Old Jul 16, 2011, 11:28 AM
desmobob is offline
Find More Posts by desmobob
Arc, spark and smoke...
desmobob's Avatar
upstate NY; Lake George region
Joined Mar 2006
OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver gets hot?
I just maidened my Electrifly Seawind EP. I equipped it with a HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver. The plane flew very well and when I brought it down after flying three batteries, back to back, the ESC and battery were barely warm but the Rx was quite warm -- borderline "hot."
Is this normal? I have analog servos in the model and believe I have the Rx in the proper mode. But even if it wasn't in the proper mode, it should be the servos that get hot, not the Rx, right?
Anyone experience this?
Good flying,
desmobobO
Anyone experience trangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
desmobob is offline Find More Posts by desmobob
Old Jul 16, 2011, 12:13 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
If you have a standard four or five cell receiver battery handy, try running just the receiver on the bench and see if it gets hot. There is a voltage regulator in any receiver and they do produce a little heat, but not enough to make the receiver hot. Somthin ain't right
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jul 16, 2011, 02:45 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I have two of those and they work great. I run them off 5v and 6v BEC and they just get slightly warm but never hot. What voltage are you using?
RC Man is online now Find More Posts by RC Man
Old Jul 17, 2011, 03:22 PM
desmobob is offline
desmobob's Avatar
Joined Mar 2006
Pete
I'll bench test it tonight and report my results.
The Rx is in an ElectriFly Seawind EP (three HXT900 servos) and I'm powering it from a Castle Creations Phoenix 25 ESC with a 3S 1500mah LiPo. I'll double-check my ESC settings to see what the BEC voltage is set at. I'm running the Phoenix out of the box, so it should be 5V.
Thanks for your responses,
desmobob
Old Jul 18, 2011, 07:14 AM
desmobob is offline
desmobob's Avatar
Joined Mar 2006
desmobob
I put the Seawind on the workbench and did some checking.... I double-checked to be sure the Rx is in analog servo mode; it is. When I work all the servos continuously, the large square black chip on the Rx's PCB gets just barely warm. When I run the motor, it gets noticeably warmer, but barely.
On the day of the maiden flight, I had just treated the Rx with Corrosion-X. Maybe the oily film on the PCB was still thick enough to prevent the Rx from cooling as I flew three batteries in a row. My Rx is mounted on Velcro in a spot where there is air moving through the fuselage.
I'll try flying again and I'll closely monitor the Rx temperature.
Thanks again,
desmobob
Old Jul 27, 2011, 11:14 PM
Big Roy is offline
Find More Posts by Big Roy
Joined Jul 2011
I just got a winning bid on a 6ex rx and wanted to order a HK Futaba compatable Orange
tx, and hoped that they are ok
Big Roy is offline Find More Posts by Big Roy
Old Jul 28, 2011, 06:05 AM
United States
Joined Feb 2001
Glitch Problem
I have a glitch problem with my Orange Rx after I upgraded my 8FGH tx to V3. It has a throttle glitch every 30 seconds or so. I think itís related to failsafe. I linked it to my 7C tx and it does not have that problem.
Maybe I need a rx firmware update to fix this problem. Does this receiver have update capability?
Old Jul 28, 2011, 08:18 PM
Chase Wu is offline
Find More Posts by Chase Wu
Joined Mar 2009
No need to upgrade the rx, just disable the failsafe settings on your Tx side before setting FrSky failsafe positions.
Chase Wu is offline Find More Posts by Chase Wu
Discussion OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver WSWitby Electric Plane Talk 2 Apr 05, 2011 07:30 AM
Alert OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver in stock now bob4432 Hot Online Deals 13 Mar 14, 2011 10:54 AM
Wanted OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver unlvace Aircraft - General - Radio Equipment (FS/W) 0 Nov 14, 2010 06:21 PM
Wanted OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver NIB unlvace Aircraft - General - Radio Equipment (FS/W) 0 Nov 01, 2010 07:04 PM
