Old Jan 16, 2013, 01:06 PM
walkmanz is offline
Find More Posts by walkmanz
Latvia, Riga
Joined Jan 2012
I cann't get it to work with baud rate 115200. Is it even possible? I cann't change my baudrate because I need it to use with multiwii, my general purpose for this was to have one gps for multi wii and osd.. now it is not working with that rate.. :/
walkmanz is offline Find More Posts by walkmanz
Old Jan 16, 2013, 03:35 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
I'm not sure a baud rate of 115200 is possible. The serial data is read with polling and not interrupt. As the pixel-output will have highest priority (it's running in an interrupt), the data-transfer must be slow enough, to make sure no character is "missed". You can do a quick calculation, to see if itīs possible. Try to compare the "line-time" (the maximum length of the an interrupt) and the serial-speed. Just to get an idea
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jan 17, 2013, 11:14 AM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
I'm not so into the code, I'm not a programmer.. well with 38400 baud rate osd works but for multiwii I need 115200 baudrate.. maybe there is the way to read the serial data at 115200 baudrate and still do the pixel generation?
Old Jan 22, 2013, 03:04 PM
kristaps_r is offline
Find More Posts by kristaps_r
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Wanted to share my DIY OSD board with GPS, Current, V1, V2, and RSSI inputs
kristaps_r is offline Find More Posts by kristaps_r
Old Jan 22, 2013, 03:07 PM
sarky1 is offline
Find More Posts by sarky1
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
Please tell me your going to sell a few of these ??
sarky1 is offline Find More Posts by sarky1
Old Jan 22, 2013, 03:09 PM
Just another user
Joined Feb 2011
C'mon dude, you just keep making my builds look ugly as hell
On a more serious note - it's awesome to see the projects be used like that. Really nice and clean setup with a PCB.
Can't really say anything but great work
You should give the version with MAX7456 a shot if you solder PCB anyway
Old Jan 22, 2013, 03:16 PM
FPVdude is offline
Find More Posts by FPVdude
Joined Aug 2011
want that!
FPVdude is offline Find More Posts by FPVdude
Old Jan 22, 2013, 03:17 PM
sidneylopsides is offline
Find More Posts by sidneylopsides
Leeds, UK
Joined Dec 2003
That's awesome, hope to see some to buy!
sidneylopsides is offline Find More Posts by sidneylopsides
Old Jan 22, 2013, 03:18 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
I will ...
Old Jan 22, 2013, 03:21 PM
Just another user
Joined Feb 2011
I will ...
Sounds good
- and as always, feel free to sell whatever you want from all of these projects. They are uploaded with no strings attached at all.
Old Jan 22, 2013, 03:24 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
I was not going to sell them. I made this just because I wanted (liked). I don't have time even to test it.
I am also going to make one 25x25mm powered from RX 5v without USB with Bat, Current and RSSI inputs
When I will test them I will think about expenses and maybe sell some.
Old Jan 22, 2013, 03:29 PM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
Sounds good
Thanks You give me real inspiration Dennis. I have more ideas in my head but don't have as much time as I want.
Old Jan 23, 2013, 03:09 AM
kristaps_r's Avatar
Latvia, Riga
Joined May 2010
OK
I will solder some more of these after I will successfully test it. My friend also asked.
I summed components, board, soldering... and seems I could give away these for 29$ shipped worldwide with tracking. (I wish i could get components as cheap as Chinese and some Chinese to solder this )
If someone interested I will count people and solder that quantity.
Can't give any date but hope this would not take long (count people interested + order components + solder)
Please don't be angry if I will find out that something is not OK with resign. USB and OSD works fine, need to test all ADCs and serial port
Old Jan 28, 2013, 11:42 AM
sokoloko is offline
Find More Posts by sokoloko
Joined Mar 2008
hello,
I would like to join this thread and enjoy this great OSD, but my OSD does not work properly.
Attached pictures of my circuit, the only thing that shows the screen output is a snapshot that lasts a few milliseconds, and appears in different horizontal position every 10 or 15 seconds.
I've tried with the following changes in the code:
# define CONTROLLER 0 or 1
# define VIDEO_SYSTEM 0 or 1 (do not know the camera system as it is reused)
# define align_text_ 1 to 22 (I tested all intermediate values​​)
And the result is always the same. I can not find the error.
Thanks and sorry for my English
sokoloko is offline Find More Posts by sokoloko
Old Jan 30, 2013, 09:10 AM
sokoloko is offline
Joined Mar 2008
hello,
After many hours and testing, the result is that multiple cirtuitos not fail, but fails to VGA Adaptor AV:
http://www.ebay.es/itm/290694941022?...ht_4555wt_1397
Connecting the circuit to capture it works correctly.
Now the problem is that this model does not detect GPS:
http://www.ebay.es/itm/271079582518?...ht_1886wt_1163
I do not know how to set it from the code, and how they connect BACKUP and 1PPS signals.
Thank you.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
