Old Jul 19, 2011, 02:00 PM
lightningmcnul is offline
Find More Posts by lightningmcnul
USA, CA, Marina del Rey
Joined Jul 2010
I'm not sure how much extra cost goes into making these compared to the 70mm's, if you can avoid to obvious lure of upping the price because its bigger and keep them near your 70mm price then this could well be the best fan available,
congratulations!!
lightningmcnul is offline Find More Posts by lightningmcnul
Old Jul 19, 2011, 02:42 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Hi Gary,
I'm impressed with the power level of this fan!
You may serious reconsider the IGV concept for safety reasons. like this the rotor would always stay on the shaft.
These power levels are getting scary...
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jul 19, 2011, 03:20 PM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Scary indeed... How is the rotor held on the shaft?
Sure is impressive.
SilentHunter is offline Find More Posts by SilentHunter
Old Jul 19, 2011, 05:27 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by efflux RC View Post
Guys,
Immedeiatley after reading Jim's suggestion last night (thanks Jim ) for a guard in front of the rotor, I contacted Mach about providing such a device, as a solution.
It's currently being addressed, and I'll keep ya posted.
Originally Posted by Erik v. Schaik View Post
Hi Gary,
Hi Erik,
As you can see from my post above, There is nothing to reconsider.
The concern is being addressed, and we will present the solution shorlty.
SilentHunter,
The shaft adaptor is secured with a precision ground collet. (.0001" per side, runout max)
The rotor is secured with a hex nut, and a threaded spinner.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jul 19, 2011, 06:26 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Wow!
I missed this one, that is one impressive fan!
Crazy power
For safety I'd just forget the ground run up once I have my numbers at home and just taxi out and after the plane is past me drill the throttle
Would love to see a 120mm or a 80mm for Habus
very cool, love the sound too, it's almost turbine like
great work.... makes me want to come to big jolt
Ron101 is offline Find More Posts by Ron101
Old Jul 19, 2011, 07:12 PM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by Ron101 View Post
Wow!
Crazy power
Thanks Ron.
We have some DS-44 (85mm) coming for the Habu 32. (easy mod for the "can do" guys)
If you find yourself making it to the Big Jolt, come by our booth. We will have a 90mm ALL ALLOY EDF on display. It'd be a chance for us to meet as well.
Gary
Site Sponsor
Old Jul 19, 2011, 08:17 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
look at it...skip that....lets put it in my T45 and fly it at big jolt
corsair nut is offline Find More Posts by corsair nut
Old Jul 19, 2011, 08:51 PM
efflux RC's Avatar
Joined Aug 2009
I'd love to Brent, but the last time we did something similar, (70mm in the Viperjejet at Cal jets) the thread was muddied up by someone who had to make a fuss about it in the threads.
Site Sponsor
Old Jul 19, 2011, 09:57 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
well he's busy right now cause he flung some more mud
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jul 19, 2011, 10:22 PM
Bigells is offline
Find More Posts by Bigells
Bigells's Avatar
Phoenix AZ
Joined Mar 2003
Metal EDFs saftey by design and test
Some thoughts on addressing the safety issue of the metal EDFs:
Full size turbine engines are designed to address these particular failure conditions, which are, fan balde off and FWD bearing failure. If the rotor fails, a blade from the fan would usally separate from the hub. The fan case is designed to contain the blade and not let it pass through the case. The blade would be swallowed by the engine which then typically stops the engine quite quickly.
In the case of these metal EDF you can address these same issues in the design, to provide a higher level of safety. I realize that the design is done and it's into testing, so any suggestions may be to late.
The design of rotor attachment to the motor shaft should be such that if it fails, the rotor would be prevented from leaving the shroud either by a catcher mount, forward of the rotor or by having the rotor behind the electric motor.
In this case the rotor would be held from exiting the shroud by the motor and its mount. As an example, in model gas turbine engines, the centrifugal compressor (first one) is contained in the forward mount/case of the engine.
All the EDFs that I have seen, the attachment of the fans shaft to the motor is by a grub screw against the motor shaft. At these higher power levels this could be a point of failure. This could be better addressed by using a shear pin to attach the shaft to the rotor.
The rotor and the rotor shaft must be designed to withstand fatigue, crack growth and material creep from 38500 rpm over a specific period of time.
This is a brief high level overview of the design of the metal fans. The EDFs can be shown by design, analysis and test, to be safe for use in the hobby.
Bigells is offline Find More Posts by Bigells
Old Jul 19, 2011, 10:44 PM
efflux RC's Avatar
Joined Aug 2009
OOOh, I've seen it.
Site Sponsor
Old Jul 19, 2011, 10:48 PM
efflux RC's Avatar
Joined Aug 2009
[QUOTE=Bigells;18808863]
The design of rotor attachment to the motor shaft should be such that if it fails, the rotor would be prevented from leaving the shroud either by a catcher mount, forward of the rotor or ..............QUOTE]
Thanks for your comments Bigellis. a "catcher mount" as you describe it is in the design process.
Gary
Site Sponsor
Old Jul 19, 2011, 11:39 PM
Quixksilver is offline
Find More Posts by Quixksilver
Distributed Manufacturing
Quixksilver's Avatar
United States, NV, Reno
Joined Jun 2009
This is a master peace. The sound, oh the sweet sweet sound. I can't wait to own one in every EDF model I don't have yet
Keep up the good work, your really taking this part of the hobby to the leading edge of what can be done to date and then some.
Quixksilver is offline Find More Posts by Quixksilver
Old Jul 20, 2011, 12:44 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Sounds like I need to increase my life insurance, and buy one. Lee
capt soap is offline Find More Posts by capt soap
Old Jul 20, 2011, 01:57 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
great jet engine vids ....i wonder what they mean by a industrial engine???? what are they used for ? does any one have a clue. J-79's were awsome motors for sure.
New Product efflux RC...AMA approved - 70mm, ALL ALLOY EDF - 6.5 lbs peak thrust efflux RC Electric Ducted Fan Jet Talk 999 Apr 12, 2013 08:04 PM
Discussion Esprit Model’s new Flagship, Ventus 2cx, 6m (236”) 13.25kg (29.1 lbs) Esprit Model Electric Sailplanes 7 Jul 11, 2011 07:45 AM
Discussion EDF Test Data, Thrust, Efflux, Amps... Anything I am missing? jfetter Electric Ducted Fan Jet Talk 50 Apr 23, 2011 01:15 PM
Question 90mm edf with around 8 lbs of thrust john_53_70 Electric Ducted Fan Jet Talk 13 Jan 16, 2011 11:05 PM
Discussion How far can a cheap 90mm fan go? 12lbs thrust? 250mph efflux? Knife Liddle Electric Ducted Fan Jet Talk 2 Nov 06, 2010 10:48 PM
