Joined Jun 2008
Hehe! Hey Integrity..I know how you love to hate Walkera..check this out
http://www.walkera.com/en1/particular.jsp?pn=X2 Although its been advertised for a while I don't think they've actually released it so you're safe! |
![]() ![]() ![]() ![]() Too bad they couldn't get rid of those bulky swash followers and implement some sort of DFC. |
This Walkera helicopter is actually based on the Sikorsky X-2. The supposedly fastest moving helicopter in the world, they claim. Piloted by a single pilot. Though i don't think it's acrobatic at all. Having a rear prop means they have not came close to the ability of the Kamov system. Though on the REAL scale model X-2 the tail rotor is not needed to fly forward, it's just for added speed. So the main rotor might be as good or better than the Kamov system. It's also probably not capable of loops and rolls. I really don't know. I would think this was designed to be a transport and recon helicopter. Not a combat heli. But i wouldn't doubt if walkera's model requires a rear prop to push it along all the time. Makes me wonder though. It's also probably not very fast. I would also wonder how well it actually handles wind. It does look like the Walkera X-2 might actually have a double swash plated main prop though. It might be a cool heli to have for $300 or something. But they will want much more. I know Walkera's scale models pretty well. I honestly think Walkera does better at scale models, if not overpriced, they are nice. They should just stop making "3d helicopters". At least the bigger sizes and make their Scale models affordable. I think they would have a big response. They just don't make the electronics good enough to handle 3D rigor. But on scale flight, it's not so bad. If they were affordable, i'm sure many people would like to have a 450 size airwolf or 200 size even. But not for the over $600 they were asking just for the 200 sizes.
You need a 24 volt supply to charge your 6 cell in series batteries, so either run two 12 volt batteries hooked in series, or when you can afford it, buy a 24 volt PSU.
The only other way I know of charging them is through the balance connector & you would need to make it selective so it only charges 3 cells at any one time, then connect to the other 3 cells after the first 3 are finished. Problem is the wires are too thin to take 4300 Mah, I think they are 26 Awg which is ok up to maybe 2 Amps. So, how were you charging them before with a 12 volt supply? Does your charger step up the voltage to 24 volts? It must be, I don't have my charger's documentation in front of me, but I am sure it says it will do a single 6 cell battery at a max of 50 Watts but it warns not to try & charge more than one battery at a time. If you took "VA" 12 volts X 4.4 Amps = 52.8 Watts but 24 volts X 4.4 Amps = 105.6 Watts So if you have a 200 Watt supply & are charging two 4400 Mah batteries in parallel that would max out your PSU @ 211.2 Watts I think.... Yeah it checked out the figures are correct, I would suggest charging two in parallel @ 2200 Mah & when it is finished charge them a 2nd time @ the same rate. Or charge one at a time, or a bigger PSU. |
United States, GA, Covington
Joined Mar 2011
how low can i go
i back!!!!!
the 450 is also getting lower!
Joined Jun 2011
I think I was barking in the dark Integrity, 400 Watts! Wow you shouldn't have that problem. I was also thinking that the PSU maybe 400 Watts (AC) not (DC) Look at your voltage chart on the PSU & see what it says for total Watts at 12 Volts DC, or total Amperage at that voltage.
You may be surprised, it might say it only puts out 10 Amps @ 12 Volts.... |
Joined Mar 2011
http://heli-heli.com/items/electroni...ger-detail.htm
It has beeen great , i have a 350watt. Power supply and if things get crazy i can get more power, but i believe its the last charger i will have to buy. It charges 2 6 cell 3300mah batteries in 20 minutes! Quote:
Like i said, i'd be happy at 1C. It would be nice if they made a higher wattage version of my charger because i often have to charge 1S, 2S, 3S and 6S packs all at the same time. The newest version of my charger is 400w instead of 200w. But i have no idea if it's able to charge 4A per port now or not. Having multiple ports is cheaper than multiple chargers when you need to charge 5-6 packs for all your helicopters, in different cell counts. It's just not working out for the 6S. So it looks like i'm stuck buying another charger. The thing that sucks is i don't have anyone i can ask about the functionality of the new version of my charger. The one you bought is too expensive. If i could afford $200 on anything right now it would be a BeastX for my V450, i think. I honestly don't want to para charge my 6S packs with a charger like that. Thats too dangerous after all the problems i've had doing it with 3S. These packs are too expensive to risk it. I've had 3S packs turn the battery leads bright red and melt the jacket and everything. If i didn't cut the power i might have had a burst lipo. I've also had my balance plugs on my para balancer boards melt out and short the charger plugs on the battery. Scary stuff when it happens to a $10-15 3S pack. But when it's a $50-100 6S pack, i just can't afford to risk that anymore. So i would probably only feel safe charging 1 pack at a time with your charger. Which probably still loads a pack faster than mine does at 0.5C
Joined Mar 2011
I wish my 3cell blue lipos would charge at a faster rate. But my 6 cells are ok. I pump 13 amps into 2 3300 mah.
| Thread Tools | |
| For Sale BNF T-Rex 500 ESP Mikado V-Bar | dawhale | Aircraft - Electric - Helis (FS/W) | 2 | Apr 11, 2011 04:16 PM |
| Sold CopterX 250SE NIB COMPLETE T-Rex 250 clone | The Nemesis | Aircraft - Electric - Helis (FS/W) | 0 | Apr 10, 2011 11:11 PM |
| Sold T-Rex 250 Clone W/Align Parts | Dingo7222 | Aircraft - Electric - Helis (FS/W) | 7 | Apr 07, 2011 08:08 PM |
| Sold Loaded T-rex 250 Clone (Perry) | Dingo7222 | Aircraft - Electric - Helis (FS/W) | 7 | Mar 11, 2011 04:21 PM |
| Sold Clone T-Rex 250 BNF W/AR6100E $150 | kevinlamrc | Aircraft - Electric - Helis (FS/W) | 8 | Mar 06, 2011 04:00 PM |
