Old Sep 24, 2012, 03:55 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
LM1881 works fine with both PAL and NTSC. The only difference is the number of lines - and LM1881 is just used to detect if it's a new line or frame.
The extra filter is optional. In most cases it shouldn't be necessary, but it removes some high-frequency noise. SimpleOSD doesn't use the extra filter and lot of people use that without problems.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Sep 24, 2012, 04:05 PM
walkmanz is offline
Find More Posts by walkmanz
Latvia, Riga
Joined Jan 2012
well then my last LM1881 scheme is correct? And for current sensor I'm looking for ACS758LCB-050U-PFF-T with some additinoal components from datasheet.. Will solder that up..
walkmanz is offline Find More Posts by walkmanz
Old Sep 24, 2012, 04:10 PM
Just another user
Joined Feb 2011
Yep, that should be right (just remeber C1, 100nF/0.1uF to make sure the signal is AC-coupled).
Remember not to add too much capacitance at the output of ACS758.
Old Sep 24, 2012, 04:23 PM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
I will do as in datasheet..
For Rf an Cf I will don't put in anything as I don't know what should I put there and it is optional.. Maybe you can suggest something.. I looked at ebay for ready these type sensors soldered up to pcb and there also is only one capacitor which is 100nF I guess..
Old Sep 24, 2012, 04:28 PM
Just another user
Joined Feb 2011
I will do as it is in datasheet..
But that's not gonna work very well
An ESC controls the speed etc. by closing an opening a couple of FET's very fast. That will give you peaks like those seen here:
(Please note, this is an actually measurement of the output from an Allegro current-sensor used in front of an ESC)
You just add the largest capacitance possible (see datasheet or my post a few days ago) - and a matching resistor. You can calculate a descent time-constant or just pick a good resistor-value.
This should give you a lot more stable readings. It will never be "true RMS" - but you should be fine
I don't recommend to use the current-sensor without filtering the output.
Old Sep 24, 2012, 04:35 PM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
I looked in datasheet and didn't find them but now I found.. R(LOAD MIN)4.7kOhm and C(LOAD MAX)10nF.. are these the right ones?
OK found your previous post also.. These are the right ones.. Thanks for helping me..
Old Sep 24, 2012, 04:53 PM
Just another user
Joined Feb 2011
Year, but you can ignore the R(load min) 4.7kOhm, as the input-impedance of the ADC on Atmega should be higher than that. 4.7kOhm prop works just fine, but you might wanna go a bit higher. The time-constant with 4.7kohm and 10nF is 47 us.
Old Sep 24, 2012, 05:06 PM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
Well that information is too complicated for me.. Which is the time-constant to reach for? I see that the formula is 4700 ohms * 0.01 uF? I should go for 10kohms? as result 100us (us is miliseconds?)? I don't know anything about this
Old Sep 24, 2012, 05:14 PM
Just another user
Joined Feb 2011
Just a quick graphical illustration.
Green is input-signal. The signal are all with 10nF cap, and the resistors are 4.7K, 10K and 100K. The 100K is just to show the effect.
The higher resistor-value, the more stable output. But too high resistor will give problems with noise and voltage-divider between the resistor and input-impedance.
10K resistor and 10nF should be a fine place to start. If you don't have stable current-readings, you can increase it.
Old Sep 25, 2012, 02:41 AM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
Hi.. I hope I understand correct..
Green is raw Vout from ACS758, with 4.7k and 10nF it gives blue line, with 10k and 10nF it gives red line and with 100k and 10nF it gives light blue line which is almost straight.. maybe I should use pot to change values from 10k up to value X which is stable..
Thanks for this great explanation and your work..
Old Sep 25, 2012, 02:46 AM
Just another user
Joined Feb 2011
You got it right. Don't "overthink it", but I would recommend at a filter.
In worst case, you will get a little unstable current-reading.
Old Sep 25, 2012, 03:40 AM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
Well I have really dumb questions I am looking for these resistors and in shop there are like 1/4W 1/2W 1W etc resistors.. Which ones should I choose, are there any diference? and also capacitors has some additional parameters as RM some has 2.54 and some 5.. Which ones are better?
Old Sep 25, 2012, 03:44 AM
Just another user
Joined Feb 2011
The power-rating doesn't matter in this case. Pick the cheapest, smallest, sexist or whatever you prefer
The capacitor is not critical either, a normal 10 nF ceramic should be fine.
Old Sep 25, 2012, 03:55 AM
walkmanz is offline
Latvia, Riga
Joined Jan 2012
And if there aren't exactly the same resistors and capacitors as needed then I can put resistors in series to mach the needed value and in paralel capacitors?
Old Sep 25, 2012, 06:22 AM
Just another user
Joined Feb 2011
That should do the trick
The resistor-value is not critical, just pick whatever you can get around the desired value. Same goes for the capacitor, except, don't use a capacitor-value above 10 nF.
Discussion Diy osd karl k FPV Talk 2 May 03, 2011 01:31 AM
Idea New DIY OSD? atari7202 FPV Talk 1 Mar 25, 2011 01:08 AM
Discussion see my own diy OSD video Passion Aerial Photography 7 May 27, 2010 02:28 AM
Discussion REAL homebrew DIY OSD - Check it out! jafoca FPV Talk 8 Jun 29, 2009 07:52 PM
Discussion picoOSD DIY PIC12F683 based OSD in C kbosak FPV Talk 6 Jan 31, 2008 08:47 AM
