Old Jul 15, 2011, 02:43 PM
RaidenTech is offline
Find More Posts by RaidenTech
Rc, rc, and more RC
RaidenTech's Avatar
Joined Jul 2011
New Flysky FS-TH9X 2.4ghz 9ch Transmiiter Overview
Liz takes a quick look at the TH9X transmitter by flysky.
New Flysky FS-TH9X 2.4ghz 9ch Transmiiter Overview Product Tour By Liz (1 min 37 sec)
Check out the th9x here:
http://www.hobbypartz.com/79p-th9x-r...nel-radio.html
Specs:
(1)、channels: 9channels TH9X
(2)、model type: helicopter ,airplane, glider
(3)、RF power: less than 20db;
(4)、modulation: GFSK;
(5)、code type: PPM/PCM;
(6)、sensitivity: 1024;
(7)、lcd type: 128*64 dot;
(8)、low voltage warning: yes;
(9)、DSC port: yes;
(10)、charger port: yes;
(11)、power:12VDC(1.5AA*8);
(12)、weight:680g;
(13)、ANT length:26mm;
(14)、size:190*80*240mm;
Included in the box:
Transmitter
8CH receiver R9B
Binding plug
Manual
The radio can do:
Throttle curves
Pitch curves
Endpoint adjustments
Subtrim
Swash AFR mixes
Servo reversing
Timer
Dual rate
Exponential
Flaperons
V-Tail mixing
Elevons
RaidenTech is offline Find More Posts by RaidenTech
Old Sep 12, 2011, 12:41 AM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
The FS-TH9X radio system is back in stock at HobbyPartz.com
hobbypartz is offline Find More Posts by hobbypartz
Old Oct 18, 2011, 11:49 AM
ktgohdt125 is offline
Find More Posts by ktgohdt125
Joined Nov 2007
HI all'
what is the difference between this 2 Flysky tx :
1. FS-TH9B 2.4G 9 Channel
2. FS-TH9X 2.4G 9 Channel
can u give a detail guide.
intend to buy 1 unit of this tx
thank you
ktgoh
ktgohdt125 is offline Find More Posts by ktgohdt125
Old Feb 17, 2012, 09:37 AM
datalex is offline
Find More Posts by datalex
USA, CA, Fremont
Joined Jun 2005
FS th9x
Is it V1 or V2 Hardware, V1 or V2 Firmware.
datalex is offline Find More Posts by datalex
Discussion FlySky FS-CT4 4-channel 2.4GHz Tx/Rx Little-Acorn Radios 5 Jul 15, 2011 11:06 PM
Sold FlySky/Turnigy/Eurgle FS-TH9X 2.4Ghz 9ch MiG-3 Reno Rocket Aircraft - General - Radio Equipment (FS/W) 7 Jul 01, 2011 07:24 PM
Help! 2.4G FS-TH9X transmiiter, simulator inteface to FMS? flygear Simulators 2 Jul 14, 2010 06:52 PM
For Sale FlySky FS-TH9X 2.4G W/ 3 Receivers Firefox675 Aircraft - General - Radio Equipment (FS/W) 3 Sep 18, 2009 03:48 PM
