Old Oct 04, 2011, 07:57 PM
Machineman is offline
Find More Posts by Machineman
Aussie F3K Team
Melbourne, Australia
Joined Jun 2008
I got it from a hobby shop that sells multiplex or hitec. They can order it in for you as a spare part
Machineman is offline Find More Posts by Machineman
Old Oct 11, 2011, 04:02 PM
Beetle-Jet is offline
Find More Posts by Beetle-Jet
Beetle-Jet's Avatar
Joined May 2010
Originally Posted by Machineman View Post
Hi all,
My Steig is still my favorite plane and I choose it over my Salpeter, FW5 and Blaster 2.
There has been a an evolution of the settings I originally posted. The big difference now is I fly the Steig a lot more agressively (tighter turns)than when I started (smooth and open) and the setting reflect this:
1. My CG is a little way forward from what I normally fly my planes at, and is at 70mm from the L.E (recommended 73mm).
2. Snap flap is now at 5mm (yes 5mm) as the plane was getting mushy when I tried to do a tight turn. Now it flies much tighter circles and the flap does not make it draggy! I have it in all modes.
3. My differential has increased to about 35% (12mm up and 8mm down).
4. I have about 2mm of Rudder mixed into the Aileron to Rudder mix.
5. I have two thermal setting, a 2mm and a 4mm setting. I fly 90% of the time in the 2mm setting and the 4mm setting is only used in dead calm conditions or extreme thermals.
6. My reflex setting is -1.5mm, but I am thinking of going back to neutral with some down trim and try it for a while.
7. I have a two stage launch, the first (on a sprung switch) has 1mm positive flap for the rotation and the second (on a normal switch) has 1.5mm reflex.
I hope this helps.
Cheers,
Marcus
Hi,
I going to try your CG point on very calm morning, that is interesting attitude
Gil
Beetle-Jet is offline Find More Posts by Beetle-Jet
Old Nov 10, 2011, 09:26 PM
MEGAHURTZ is offline
Find More Posts by MEGAHURTZ
IOWA
Joined Feb 2001
switch
I found one here
http://search.digikey.com/scripts/Dk...rds=ckn1142-nd
It just came in today, it looks like a dead ringer for my SD10-G.
I have not put it in yet. This is a spring on one side and toggle on the other.
MEGAHURTZ is offline Find More Posts by MEGAHURTZ
Old Nov 11, 2011, 05:02 PM
Tmfury is offline
Find More Posts by Tmfury
up from the skies
Tmfury's Avatar
United States, CO, Fort Garland
Joined Jul 2011
I'd like to say sorry for neglectin this thread I started.I crashed my steig acouple months ago(tried to fly with a dead li po)also it was brought to my attention that I spelled it wrong and I need to fix it.as soon as I figure out how I'll fix it. Also for weeks I couldn't log on cause it said my pass word was wrong,and I finally got that workin again.the good news is Cody shipped my new steig today. This one features top drive, instead of 4 servos in fuse. I can hardly wait to fly with all the New Mexico dlg guys again. And thanks to everybody whose taken the time to post on this thread.
Tmfury is offline Find More Posts by Tmfury
Old Nov 11, 2011, 05:58 PM
1900 Driver is offline
Find More Posts by 1900 Driver
1900 Driver's Avatar
United States, CA, Santa Barbara
Joined Mar 2009
I just picked up my new topdrive carbon wing from cody! the layup is far better than the last one. It seems a lot more durable too! really excited to get it going!!!
Thanks again Cody,
Brandon
1900 Driver is offline Find More Posts by 1900 Driver
Old Nov 11, 2011, 06:17 PM
IOWA
Joined Feb 2001
switch outcome
I installed my new switch (I am a lefty) on the left side, momentary set forward so it helps me hold on to the radio.
This C&K switch has a harder snap. The momentary side is fine, the toggle side is the harder side.
The part that came out of the radio was a Salecom T80-T I would buy this one, if I did it again. Salecom T80-T flat toggle 0n 0ff (On).
Old Nov 12, 2011, 03:36 AM
floquet is offline
Find More Posts by floquet
Hugh Blackburn
floquet's Avatar
Joined Jun 2005
Marcus you big fibber!
This the part:
http://www.worldhobbies.com/product_...5707_item.html
Thanks to Mike Stern & Nick Chitty for putting us onto this.
Hugh
floquet is offline Find More Posts by floquet
Old Nov 12, 2011, 09:00 AM
IOWA
Joined Feb 2001
switch price
Wow, I thought $7.50 was high from Digi key.
World Hobby at $23.
Salecom T8014B-(U)(short flat toggle, U2 for a long flat toggle
This is a On Off (On).
I see this switch in Salecom literature. I have not found in the USA.
http://www.salecom.com.tw/pdf/T80-T_.pdf
Old Nov 12, 2011, 09:31 AM
Tmfury is offline
up from the skies
Tmfury's Avatar
Joined Jul 2011
Does anyone know if the latest steigs ( top drive)are finishing out at the same weight as the previous ones(4 servo in fuse)?
Also if anyone has build/flight reports on the top drive version I'd like to read bout it
Old Nov 12, 2011, 10:54 AM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Post #2 irrelevant now.
gopherhunter is offline Find More Posts by gopherhunter
Old Nov 12, 2011, 08:23 PM
pocket rocket is offline
Find More Posts by pocket rocket
pocket rocket's Avatar
patagonia,az
Joined Oct 2002
Well done Tom
you can spell Steigeisen !!!!!!!!!!!!!
I have one too
Philip
pocket rocket is offline Find More Posts by pocket rocket
Old Nov 12, 2011, 08:47 PM
Tmfury is offline
up from the skies
Tmfury's Avatar
Joined Jul 2011
Actually I can't spell or do math beyond about a 7th or 8th grade level.but I love flyin gliders
Old Nov 12, 2011, 11:05 PM
IOWA
Joined Feb 2001
I also have a Steigeisen 4 servo in the fuselage and a SD10.
Now, if I can just get the programing figured out.
Old Nov 12, 2011, 11:15 PM
Tmfury is offline
up from the skies
Tmfury's Avatar
Joined Jul 2011
Megahurtz,I'm not the best guy to help program a radio,but I could share my set up- also a sd 10g.I know there's a way to load the whole set up from one tx to another. Cody did that for mine.
Old Nov 12, 2011, 11:44 PM
danfitz is offline
Find More Posts by danfitz
danfitz's Avatar
United States, CA, Vista
Geez, where were you guys when I was trying to sell my Steigeisen?
danfitz is offline Find More Posts by danfitz
