Old Jul 18, 2011, 09:55 AM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Do you want to see how durable this plane is?
We were maiden flying a new 72" Hercules which has the 6" middle extension what we thought at first was a radio failure and it hit the ground hard enough to bounce 8 feet high. We were flying in 90 degree air temperature with about an 8 mile per hour wind out of the South. The plane flew well with C3530 KV 1700 motors even in the heat. The video shows gliding and multiple hand launches after the crash.
We later decided that the hot glue had softened because it was so hot that day and the horns had loosened in the elevons and the servos probably moved because they also were glued in with hot glue.
The plane was carrying four 4500 3S lipos weighing in over 3.5 lbs for a total of 18,000 mA of 3S power (yes eighteen thousand!!!!). The plane had a total weight of over 8+ lbs when it hit the ground. I do not know of any other plane of this size and weight that could have survived this kind of an accident with so little damage. All of the batteries and radio were undamaged even though the plane hit the ground so hard. This is the advantage of the EPP foam and a flying wing design.
The plane was heavy enough it sank so deep in the grass we had to hand launch it. We did not edit out any bad launches. I am pleased that this plane is stable at such a slow speed that it can be easily hand launched even at the amazing weight of 8 lbs. I also have a bad elbow that makes my being able to launch the plane even more impressive.
I was using some new speed controls and they didn't throttle up the same although they are the same brand and size. This gave us a good chance to test how the plane will fly with unequal thrust. The plane does not pull to the side or loose control even with one motor at half the thrust of the other due to the dual rudder design. I did not put music with this video because I want you to listen to the motors and hear how much different they are running.
Hercules 72 inch crash and unequal thrust 7-21-11 (5 min 20 sec)
This is for all of you who have forgotten how fragile most planes are.
Model airplane crashes (1 min 5 sec)
Lee is offline Find More Posts by Lee
Old Jul 18, 2011, 09:56 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
September 20, 2011
Today I went flying with the Hercules with the 6" extension and I set it up and flew it 4 different ways to test the CG. See the pictures below.
Total plane weight is 5.3 lbs without batteries or 84 oz.
Elevons are trimmed up about 1/4" for reflex
4X 4500 3S batteries ............ total battery weight 49 oz, RTF weight 133 oz, CG at 9.5
2X 4500 3S batteries ............ total battery weight 25 oz, RTF weight 109 oz
4x 1300 3S batteries ............ total battery weight 16 oz, RTF weight 100 oz
2x 1300 3S batteries ............ total battery weight 8 oz, RTF weight is 92 oz CG at 10.5
All flew well without modification with only slight amount of up trim adjustment as weight increased. The decreased weight did increase glide. The 2X 1300 3S batteries showed instability and didn't track or loop as well. The best flying was about 10" back.
How many planes do you know that can fly with 41 oz variation in batteries on board with out other modification and still fly well?
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Rocky's Super Build Videos
Rocky is a 17 year old customer who has been flying our Reaper FPV and is making videos to show how he is building his Hercules.
#1 Unpackaging the plane
#2 Gluing the cores together
#3 EPP Elevon covering
#4 Motor mount and spars.
#5 Motor mount, spars and shock cord
#6 Installing the Shock cord
#7 Mounting the GoPro
#8 Laminating
#9 Elevons and horns
#10 Servo installation
Thanks Rocky!!!
Lee
Old Jul 18, 2011, 09:57 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
The first video shows me flying limbo at a local fly in and the second video shows be trying to stall the plane with the plane flying slow in steep climb outs and hard turns.
#2 Hercules Limbo 9-11 (2 min 21 sec)
Hercules slow flight 7-11 (5 min 20 sec)
Old Jul 18, 2011, 09:58 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
2 elevons or 4 elevons....which is best????
GoPro with picture in a picture.
Hercules with GoPro and 2 elevons 9-11 (9 min 3 sec)
Hercules with traditional elevons 9-11 (4 min 37 sec)
GoPro action with a little aerobatics added in.
Hercules with GoPro and 2 elevons 9-11 (8 min 19 sec)
Old Jul 18, 2011, 09:59 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Reflex is a little up trimmed into the plane across the entire elevon. All flying wings have it and whether it is trimmed into the elevons or cut into the airfoil it is there.
Because the elevons on the Herc are so big it only needs a small amount of reflex. I think that most of the problems people have had are not enough reflex or too much movement in the elevons or reversed flying surfaces.
It took some pictures of the reflex trim on my 78' Herc from both the top and the bottom. Although the top is reflexed only about 1/8" we started to question if people are measuring from the bottom where the reflex is 1/4" to 3/8". If this is the case of the point of measurement it may confusing to some of the builders. Look at the pictures below.
All 3 of my Hercules at 66", 72" and 78 are flying great and balanced within 1/4" of 10" back from the nose of the plane. Notice the picture on the skid where I mark the 9.5" - 10" - 10.5" back from the nose to quickly check the CG.
I have only had one flight where the first Hercules prototype was tail heavy where my plane didn't fly well on the first flight. It didn't dive but looped back over my head. In fact on the last video of the 78" Hercules surfing in the wind, the plane had never been taken off or trimmed before the camera was running and the entire video was shot on the first set of batteries ever run though the plane.
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
looks very cool ! how much ?
i3dm is offline Find More Posts by i3dm
Old Jul 18, 2011, 10:00 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Reserved 8
Old Jul 18, 2011, 10:01 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Reserved 9
Old Jul 18, 2011, 10:02 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Reserved 10
Old Jul 18, 2011, 10:11 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Im gonna order one. Finally something that interests me enough to make me wanna throw out my EPP fpv.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Jul 18, 2011, 10:18 AM
viper6549 is offline
Find More Posts by viper6549
Bugs!!!!!!!
viper6549's Avatar
USA, OK, Wayne
Joined Sep 2009
Regards
Doug
Dito
viper6549 is offline Find More Posts by viper6549
Old Jul 18, 2011, 10:21 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Ok were can I get one ? And how much ?
hotdog1 is offline Find More Posts by hotdog1
Old Jul 18, 2011, 10:23 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Go to www.crashtesthobby.com for more information. Planes are in stock.
Old Jul 18, 2011, 02:54 PM
rcairnut is offline
Find More Posts by rcairnut
"Still Crashing since 1960"
rcairnut's Avatar
Pierre, SD, USA
Joined Dec 2001
I said I would not buy another one of Lees planes this summer, looks like I was wrong again
Good luck on the motors, I don't see any in stock at the moment. I will have to dig into my stash and see what else may work. (my motor stash of course!)
nut
rcairnut is offline Find More Posts by rcairnut
Sold Waco MOSQUITO 60" HGG**RELIST**New LOWER PRICE agarchitect Aircraft - Sailplanes (FS/W) 0 Jul 16, 2011 06:55 PM
