Old Jul 15, 2011, 09:06 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
WOW! looking good what tail servos are you using? they look a little small... IMHO you really need HS-81-82 size servos(about 17gram or so) due to the overall weight of the plane and mass... it's just an awful lot for a 9g servo to throw around.
You'll probably LOVE the FC! one of the few planes that I've built and flown that lives up to the hype it's just plain FUN to fly
post some completed pic's and maiden info
John
shultz is offline Find More Posts by shultz
Old Jul 15, 2011, 09:17 PM
waynemia is online now
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Thank you.
The tail servos are MG-14s. It is a 14g servo. I am not a fan of Hitec servos. The MG-14s have the torque needed and they are metal gear.
I helped another club member with his but it is pretty stock.
The decals are pretty wrinkled but I won't use much of them anyway.
waynemia is online now Find More Posts by waynemia
Old Jul 15, 2011, 10:38 PM
shultz is offline
Joined Sep 2009
MG-14's should do fine... as for the decals... mine were wrinkled as well a little light spray of windex helped keep them from sticking until I could get them to lay right all though I must say... your paint job looks clean as is...I'd just leave it... maybe some aircraft ID numbers if anything.
John
Old Jul 16, 2011, 07:01 AM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
An N number might be nice.
Old Jul 16, 2011, 06:18 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Making progress on the wiring. This thing will have more wiring than anything I have built to date.
I also have the wing assembled. I did not care for the setup on the tail wheel. I added a wheel collar below the hinge so that the tail wheel would not push directly into the rudder.
Old Jul 16, 2011, 08:43 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
A little more progress. The wings are glued together, the lights are wired in, fuse halves are joined, main gear block installed, and main gear temporarily installed.
Lighting on my FunCub (0 min 12 sec)
Old Jul 16, 2011, 09:01 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Looking good!
Xpress.. is offline Find More Posts by Xpress..
Old Jul 17, 2011, 07:52 PM
shultz is offline
Joined Sep 2009
I hope you plan on showing us a night flight
I'm seriously considering building another FC so I can incorporate LED's and Nav lights into the fuse and over all build... I could just stick them on my current FC... it will look like I did exactly that I'm really enjoying my LED covered slowstick and Nutball for evening/early morning flying...I think the FC would be even nicer as a night flyer.
Old Jul 17, 2011, 08:19 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
An evening flight for sure. I am not that experienced at night flight.
We will see.
Old Jul 18, 2011, 05:35 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
No pics today, CA is drying on the wing rods. I have all the lights on, the lenses on the position lights and landing lights, motor mounted, ESC done (Turnigy 40 Sentry), Tail wheel glued, push rod snakes installed, prop balanced, and end points set. I chose not to use the Castle 36 ESC. I might want to sneak a 4S battery in one of these days.
I put in a 9 channel receiver but I only have control of 8. The 9th will be the FAA lighting. I have all the aileron and flap servos on separate channels. My Futaba 10C automatically reverses channel 5 for me for flaps and I don't have to fiddle wth the mount or a reverser. I put the flaps on a three way switch. I may want to change that later. It is currently 0*, 45*, and 90*. It is approximately 90* I have not measured it but it is all the servo can do. I would need a longer arm to get more. I am SURE it will be enough though.
I can also use the aileron differential feature. I have the tow release all setup.
I have a crow programmed.
The tail push rods were almost too short. I guess it was just the position of the output gear. I have more throw available than max in the manual. I might want to play with an elevator -> flap mix too.
This should be some fun to play with the various settings.
Old Jul 18, 2011, 06:05 PM
shultz is offline
Joined Sep 2009
sounds like you're just about there! Oh... I'll settle for an evening flight
One thing thats a bit troubling... I see no mention of a separate BEC
Old Jul 18, 2011, 06:26 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
I will use a separate battery for the LEDs. 500mAh, 3S works fine and not much weight.
The ESC has a 3A esc and that should handle the servos. I might measure it for grins and giggles.
Old Jul 18, 2011, 07:26 PM
shultz is offline
Joined Sep 2009
Yeah that should be fine... I just don't like on board BEC's... even switch mode. what bothers me is that if the ESC gets a little to warm on a hot day here in Vegas it could thermal the BEC... plane goes down I just feel better running Castle creations BEC's A dead stick, even in a bad position is far better than just helplessly watching the plane go in!
Old Jul 18, 2011, 07:35 PM
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
So far, I have not had a problem with BECs and it is hottern' you know what here. I use mostly Turnigy ESCs and they have done well. I have the CC 36 ESC that came with the power set but chose not to use it.
For Sale Aluminum Motor Mounts for Multiplex FunCub, Gemini, EasyCub, Mentor, Parkmaster 3D sotog Aircraft - Electric - Power Systems (FS/W) 0 Jun 24, 2011 11:41 PM
Discussion funcub faster ahifly Electric Plane Talk 6 Jan 06, 2011 07:25 AM
Question I find my fw190 easier to fly than my funcub-am I missing something? richieh Beginner Training Area (Aircraft-Electric) 6 Nov 30, 2010 05:56 PM
For Sale [b]Multiplex FunCub - FPV Combo[/b] no7rosman Aircraft - Electric - Airplanes (FS/W) 3 Nov 11, 2010 09:32 AM
For Sale Mulitplex FunCub - FPV Combo no7rosman FPV Equipment (FS/W) 0 Nov 08, 2010 08:17 AM
