Old Feb 15, 2013, 11:51 PM
daito is offline
Find More Posts by daito
United States, IL, Glenview
Joined Sep 2012
@kristaps_r
I am interested please let me know if you have one for sale.
Thx
Peter
daito is offline Find More Posts by daito
Old Feb 17, 2013, 04:20 AM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Originally Posted by daito View Post
@kristaps_r
Thx
Peter
I'll let you know but that would be at least after week or two. Have a lot to do on other projects.
kristaps_r is offline Find More Posts by kristaps_r
Old Feb 21, 2013, 10:28 PM
Piojo is online now
Find More Posts by Piojo
Newbie
Chile, Santiago Metropolitan Region, Stgo
Joined Apr 2011
Hi!
This is my 1st post on rcgroups, i try the code and works perfect.
A video of my first test using diy-osd:
First test of diy-osd from rcgroups (0 min 45 sec)
My next test must include: more light, a better camera, a more portatile tv, and then i try gps first and then current/voltage sensors.
Thanks a lot!!
regards from chile,
Piojo is online now Find More Posts by Piojo
Old Feb 22, 2013, 09:27 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
Hello Everyone,
A good news about SimpleOSD Open.
As you know, we didn't produce it since few months because of new design and production. My plan was making it smaller, lighter and cheaper
After few PCB design problem and reproduction now I did it.
This is new SimpleOSD X2
It is coming with useful features for opensource programmers.
And best news it is only 39.90$
The product page: http://www.flytron.com/osd-headtrack...l-edition.html
Schematic: http://www.flytron.com/pdf/SimpleOSD_X2.pdf
Features:
  • Working with both DIY-OSD(open source) and SimpleOSD XL(close code) firmwares. (compatible SimpleOSD XL firmware coming soon)
  • 16Mhz Atmega328 Processor with Arduino Boot
  • Standard 6 Pin FTDI Port for PC connection and other Serial sensors as GPS
  • 100% compatible with DIY-OSD Project.
  • I2C pins ready to solder for all sensors.
  • 4 extra Analog input pins
  • 6 extra Digital input/output pins
  • On-Board Voltage Sensor
  • One current sensor input
  • Simple 3 pin (video,+,-) connection to video system.
  • 5V regulated output for other sensors (120mA max)
  • Build-in LM1881 video signal seperator
  • PAL & NTSC compatible
  • Only 1.95gr
You can use a standard FTDI cable to programming it.
I just add some lines into the DIY-OSD 0.18 firmware for compatibility. You can download it from the attachments.
@Dennis:
You can track the differences into the code with "X2" keyword.
Can you update your original for the future updates?
Here is the list:
config.h
Replaced line
Code:
//Arduino = 0, SimpleOSD OPEN = 1, SimpleOSD X2 = 2
#define CONTROLLER 2
Added this line because of different dim, voltage and current pins
Code:
 // SimpleOSD XL OPEN 16 mhz
#elseif (CONTROLLER==1)
  // Input from current-sensor and voltage-divider
  #define voltage_divider_input 7
  #define current_sensor_input 4
#if (dim_on == 1)
// This is used for dimming. can be changed to another pin if you want.
 //define SimpleOSD OPEN's dim pin C5
 //SimpleOSD OPEN XL
 #define DimOn  DDRC |= 0b00100000;
 #define DimOff DDRC &= 0b11011111;
#else
  #define DimOn  DDRB |= 0b00000000;
  #define DimOff DDRB &= 0b11111111;
#endif
  #define little_delay _delay_loop_1(13);
 // SimpleOSD X2 16 mhz
#else
  #define voltage_divider_input 0
  #define current_sensor_input 1
#if (dim_on == 1)
 //define SimpleOSD X2's dim pin B1
  #define DimOn  DDRB |= 0b00000010;
  #define DimOff DDRB &= 0b11111101;
#else
#endif
#endif
Main Sketch
Replaced Line into SETUP section
//Define SimpleOSD X2 dim pin
#if (CONTROLLER == 2)
pinMode(9,OUTPUT);
#else
pinMode(9,INPUT);
#endif
Added into the SETUP section
// If SimpleOSD X2/LM1881
if (CONTROLLER ==2) {
attachInterrupt(0,detectline,FALLING);
attachInterrupt(1,detectframe,RISING);
pinMode(13,OUTPUT);
digitalWrite(13,HIGH); // Turn on the led
// Button with internal pull-up.
pinMode(6,INPUT);
digitalWrite(6,HIGH);
Please feel free to any question.
Cheers
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Feb 22, 2013, 09:35 AM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Hi Melih
It looks good
I've been busy with the MAX7456 OSD project lately and not been around much here (you have probably noticed, that I have bought a few GPS-units and current-sensors).
I will try to get some time and update the software sooner or later.
By the way, send you an e-mail long time ago regarding the MAX7456 version. You are also welcome to use that for anything you like.
Dennis Frie is online now Find More Posts by Dennis Frie
Old Feb 22, 2013, 09:58 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Hi Dennis,
Yes i noticed your GPS+Current sensor orders and I tried to making a surprise to you and put few units SimpleOSD X2 into your pack but didn't finish it in time :/ Anyway, now they are ready to shipping
Personally i don't like complicated electronics like MAX based OSD devices but of course i will glad to subscribe you.
