Old Nov 06, 2012, 03:47 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by bob4432 View Post
i would personally wait to see what dennis has been working on, but if you want to get started, check this link - http://www.rcgroups.com/forums/showp...postcount=1928
The MAX7456 project was just a quick idea, I haven't done much work but an initial test-code and first PCB-layout. Just show-off .
As you need a bit of experience to solder the components, it's not really an obvious DIY-project with the MAX7456. The work with MAX7456 have been done pretty quick and hard-coded, so I'm probably not gonna upload code etc. Already plenty of MAX7456 projects out there
Dennis Frie is offline Find More Posts by Dennis Frie
Old Nov 06, 2012, 03:53 AM
Just another user
Joined Feb 2011
you will never look at projects the same way - http://www.amazon.com/Updated-Aoyue-...rds=aoyue+968a
At the price it looks amazing. Have you tried that exact model yourself?
Old Nov 06, 2012, 05:32 AM
Just another user
Joined Feb 2011
Originally Posted by sarky1 View Post
Alright I'm stumped.
I connected this back up on my bread board and I can only get output if I short out the cap and disconnect the pot. Here are the pics, is anyone able to help??
What kind of cap have you used? And have you checked the potentiometer is right? If you remove the potentiometer, you dont have AIN0 connected?
Old Nov 06, 2012, 06:12 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ
Joined May 2010
Have one on the bench - works excellent. Everybody I know that has one loves theirs. Between that, cheap laser cut kapton stencils (or other type), hotplate or Toaster oven, oshpark.com for nicely Priced low qty high quality 2 or 4 layer 6/6 enig finished boards In a decent time you will be able to make so many projects that i would consider professional quality (especially for what we are Doing) your significant other will think you are cheating on them. .
Highly recommend!!
bob4432 is offline Find More Posts by bob4432
Old Nov 06, 2012, 06:20 AM
Just another user
Joined Feb 2011
Highly recommend!!
Have to check oshpark.com. Have used BatchPCB and Seeedstudio so far. But if OSH makes PCB's every 2. day it would be really nice
I have a lot of equipment available at work and the university (SMD rework, "owen" etc.), so could be an option. A lot can be done with a normal soldering-iron, but some reflow might be a good idea with the very small components.
Old Nov 06, 2012, 06:28 AM
Just another user
Joined Feb 2011
- and a few PCB's have been ordered from oshpark.
Old Nov 06, 2012, 10:29 AM
sarky1 is offline
Find More Posts by sarky1
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
The cap is a 0.1 uF are there different types as this one does look different to what I have seen in other peoples pictures.
Yes if I remove my pot Its the same as disconnecting Pin6 on my arduino which I thought was AIN0.
Looking at this maybe its actually pin7 that is AIN0 and pin8 that is AIN1.
http://arduino.cc/en/uploads/Main/Ar...-schematic.pdf
sarky1 is offline Find More Posts by sarky1
Old Nov 06, 2012, 10:30 AM
sarky1 is offline
sarky1's Avatar
Canada, BC, Langley
Joined Oct 2011
Just answered my own question. So I think its in the correct spot.
The pot is a 50k so that should be fine as far as I can tell
Old Nov 06, 2012, 01:43 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Highly recommend!!
Man I wish you were in Europe so I could send you some stuff to solder for me
msev is offline Find More Posts by msev
Old Nov 06, 2012, 06:49 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
That's what I have.
Nothing goes to the trash anymore. I bet you'll recognise this quote!
This weekend just repaired one ESC plush 6A by replacing the fets.
Btw is there any pcb layout available to send to some of those batch services?
I'd like to build one or two, I tried first using the perforated pcb's but it becomes a mess with wires/soldering and I'd
prefer to go SMD size.
One other alternative I was considering was to order a atmega328 to fit into a E-OSD and be able to load this code.
IceWind is offline Find More Posts by IceWind
Old Nov 06, 2012, 06:52 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
Do you have a link?
Here it's a MAX7456 that's mentioned
http://code.google.com/p/arducam-osd/wiki/minimosd
Opx sorry, It was a typo.
There is no such thing as a MAX7566.
Old Nov 07, 2012, 12:28 AM
RickEis is offline
Find More Posts by RickEis
United States, AZ, Prescott Valley
Joined Feb 2012
Connecting elements to the Diy Osd
Can someone point me to a schematic which shows connecting the Diy Osd to a GPS, current sensor, and maybe a atmospheric pressure sensor etc?
Thank you in advance,
Rick
RickEis is offline Find More Posts by RickEis
Old Nov 07, 2012, 01:04 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I would be interested in the same.
flyandi is offline Find More Posts by flyandi
Old Nov 07, 2012, 01:28 AM
bob4432 is offline
bob4432's Avatar
United States, AZ
Joined May 2010
I don't think I have seen one w/ a barometer as most use GPS altitude as it is accurate enough for this purpose. With baro it would need to be added to the code which would not be an issue, but then the mount of the unit would become very important since they are not only sensitive to pressure but light also.
Just look at how hard alt hold has been to implement in MW because of the mount issue and I am sure other FCs I am not familiar with
Old Nov 07, 2012, 06:56 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Hmmm i have being flying a homemade OSD no GPS but with barocensor for 6 years now, its is mounted in a black plastic box and works like a charm, i love the vario it give me in my glider, little bulky box and the hight is probatley a little off but the vario is somthing i dont want to fly without in my glider so no baro vario is a showstopper for me.
GPS flying hight is fine but for vario is not good.
Lars.
LKJ is offline Find More Posts by LKJ
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 01:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 01:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 02:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 07:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 08:47 AM
