Espritmodel.com Heli Air
Old Jul 15, 2011, 09:18 PM
Rising Force
Tmfury's Avatar
United States, NM, Albuquerque
Joined Jul 2011
Steigeisen
Hey guys,this is my first post.thougt i'd share my experiance with my first dlg.the stiegeisen.it has been way super fun! I couldn't launch very high at first but progress came every session.now after a month I get 100 feet + and it feels super comfortable.the plane es todo bien!! I'm 100% satisfied,I can't say enough good things about it. In addition, I'd like to thank skip and Cody,you guys are the best!
Thanks para todo.
Tom martin
Tmfury is offline Find More Posts by Tmfury
Old Jul 15, 2011, 09:25 PM
Registered Loser
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Tom welcome to the addiction and RCGroups. Where are you located?
John
"Anyone who can only think of one way to spell a word obviously lacks imagination." ...Mark Twain
gopherhunter is offline Find More Posts by gopherhunter
Last edited by gopherhunter; Nov 12, 2011 at 10:51 AM. Reason: Well he finally got it spelled right!
Old Jul 15, 2011, 09:32 PM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Thanks I'm in Albuquerque Nm and lookin forward to be a participant in this great forum
Old Jul 15, 2011, 09:40 PM
Registered Loser
Franktown, CO. USA
Joined Mar 2009
Did we see you at Blue Skies Over New Mexico last weekend?
Check this out too...http://www.rcgroups.com/forums/showthread.php?t=1469797
John
Old Jul 15, 2011, 09:44 PM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Yes that contest helped me tons and was super fun-great people.does anybody have advice on ail differecial settings?
Old Jul 16, 2011, 10:56 AM
Joined Aug 2007
Hello everybody and hello tmfury. I use the factory settings ( stratair.com) and work well for me. With experience you' should throw it really high. It's one of the best things this model do.
For floating I found twister2 and Salpeter better.
Francesco
Italy
f19650 is offline Find More Posts by f19650
Old Jul 16, 2011, 11:34 AM
Schweiz
Joined Jul 2010
perosnally i don't like differential on the steigeisen,
respectivly do i have 75% negative differential.
= more aileron down then up.
Best is, you try yourself.
different pilots, different flystyles.
different wheight of planes/Wings, different behave
on my first steigeisen i had the factory settings, exept the exponential which i took out.
My second steigeisen ( also secondhand) went nearly into ground on the first throw.
I setted up all like the factory settings.
But my second steigeisen needs up elevator on the throw, not down.
and in the meantime i fly the CG more forward. I guess around 71mm now.
punky
patchworker is offline Find More Posts by patchworker
Old Jul 16, 2011, 11:47 AM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Thanks Francesco , i'll check that out.currently I have about 2.5 to 1( up to down travel ) similar to my j&b ships.seems like dlg don't need that much diff.I appreciate any thoughts on this .
Unleash the fury
Old Jul 16, 2011, 11:54 AM
Beetle-Jet's Avatar
Joined May 2010
Hi,
Congrats on the Steig, i also has it for few months now.
What kind of version do you own ? Kevlar wing ? , else ?
does your wing servos installed in the wing, or in the fuselage?
At first i had some minor issues when throwing hard, such flatter at the outer wing aileron.
After some modifications and much smoother launching technics No flutters.
At start i used the original setup that come along with the instructions, today i change it a bit to suite my flying style
such as more movement of the Rudder in the Ail > Rudd mix
Ele > Camber mix is something that helps.
For strange reason but i really don't care i added a bit Camber to the wing on cruise mod ( with the left slider ) and small elevator down compensation, and the plane act much more calm without loosing is penetration ability
this glider can easily launched to heights around 200 ft.
I am kind of new to this DLG's and with the right technics i measured 183 ft
Gil
Beetle-Jet is offline Find More Posts by Beetle-Jet
Old Jul 16, 2011, 12:14 PM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Thanks for the replies,I have the aramid wing 4sevo in fus & after flying at rec cg 73mm I moved it back to 75mm and like it immediately the plane is way more "alive" with no stability loss .it's super gentle handling .I've got bout 300 throws & not a scratch on it.also no flutter .any ideas on fm's & settins are greatly wecomed.
Tm
Old Jul 16, 2011, 12:27 PM
Beetle-Jet's Avatar
Joined May 2010
hi,
pics would be nice, where did you placed the wing blade ? ( pic will help )
did you need the flight mods setup ?
Gil
Old Jul 16, 2011, 02:08 PM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Hi gill
I placed the peg close to instructions within 1-3mm .I would go little closer to tip next build .I don't know how to post pics& video yet ,as soon as I can sure will
I'm just learnin computers too
Thanks. Tom
Old Jul 16, 2011, 02:20 PM
Rising Force
Tmfury's Avatar
Joined Jul 2011
Gill
So far my setup inc:
Launch. 2pm chamber w/1.5mm up el
On spring sw
Cruise
Therm1-3mm ch & 1mm up el
". 2-5pm ch&. 1mm " "
Reflex. 1.5 mm - 1 mm dn el
Chamber on slider also-unto 6 mm
Old Jul 28, 2011, 12:29 PM
1900 Driver's Avatar
Denver CO
Joined Mar 2009
I just traded for a used Steig from a buddy the other day, was amazed at how well the plane flew! its like an F3J ship. covers ground really well and can cruise from thermal to thermal so easy its almost rediculis! after about 20 or 30 throws I started to amp up my launch with more power and was easily getting 180 ft and then I ripped the wingtip completly off along with the throwing peg! couldn't believe it! so I put a couple layers of carbon uni on top and bottom of tip and just put the blade back in with radiused edges and epoxy with micro balloons and moved the blade a little deeper towards centerline. Before it was pretty far out and right on the edge or the reinforced area. So, be very carefull if you're going to push peg placement outboard and an feel for the hard point! I have the full carbon wing.
Brandon
1900 Driver is offline Find More Posts by 1900 Driver
Old Jul 28, 2011, 09:38 PM
Tom:
Have you been counting (Like, one, two, three...)?
Will you be at the sod farm this Saturday?
Yours, Greg
glidermang is offline Find More Posts by glidermang
