Old Jul 17, 2011, 03:06 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
New Product
efflux RC... AMA appv'd 80mm and 90mm ALL ALLOY EDFs
EDIT July 21, 2011
Our ALL ALLOY edfs are now AMA approved.................................................. .................................................. ..
Initial testing of the Mach ALL ALLOY 90mm EDF has been completed.
Weight of complete 90mm EDF unit (no motor): 244g
The video depicts the peak thrust at 6 KG.
Hear are the other numbers
Volts........44.9
Amps.......118.69
Watts........5329..2
RPM..........34429
Posting peak numbers for EDF is consistant with the industry. Below is the avereage, settled thrust (during a 30 sec run)
Settled thrust....5.6 kg (12.35 lbs)
Volts........43
Amps.......114.93
Watts........4899
RPM..........32533
Equipment used:
EDF: Mach ALL ALLOY, 90mm (CNC Machined entirely from 6061-T6 Aluminum)
Motor: HET 700-83-1080
ESC: Mega power 120 opto
LIPO: 12s, Fullymax 55c, 5000 (4s x3)
EDF test stand configuration
INLET: no external inlet lip or bellmouth intake (the EDF housing has only a small inlet radius on the I.D.)
EXHAUST: open
Mach and I both have 39mm MEGA 22/80/1E (1080kv) motors on the way for continued testing.
I will also conduct our usual, in house testing upon receipt of the EDF unit and MEGA motor.
We will provide a bench test video and unedited flight test video, as is our standard policy.
My bench test will include a .25" radius inlet lip and an open exhaust.
We hope you guys follow along and join in for continuing developments.
Gary
MACH 90mm All Alloy EDF thrust test 2011-07-17 (1 min 12 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jul 17, 2011, 03:21 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Great numbers and this is WITHOUT a full intake lip...
Your amps and watts are switched in your figures....
Hows the heat transfer from motor to shroud?
Also, KA test stand....did you guys make it yourselves? If not where can we be acquired?
Nice
Regards
erh7771 is online now Find More Posts by erh7771
Old Jul 17, 2011, 03:36 PM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by erh7771 View Post
OMG Is this legal?
This is WITHOUT a full intake lip...
Nice
Regards
Thanks for the correction. I fixed it above, as well.
Volts........44.9
Amps.......118.69
RPM..........34429
Volts........43
Amps.......114.93
Watts........4899
RPM..........32533
The heat tran fer is excellent. The motor is a very tight to the motor housing I.D. and is assembled using thermal transfer compound (heat sink grease.)
The thrust stand is available from us. I havent posted them on the website yet.
The price is $685.00 (scale included)
Optional intake and exhuast tube supports: $99.00
intn'l flat rate shipping: $69.00
Site Sponsor
Old Jul 17, 2011, 03:59 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
good mother!!!!!!!!!!!!!!!!!!!
now..how about a 120
cant wait to see the 90 in person!
corsair nut is offline Find More Posts by corsair nut
Old Jul 17, 2011, 04:48 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Awsome test ...lots-o-info
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jul 17, 2011, 04:54 PM
Joined Nov 2005
Can't wait to see the 120 numbers, looks like for around 15pds of thrust on 12s it'll use less than 100 amps...
Was flyin some of my 70mm today and want to keep everything light
Old Jul 17, 2011, 04:55 PM
Joined Nov 2005
Originally Posted by efflux RC View Post
...The heat tran fer is excellent. The motor is a very tight to the motor housing I.D. and is assembled using thermal transfer compound (heat sink grease.)...
How much does the unit weigh?
efflux RC's Avatar
Joined Aug 2009
LOL...knew that one was coming.
I hope to have them at the BIG JOLT.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jul 17, 2011, 05:01 PM
efflux RC's Avatar
Joined Aug 2009
I'm awaiting the the weight spec, and hopefully the efflux velocity.
It should be pretty light,
All the weight will be in the motor and battereis.
I'll be offline for a few hours.
Site Sponsor
Old Jul 17, 2011, 07:00 PM
Joined Nov 2005
....wait, 13pds out of a 90mm!?
How to do a double take....
Turbines better step their game up...
Old Jul 17, 2011, 08:56 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
awesome stuff Gary. any idea on pricing yet? great numbers though and this is only the beginning. how much more do you expect to get out of this?............2-3 lbs?
edit: is it just me, or does that thing not sound eerily similar to an early generation axial turbine? WOW!!!!!!!!!!!!!
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jul 17, 2011, 09:00 PM
efflux RC's Avatar
Joined Aug 2009
The complete unit (no motor) weight is: 244g
Rich,
Price, coming soon.
We may see a bit mree from the MEGA. They will be available for 36 and 39mm motors, so there will be a varriety of motor choices. and brands. I'm sure we'll see our euro friends running Petties and Lehners in them as well.
The sound is always a plus for those who are concerned.
Site Sponsor
Old Jul 17, 2011, 10:35 PM
50mph is offline
Find More Posts by 50mph
50mph's Avatar
Tacoma, Washington
Joined Jul 2007
Nice
So what about running this on 6S?
I need a 6S setup for a 90mm.
50mph is offline Find More Posts by 50mph
Old Jul 17, 2011, 10:54 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Now, if we could just get the AMA to allow these rotors...
JimDrew is offline Find More Posts by JimDrew
Old Jul 17, 2011, 11:04 PM
efflux RC's Avatar
Joined Aug 2009
This is intented to be a high powered unit and requires high power to spiin it at the RPMs required for the previously posted thrust. You are going to need a 120HV ESC for 12s, At 6s the amps would near 240.
I would not consider 6s a possibility for this fan.
Maybe a higher kv motor for 10s, but youll need a bigger ESC. You could run it on less cells, but your thrust will decrease accordingly.
At this time, it's only been bench tested on 12s, with one motor.
Site Sponsor
New Product efflux RC...AMA approved - 70mm, ALL ALLOY EDF - 6.5 lbs peak thrust efflux RC Electric Ducted Fan Jet Talk 999 Apr 12, 2013 08:04 PM
Discussion Esprit Model’s new Flagship, Ventus 2cx, 6m (236”) 13.25kg (29.1 lbs) Esprit Model Electric Sailplanes 7 Jul 11, 2011 07:45 AM
Discussion EDF Test Data, Thrust, Efflux, Amps... Anything I am missing? jfetter Electric Ducted Fan Jet Talk 50 Apr 23, 2011 01:15 PM
Question 90mm edf with around 8 lbs of thrust john_53_70 Electric Ducted Fan Jet Talk 13 Jan 16, 2011 11:05 PM
Discussion How far can a cheap 90mm fan go? 12lbs thrust? 250mph efflux? Knife Liddle Electric Ducted Fan Jet Talk 2 Nov 06, 2010 10:48 PM
