Old Nov 18, 2012, 11:38 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by RickEis View Post
Well, I have looked at the schematic and code at the bottom of Sparkfuns page but it appears I am missing some knowledge on connecting it and getting the code to compile with the arduino - So I am looking for some help Have you got something that works with the arduino and sparkfuns board?
I looked also and was disappointment. My Bad.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 18, 2012, 11:42 AM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
That Ok rimshotcopter
So can you show a schematic and write a code that will compile and make my screen say "hello world" ?
RickEis is offline Find More Posts by RickEis
Old Nov 18, 2012, 11:44 AM
Joined Aug 2009
Sorry I do not have one but here is another ODS with open source code: http://code.google.com/p/rushduino-osd/
Old Nov 18, 2012, 01:32 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Sorry, but I don't have a simple code available - only the mess I'm working on
Dennis Frie is offline Find More Posts by Dennis Frie
Old Nov 18, 2012, 03:23 PM
Just another user
Joined Feb 2011
narh, what the heck.. For those of you who want to have a look, feel free. But please be aware that it's in no way meant as a release-version
It should by no mean be used as a fully working version (though it most likely does work flawless ).
A few notes on schematic...
- MAX7456 crystal must be 27 MHz,
- C5 and C6 must be 47 uF
- Crystal-caps depends on the crystal.
- RSSI, current-sensor and RX+TX series resistor is just "random value" to get the footprint.
- Decoupling capacitors on Vcc (buttom right) is just to get the footprint for PCB-design. I will use what I have around and find suitable.
R5 and R6 should be 75 ohm resistors (video-impedance). I just put 82 ohm as the 75-ohm value wasn't in my library.
A few notes on firmware
- Very early version not tested very well.
LOS limit moved to around 50 kilometers
LOS will change from meters to km when above 10 km
UART uses interrupt for best performance.
Serial.print can't be used
Only ~30% memory used so far, plenty of space left.
If you have any questions or need help with the code, please wait until an actual release with a bit of explanation etc
https://dl.dropbox.com/u/3947315/MAX7456_OSD.rar
PCB-design etc. will most likely be available later.
The main firmware is pretty much done - so I'm open to ideas
Old Nov 18, 2012, 04:45 PM
RickEis is offline
Joined Feb 2012
Awesome work Dennis
Attached is a picture of the components which would be awesome to use if compatible with your program !
I'm hoping one of your (smarter then I) readers can use this image to sketch in the wires illustrating the connections, while you are continuing to polish your project.
Rick
Old Nov 18, 2012, 10:43 PM
RickEis is offline
Joined Feb 2012
Dennis,
Your program is the first larger program for this MAX7456 that compiled for me.... and I have tried a lot, attempting to get this up and running -
Looking forward to hooking it up soon
Rick
Old Nov 19, 2012, 01:33 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
I see code for artificial horizon, but see no hardware to support it?
And I'll repeat my self, add possibility to send data to the ground, please
dziedrius is offline Find More Posts by dziedrius
Old Nov 19, 2012, 01:52 AM
Just another user
Joined Feb 2011
The code for artificial horizon is not done at all. The rounding-errors should be fixed and tilt should be implemented with better resolution - but it's a start.
I will later add some gyro and accelerometer support and a little filter to keep it running smooth.
Sending data to the ground is not really an option with MAX7456. Using the audio-channel is a possibility, but as I use Lawmate, I don't really have good audio-channel to use.
Old Nov 19, 2012, 02:09 AM
Joined Jul 2008
Why it is not an option with MAX7456? At the moment I don't see how those two things correlate, I just thought that MAX7456 will offload main processor, so it will be easier to add.
Haven't checked, but I think MAX7456 does not support VBI, so there's no ability to send data through video channel also - and I guess that cheap EasyCap ripoffs will struggle with VBI decoding.
Old Nov 19, 2012, 04:23 AM
Just another user
Joined Feb 2011
MAX7456 is designed to overlay graphics in the video. When using a part of the video-signal to transmit data, it would be preferable to "hide the data". Sure, you can still use a microcontroller to output some data, but atm SPI is used by MAX7456, serial by GPS and I2C by extra sensors. Not saying it ain't possible, just not straight forward. As I personally don't use antenna-tracker etc. I don't care too much about extra downlink information. My videolink will provide the necessary information.
Old Nov 19, 2012, 05:14 AM
Just another user
Joined Feb 2011
Awesome work Dennis
Rick
Hook it up and let us know how it works
You should note that you will get some chinese-characters, until you load my character-set for MAX7456 (included in the code but out-commented as they only have to be uploaded once).
Connect it like this, upload the code and you should see the magic start . You don't need a camera connected, it will automatic generate sync-pulses etc. if no video-signal is present.
MAX7456 -> Arduino
CS - > PB2 (10)
SDIN - > PB3 (11)
SDOUT - > PB4 (12)
SCLK - > PB5 (13)
GND - > GND
5 V - > 5 V
Reset - > Vcc
- if anyone plan to actually test the software, please let us know how it works
Old Nov 19, 2012, 03:00 PM
RickEis is offline
Joined Feb 2012
Dennis,
Again, it all compiled first time !!!! - amazing job !!! You would not believe how many things I have tried that would not compile.
This evening, if all goes well, I plan to hook it up like this (see attached photo), unless I have something wrong ?
Rick
Old Nov 19, 2012, 03:10 PM
Just another user
Joined Feb 2011
Dennis,
Rick
Your drawing looks right - just remember to connect GPS TX and RX to RX and TX on Arduino to get data. The signal from the current-sensor should also be connected, but start with just Arduino and MAX7456 shield.
Old Nov 19, 2012, 08:35 PM
FPVdude is offline
Find More Posts by FPVdude
Joined Aug 2011
wow, that looks nice. Its been like 2 years since I first looked at this project, and I still haven't implemented this osd on my plane due to so many problems
FPVdude is offline Find More Posts by FPVdude
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 12:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 12:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 01:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 06:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 07:47 AM