Have you got any group for MAX based OSD project?
Site Sponsor
Old Feb 22, 2013, 10:38 AM
Just another user
Joined Feb 2011
Originally Posted by MelihK View Post
Hi Dennis,
I would have been a bit surprised, to see a "random" piece of electronic
The extra components needed on the MAX7456 version is not exactly an advantage, but the overlay looks better and there is a lot more processing-time left. But the simple design here is really nice.
I will test the OSD ASAP and report back and have an updated software-version compatible
Old Feb 24, 2013, 06:34 AM
emax is offline
Find More Posts by emax
emax's Avatar
Germany, HE, Darmstadt
Joined Feb 2013
Question: As I didn't find the word(s) "air-speed" in this thread, I wonder whether air-speed data (instead of GPS speed) can be processed or is on the todo list?
emax is offline Find More Posts by emax
Old Feb 26, 2013, 03:17 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Please, can some point me to a C Bitmap editor to create fonts and other items? I have Tobis ODS Charter Maker however, I would like to have something a little more robust.
Thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 07, 2013, 12:20 PM
loty is offline
Find More Posts by loty
Joined Jan 2013
Originally Posted by vipix View Post
New WMC copter controler have GPS possibility.
Because i have using yours OSD, i want to ask if it is possible to connect this OSD as slave to I2C and provide all info for another arduino?
By now is required seperate arduino to make Serial GPS work with WMC I2C ports. I want to make simplier and use your OSD to display info and use as RTH in WMC.
I know it's an old post but I just stumbled on it and realized that I'm working on exactly the same thing!!! Did you ever get it to work with second Arduino and GPS going to DIY OSD via I2C? For me RTH is a MUST and second Arduino running RTH autopilot is a perfect solution. BTW - I went with LM1881 setup for DIY OSD as it's much easier and better looking too. I cleaned DIY OSD code as well (fixed few bugs in the process too )
loty is offline Find More Posts by loty
Old Mar 13, 2013, 08:34 PM
alejoal07 is offline
Find More Posts by alejoal07
Joined May 2009
Technical question here... please help meee! I'm killing myself trying to figure out whats right...
You say there is a negative part in the pal signal, which is backed up here:
http://en.wikipedia.org/wiki/File:PAL_2_lines.png
But then this guy is generating PAL with just 0-1v:
http://www.rickard.gunee.com/project.../pic/howto.php
How does it work if the Sync level is suppossed to be -1.5v ?!?!?!?!
I'd really appreaciate it if you could help me... I live in a NTSC country but I'm thinking about developing a PAL OSD that's plug and play with Multiwii and can get the Gyro-Accel-Magnetometer-altimeter data straight through serial... Of course it would be open source
Any help appreciated! I need this confirmed so that I can start developing while the PAL gear I ordered is on its way.
alejoal07 is offline Find More Posts by alejoal07
Old Mar 14, 2013, 03:31 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
One OSD that takes serial data from MultiWii and draws AHI ... is called Mobidrone. It has same schematic as DIY OSD so nothing to invent, it is allready done and opensource: http://www.toptel.sk/multicopter/ind...&products_id=1
I think I saw also MinimODS code for MultiWii somewhere.
Old Mar 15, 2013, 05:30 AM
RFnoise is offline
Find More Posts by RFnoise
RFnoise's Avatar
Sweden
Joined Mar 2010
Hello all!
Have anyone of you added code for the BMP085 sensor in this project that we can use for accurate altitude? Yes I know that you Melih have done that..
Regards,
Carl
RFnoise is offline Find More Posts by RFnoise
Old Mar 15, 2013, 07:26 PM
PMB-NZ is offline
Find More Posts by PMB-NZ
PMB-NZ's Avatar
Wellington, New Zealand
Joined Aug 2009
If everything was ideal and it was all DC coupled, the video signal would go negative. Higher quality but it makes things a lot more complicated to keep all parts working and interconnectable.
The simple solution is to AC couple the video signal; which just means feeding it through a large value capacitor. This passes the high frequency video signal to the next stage but blocks DC. The signal reference level is shifted positive or set above 0V by the next stage . Now it can operate from a simple single supply.
There are some minor problems introduced by the AC coupling. Quality is reduced and the average DC level is all over the place, which can affect the ability of the next stage to lock onto and track the video signal when it's less than idea; which is often the case with FPV.
I had this problem a while back and added a DC correcting amplifier to the groughd station. This made previously crappy cameras look quite good.
Paul
PMB-NZ is offline Find More Posts by PMB-NZ
Old Mar 17, 2013, 08:45 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Originally Posted by RFnoise View Post
Hello all!
Regards,
Carl
Hi Carl,
Yes I did. But it is not an open product.
You can also do that with DIY-OSD, I can only show the way to you. Just download the ArduPilot project and isolate the altitude calculation code. Or maybe you can find BMP085 library with temperature compensated altitude calculation code on the net. Then you can integrate it into the DIYOSD code.
Sorry for this close code things but HobbyKing copying our all projects and we have to do this for surviving and supporting future projects
thank you for your understanding.
Melih
Site Sponsor
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 01:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 01:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 02:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 07:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 08:47 AM
