Old Jul 02, 2001, 01:23 AM
slowpoke is offline
Find More Posts by slowpoke
Palo Alto, CA, USA
Joined Nov 2000
Kyosho Ferias: How to mount a sp380 on a firewall?
Folks, I have the remnants of a Kyosho
Ferias that I'm repairing after a crash
due to a radio glitch. The sp380 motor
was held in an aluminum hose-clamp like structure mounted on a couple of plywood
arms that stuck out from the firewall. The
arms broke off in the crash and I'm
wondering how mount it witn some 'give'
in the mount so that minor contact of the
prop with the ground on landings wont
rip off the motor. The original mount wasnt
bad but its hard to repair without taking
off the firewall and i'd like to patch up
the firewall with some plywood and mount
the motor on it.
Thanks.
slowpoke is offline Find More Posts by slowpoke
Old Jul 02, 2001, 01:54 AM
Spam is offline
Find More Posts by Spam
San Diego, CA, USA
Joined Aug 2000
The original Ferias Motor mounts were notoriously weak anyway... A simple hard landing without prop contact would be enough to snap the two pieces of wood.
I have seen several "fixes".
1. Run 2 1/4" dowels about 8" into the fuselage, use rubber bands to hold down the motor.
2. Replace and reinforce the original mounts. This time the motor was mounted on 1/2 of the clam-shell mount and rubber bands were used.
3. Bolt up a nylon/glass motor mount for a .15 size engine to a plywood firewall, again, rubber bands were used...
All 3 of these methods worked, but 2 seemed to work the best. This method kept the original downthrust. The reinforcement was 2 triangular pieces of 1/8" ply glued under the existing mount. This brace finally broke when the aircraft thought it would be fun to emulate a lawn dart, and its wing snapped in half... All I heard was a CRACK, a loud "Oh C**P" and 5 seconds later a smash...
At least the radio gear survived...
Spam is offline Find More Posts by Spam
Old Jul 06, 2001, 01:58 AM
slowpoke is offline
Palo Alto, CA, USA
Joined Nov 2000
Thanks for the info spam! All good
suggestions. I'm also considering replacing
the plywood arms with carbon fibre 'cept not
having dealt with CF very much, I
have no idea if a strip of carbon would be
suitable or not. I need it to be strong
enough to support the 280 while being able to bend in a mild crash and spring back into shape. I'm not sure what thickness
to get or if I should go for a CF tube.
Are CF tubes available in rectangular cross-
sections? If so, those might be more suitable.
Ashok
stick mount gearbox on firewall? DrummerboyBG Electric Plane Talk 6 Aug 27, 2005 08:16 PM
Question How to mount 2508 on pager motor PlanesRcool Scratchbuilt Indoor and Micro Models 3 Mar 19, 2005 08:47 PM
How to mount a Himax on the Shogun ? microflite Mini Helis 12 Oct 20, 2004 03:31 PM
how to mount a PJS300 on an IFO and get your wife mad at the same time! dalbert02 Electric Plane Talk 8 Feb 19, 2004 03:18 PM
How to mount heatsink on GWS ics 300 esc??? AL TYLER Power Systems 7 Nov 30, 2003 09:03 PM
