Old Jul 18, 2011, 02:39 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
well i think some sort of guide vane/cage could be mounted to the front to hold the rotor in ...that easy .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jul 18, 2011, 03:31 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Safety Guard...
Guys,
Immedeiatley after reading Jim's suggestion last night (thanks Jim ) for a guard in front of the rotor, I contacted Mach about providing such a device, as a solution.
It's currently being addressed, and I'll keep ya posted.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jul 18, 2011, 05:40 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
it could be something as simple as an "X" made of aircraft cable, but if it were me and I had the means, I'de machine something that's aerodynamic for containment. something similar to what holds the starter in place for a turbine, or the IGV system on the WM series fans. jsut a thought.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jul 18, 2011, 05:41 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
if it looks like inlet guide vanes it can improve the thrust too. the guide vanes i have seen on full scale turbo fan engines actually bends the air so that the rotor takes a bigger "bite" of air . think of them as stators that turn the air into the rotor...but hey even straight vanes would at least catch the rotor and smooth out the incoming air ,a bering could be used too for even better shaft support.
Old Jul 18, 2011, 05:47 PM
Joined Jan 2009
^^^agreed. totally.
Old Jul 18, 2011, 06:17 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
WELL GREAT MINDS DO THINK ALIKE
Old Jul 18, 2011, 08:55 PM
Joined Jan 2009
well, it stands to reason really, when you look at all the early turbojets, they had a moveable stator section before the first stage of compressor blades. it could be moved to give the best air entry to the first stage. that's a little advanced here, but if it's designed at the right angle, as you say, it should increase thrust slightly. my guess is it should use the same amount of blades as the stator section. this makes sense to me, but three would give adequate support and containment.
Old Jul 18, 2011, 08:57 PM
Joined Jan 2009
now, how do I/we get a patent on this, before it gets produced?..........JIM, EPF, TAM, anyone, anyone, Bueller, Bueller? hahahahahaha.
Old Jul 18, 2011, 10:20 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
LOL! Too late, I jumped in a time machine and already filed.
JimDrew is offline Find More Posts by JimDrew
Old Jul 19, 2011, 01:27 AM
Joined Jan 2009
DAMNIT!!!!!!!!!! apparantly, XPS also produce the flux capacitor. hahahahahaha.
Old Jul 19, 2011, 04:09 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Interestingly, you guys are talking about something that a company has just been poo-pooed for making, i.e. straight vanes, rotor, stator.
The argument for was 3 bearings is better, the one against was it's statically indeterminate, therefore bad.
Odysis is offline Find More Posts by Odysis
Old Jul 19, 2011, 09:49 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
So where they saying that straight stators reduce static thrust?
I've got some shrouds that have straight stators and my bench numbers go down noticeably with them using same rotors\motors\escs...couldn't explain it and thought the stators might be the issue.
erh7771 is online now Find More Posts by erh7771
Old Jul 19, 2011, 10:09 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
will on full scale the IGV's turn the airtoward the blade in the opp. direction ...i never have understood that but it helps the rotor take a bigger bite of air .....they are hinged to change there angle also ....i dont know if this would help or hurt a EDF. might make it real noisey too
Old Jul 19, 2011, 10:47 AM
Joined Jan 2009
I think it's because there's no windmilling, or loss of energy associated with a straight flow of air. a swirling mass in the direction of rotation has less losses, thereby giving a bigger bite.
Old Jul 19, 2011, 12:25 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
Would a FG / kevlar / nylon IGV assembly work? It might deform and absorb the energy without possibly breaking a chunk out of a blade. I assume that it would be easier and lighter than an aluminum version. No carbon here, I think that it would shatter. Setting the IGV angle for best performance would be a side benefit. A variable IGV system is actually not to hard to make, but it may not be as strong, negating the original issue.
http://www.youtube.com/watch?v=aO4kG...layer_embedded
Ken
Ken Lilja is offline Find More Posts by Ken Lilja
New Product efflux RC...AMA approved - 70mm, ALL ALLOY EDF - 6.5 lbs peak thrust efflux RC Electric Ducted Fan Jet Talk 999 Apr 12, 2013 08:04 PM
Discussion Esprit Model’s new Flagship, Ventus 2cx, 6m (236”) 13.25kg (29.1 lbs) Esprit Model Electric Sailplanes 7 Jul 11, 2011 07:45 AM
Discussion EDF Test Data, Thrust, Efflux, Amps... Anything I am missing? jfetter Electric Ducted Fan Jet Talk 50 Apr 23, 2011 01:15 PM
Question 90mm edf with around 8 lbs of thrust john_53_70 Electric Ducted Fan Jet Talk 13 Jan 16, 2011 11:05 PM
Discussion How far can a cheap 90mm fan go? 12lbs thrust? 250mph efflux? Knife Liddle Electric Ducted Fan Jet Talk 2 Nov 06, 2010 10:48 PM
