Old Nov 20, 2012, 03:44 PM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
Dennis,
Got it !! The last schematic was it
Rick
RickEis is offline Find More Posts by RickEis
Old Nov 20, 2012, 03:48 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by RickEis View Post
Dennis,
Rick
Perfect
I'll later post a little more details etc. on the project - mind if I use your picture now that you have confirmed that it works?
Now, to get rid of the chinese-letters, in the main function you can find 3 if-sentences called
if (1==0) {
bla bla
If you first change the 2 first to 1==1 upload the code and wait 10-20 seconds (it will upload text-characters etc). Make them 1==0 again and then do it with the last one upload and set it to 1==0 again. Not user-friendly, but hey, you are using a pretty early version
Dennis Frie is online now Find More Posts by Dennis Frie
Old Nov 20, 2012, 03:49 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I can only dream at this point. Wow!
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 20, 2012, 04:18 PM
RickEis is offline
Joined Feb 2012
Originally Posted by Dennis Frie View Post
Perfect
if (1==0) {
bla bla
Dennis,
Of course you can use any of these pictures - I consider them more yours then mine anyway I could never have done this !! I'll keep updating the schematic as we add the components.
What do you mean, "you are using a pretty early version". If you are talking the MAX7456, it is new ! - just received it a few days ago for this project
Ya this Chinese letter thing is not too friendly - let me try and see if I can do it
I see you included a bunch of stuff for it in your download. We really need to make it easier for simple folks like me
Rick
Old Nov 20, 2012, 04:22 PM
Just another user
Joined Feb 2011
Dennis,
Rick
No worries, it's easier in the next version.
You don't need all the extra material I have included, all the characters, arrows etc. is already included in the code
By pretty early version I referred to the software-version
Old Nov 20, 2012, 04:54 PM
Just another user
Joined Feb 2011
Rick, you can upload this version.
It will automatic upload the characters for MAX7456. Just note that MAX7456 must be connected while you program the controller
https://dl.dropbox.com/u/3947315/MAX7456_OSD_2.rar
Old Nov 20, 2012, 05:08 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Looks sweet DF!
msev is offline Find More Posts by msev
Old Nov 20, 2012, 05:19 PM
Just another user
Joined Feb 2011
Originally Posted by msev View Post
Looks sweet DF!
Thanks. I just measured the weight, its around 6 gram atm. Not bad at all.
Old Nov 20, 2012, 05:20 PM
RickEis is offline
Joined Feb 2012
Dennis,
Easy enough!!! (see pict ! )
This was with the old version and your instructions -
I'll try your new version in a bit .
Rick
Old Nov 20, 2012, 05:24 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Haha, great!
The new version just does it all automatic first time it boots.
There is also a lot of minor changes, but it looks the same
Old Nov 20, 2012, 05:49 PM
RickEis is offline
Joined Feb 2012
Just checked schematic..
http://arduino.cc/en/uploads/Main/Ar...-schematic.pdf
The pro mini schematic don't use the same pinout.. Explains the problem.
I think your Uno is a better candidate.
We need this to work with the Pro Mini also - You thinking it won't ?
I can't figure the pins - guess I need to study them a bit more ?
For example
GPS -> Arduino UNO
GND - > GND
5 V - > 5 V
IN - > PD1 (??)
OUT - > PD0 (??)
Rick
Old Nov 20, 2012, 06:06 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
GPS -> Arduino
GND - > GND
5 V - > 5 V
IN - > TX
OUT - > RX
Note that in some designs the TX and RX may need to be reversed.
Legot is offline Find More Posts by Legot
Old Nov 20, 2012, 08:08 PM
Snaydher is offline
Find More Posts by Snaydher
Goi‚nia - Brasil
Joined Jan 2009
Does SimpleOSD Open works with ArduCam Configurator OSD? Can i load minimOSD firmware on it?
Snaydher is offline Find More Posts by Snaydher
Old Nov 20, 2012, 10:14 PM
RickEis is offline
Joined Feb 2012
Dennis,
V2 compiles first time with both mini pro and uno and looks excellent as in the pict I posted previously
I'm assuming V2 loaded the English text with the mini pro because I had only done it manually with the Uno - so I think it worked perfectly
When I input video, it threw the text around (see Pict).
- problem maybe ntsc verses pal?
Also I hooked gps-out to rx0 uno and gps-in to tx1 uno and "still waiting"
I believe the baud rate for my gps is 38400 - change the 9600 in config.h
//#define BAUD 9600
#define BAUD 38400
not sure if that was the right place to change things ?
Tried mini pro again - tried to read Arduino Mini Pro schematic -
(hard to understand for me
UNO -> MINI PRO
cs=pb2=pin 10 -> pin 12 ?
sdin=pb3=pin 11 -> pin 11 ?
sclk=pb5=pin 13 -> pin 9 ?
sdout=pb4 =pin 12 -> pin 10 ?
Didn't work - gray screen
// General configuration
#define VideoSignalType_PAL
//#define VideoSignalType_NTSC
// Unit system
#define UnitSystem METRIC
///#define UnitSystem IMPERIAL
// gps baud rate
Rick
Old Nov 21, 2012, 01:27 AM
RickEis is offline
Joined Feb 2012
Dennis,
Is this looking correct for the UNO ?
I have a hayday reading these arduino schematics
Probably because I never have
Rick
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
