 2013, 05:02 AM
njosef is offline
Joined Jun 2012
no i havent time yet
Old Apr 25, 2013, 11:47 PM
mick3485 is offline
Find More Posts by mick3485
Joined Oct 2011
wow nice project! Just saw it!
I was wondering if it's possible to change the view with something similar at the image i posted..maybe modding the script of the ascii..
(only an example)
mick3485 is offline Find More Posts by mick3485
Old May 03, 2013, 10:06 AM
ironman139 is offline
Find More Posts by ironman139
Joined May 2013
Hello,
I know this project is old,
but is it possible to get the altitude by a BMP 085 Sensor instead of a GPS ?
I just need the alt for my OSD, nothing special.
-ironman
ironman139 is offline Find More Posts by ironman139
Old May 10, 2013, 09:31 AM
njosef is offline
Joined Jun 2012
I tried again and now working. But i dont know where was problem.
Old May 21, 2013, 12:05 PM
van-c is offline
Find More Posts by van-c
St. Pete, FL
Joined Feb 2006
The Arduino Micro is another very small board and is conveniently available at Radio Shack. I tried building the code for it, but for the Micro (essentially the same as the Leonardo) a number of constants used had to be changed because the Serial IO and timer are different from other boards. Also, the Micro has only about 28K available because the boot loader steals about 4K from flash memory and the compiled program is a bit too large to fit. (Maybe there are some tricks that can be done to reduce the memory taken up by the ASCII file.)
Has anybody else tried building this project for the Arduino Micro board?
--Van
van-c is offline Find More Posts by van-c
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
