just got a airfield t-28 from microdan on the forum here .looking for extra batteries.
will these fit? http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html stock battery is 50.8 length 31.75 height 15.87 width whats everyone using?? |
I've been a bit busy with work for the last couple of weeks but plan to persue your idea of checking in the warbirds threads for some ideas on alternate props. Seems this one's diameter is 7" but I'm not sure of the pitch. I have considered making a mold of mine before I damage it and just cast some as I need them. Wonder if there'd be a market for these stolen copies? The Chinese don't seem to hold much value in intellectual property rights, so I may follow through... ![]() I did do the mod to the back seat and made a couple of test taxi runs in the cul-de-sac. The pilot and some of his gages do rather well, in a depth of field sort of way, but the view out of the windows is rather wonkey with the waves inherent in the plastic canopy. Might post some vid of it this weekend. |
Joined Dec 2010
http://www.snhobbies.com/index.php?c...0b4190e37cb3bb |
United States, TX, Austin
Joined Jan 2011
Joined the club and bought a mini T-28 too.
Though, went back to order some extra props from NitroPlanes and found the only shipping option listed is outrageous. There is no way I am paying more in shipping than the price of 3 already overpriced props. Thus, went to my LHS today to search for alternatives. I picked up a few that I will test out and report back on. Though, if any one else finds a reasonably priced place to order props, please do share too.On another note, does any one have any tips to help in a successful flight? Are there any quarks to keep in mind? How is the stall speed and tip stall on this? Also, has any one taken any flight video yet? I would love to see how this behaves in the air. Happy flying |
heres a unmodded plane flight
and heres a modded plane on a 3s battery with a 2 blade prop .shes a screamer!!
this is the 800mm bird. |
Joined Jan 2011
I benched tested the T-28 with a watt meter and found that with the standard prop can pull the following power:
* 3 Cell 850 40C - over 19amps * 2 Cell 850 40C - 13.5 amps I am little confused as the JST connector that comes with this plane is rated at 10Amps max and even the two cell I used pulls way over that. Plus, the 20amp esc of course is way over the JSP plug rating too. I have to guess that this plane must be intended to run a low C rating 2-cell at no more than 10 amps. Does any one happen to know what brand/model this motor is and what its ratings are? Also, how do you all configure yours? What combo of battery, connector, esc, and prop are you running on your T-28s? I appreciate the feedback
United States, CA, St Helena
Joined Jun 2011
Hey guys, I bought the 800mm P-51 with hopes of turning it into a pylon racer, however there was no way I could fit a 450 motor in there, and the acess was very poor to get to the motor. I am now looking at the T-28 as it has the roomier radial engine front end. I was wondering if any of you guys could tell me how much room there is over the stock motor or upload some pics of the plane without the cowl... Thanks,
Taylor |
well he is running a 2 blade prop. not sure if he changed out the jst plugs though .might have to listen more closely to the video and see if he mentions that . |
just put my t-28 together today .like mentioned the instructions are kinda vague .your on your own putting all the horns on ,setting them up ,trimming them out ,ect,ect.
wasnt a big issue but the instructions dont mention any of that . ok, i went ahead and double side taped my receiver down out of the way of the steering rod for the front wheel . now wheres the best place to mount the esc?? it kinda just flops around in there ,theres a spot for it kinda but dont want to just jam it in there by the motor ,not only that but it could stress the wires . i want to double side tape it in as well but just figured i would ask ,if you have a picture of yours to post please do . and what about the battery?just use something to wedge it in there?otherwise it can move around ,theres alot of space around it . oh yeah ,the antenna wire ,wheres the best place to run it ???i could run it right thru the wing and let it hang outside the plane.(thru the same hole the aileron wires go thru) good idea?bad idea? suggestions ,pictures?thanks |
| Thread Tools | |
| Sold Airfield Extreme Detail 4-Channel Remote F4U Corsair 800mm (31.5") | Mikemynameis | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 06, 2011 11:50 PM |
| Discussion 800mm T-28 | varian | Nitro Planes | 2 | Jun 26, 2011 01:32 PM |
