This thread is privately moderated by ALL American, who may elect to delete unwanted replies.
Old Jul 15, 2011, 02:34 PM
ALL American is offline
Find More Posts by ALL American
It's Not Too Windy...Man Up
ALL American's Avatar
USA, CT, Wallingford
Joined Oct 2009
Mini-HowTo
E Flite P51B - Conversion and Installation of the New FMS Version 6 Tail ETract
Here's the base retract:
http://www.pw-rc.com/product_info.ph...oducts_id/1943
Not too shabby for $16.00!
The E-Flite 10-15 Steering Arm cost about half that. http://www.e-fliterc.com/Products/De...ProdID=EFLG113
I think the above listed assembly is a steerable version of this retract
http://www.pz-servos.com/en/products...etail&P_Id=835
Here's how I modified this small E-Tract unit to fit into the E-Flite P51B's existing tail wheel opening and to steer via a pushrod linkage.
I will add text when I get a chance. For the time being, the photos are self-explanatory
Parts
Name: FMS Version 6 Tail Retract StockTop View.jpg
Description: Name: FMS Version 6 Tail Retract Stock Side View.jpg
Description: Name: E Flite Steering Arm.jpg
Description:
E-Flite 10-15 Steering Arm Modifications Required
Name: E Flite Steering Arm Modification.jpg
Description: Name: Strut - Steering Arm Brass Spacer.jpg
Description: Name: Modified Steering Bracket.jpg
Description:
E-Tract Unit Disassembly
Name: Disassembled E-Tract.jpg
Description: Name: Discard Parts.jpg
Description: Name: Strut Disassembly.jpg
Description:
E-Tract Unit Modifications Required
Strut Modification
Name: Strut Modification.jpg
Description: Name: Strut Modification 2.jpg
Description: Name: Modified Strut.jpg
Description:
Trunnion Modification Name: Trunnion Modification.jpg
Description:
E-Tract Right Housing Modifications Name: Retract Housing Right Side Modification.jpg
Description: Name: Retract Housing Right Side Modification 2.jpg
Description:
Reassemble Name: Reassembled E-Tract.jpg
Description:
Fabricate and Install a Bottom Mounting Plate
Name: Bottom Mounting Plate.jpg
Description: Name: Mounting Plate Attached.jpg
Description: Name: Assembled Unit Ready for the Linkages.jpg
Description:
Install Pushrod Guide Plate - Note the Tubing Bushing Name: Install Pushrod Guide.jpg
Description:
E-Tract Installation
Start the insertion in the deepest part of the retract bay, the front. Use a clockwise twisting motion and wiggle if needed. Insertion should NOT require any force. The unit will go in freely if it is turned in at the correct angles.
Step 1 Name: Insertion Step 1.jpg
Description: Step 2 Name: Insertion Step 2.jpg
Description:
Step 3 Name: Insertion Step 3.jpg
Description: Step 4 Name: Insertion Step 4.jpg
Description:
Drill Mounting Holes Name: Drill Holes for Mounting.jpg
Description: Name: Drill Last Hole for Mounting Gear Down.jpg
Description:
Remove, Install Pushrod and Steering Linkages Name: Test Fit - Remove and Add Linkages.jpg
Description:
The only way I can make this easier is to do it for you!
ALL American is offline Find More Posts by ALL American
Old Jul 16, 2011, 12:13 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Wow, blundering boob free instructions........excellent documentation!!!Thanks a bunch
Regards
flmlm is offline Find More Posts by flmlm
Old Jul 16, 2011, 03:44 PM
Joined Oct 2009
Regards
Thanks Mike!
I can't tell you how many different servoless retracts I've tested, how many different steering linkage configurations I've tested and how many tries it took to make it fit into the tiny, shallow opening of the P51B. I settled on this setup because it is the lightest E-Tract and the most reliable steering linkage I could come up with. Total weight is 1.25 ounces, including the mounting plate, E-Flite Steering Arm and clevis.
I may elaborate a bit or add more pictures at a later time, but I think what I've posted is fairly self-explanatory. If you have any questions let me know?
Regards,
Anthony
Old Jul 18, 2011, 05:20 PM
flmlm is offline
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Anthony
Your diligence is appreciated thats what these groups are all about modellers helping modellers.
Regards
Old Jul 18, 2011, 07:50 PM
Joined Oct 2009
Anthony
Regards
Please post some pics of your setup when it's complete and feel free to PM me if you need some help.
Regards,
Anthony
Old Jul 18, 2011, 08:33 PM
flmlm is offline
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
I was thinking about what about some tail wheel gear doors...perhaps something like the set up on the FMS Mustang....wouild be nice to have the tailwheel bay covered when retracted.....just isn't much room inside. Just a thought that I'm kicking around....
Regards
Old Jul 18, 2011, 09:00 PM
Joined Oct 2009
Regards
Mike,
I am happy that the E-Tract fits! There is physically no room to spare when installing the assembled E-Tract into the the retract bay. Therefore, any hinges would be in the way. Now, if the hinges and doors can be added after the E-Tract is inside of the retract bay and made removable for servicing the retract, then I don't see any reason why it is not doable. If you figure out how to install gear doors please share. For the time being, I am happy that I don't have to look at a tail wheel hanging down or watch it retract in the wrong direction.
Now if the automotive paint supplier ever comes through with an Olive Drab that matches the Oracover I'll be able to finish my plane.
Regards,
Anthony
Old Dec 23, 2015, 10:17 AM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Thanks for writing this up. Sorry but I am just now getting around to building this plane. Your links for the retract are no longer valid. Do you by chance know of a new source for the retract?
camoy is offline Find More Posts by camoy
Old Dec 24, 2015, 09:45 AM
Joined Oct 2009
I do not have updated links for the parts. Try Motion RC for the FMS P51 Tail Retract and the other parts are E Flite and parts I recycled that came with the P51B . The mounting plate was constructed from a nearly indestructible plastic, but you can substitute a light aluminum.
Good Luck
Anthony
Old Jan 11, 2016, 05:10 AM
camoy is offline
I can't fly
camoy's Avatar
Joined Dec 2006
First off thanks for the suggestion for the website to get the tail retract, they had them.
I have done the required modifications to the retract and was in the process of making the mounting plate. I have a request can you post a picture of how the steering rod attaches and how the steering mechanism is assembled on the retract? Sorry but I can't seem to figure that part out.
Thanks again
Old Jan 11, 2016, 07:40 AM
Joined Oct 2009
Thanks again
This is an old project.
Send me your email address and I'll see if I still have any pics.
Anthony
Old Mar 23, 2016, 10:42 PM
ttodro is offline
Find More Posts by ttodro
ttodro's Avatar
United States, IL, Lisle
Joined Mar 2004
Anthony
I am also interested in making this modification, my kit has all the parts, radio, and servos. Finally going to put it on my bench, and get it ready. Just found this post and interested in more photos, so I will send you an email..
Has anyone installed a set of doors? Definitely going to make this mod, and still trying to come up with simple and reliable door mechanism without resorting to adding another servo to operate the doors.
Any suggestions would be greatly appreciated.
ttodro is offline Find More Posts by ttodro
For Sale E-flite AT-6 Texan 25e kit - brand new in box PositivelyJoe Aircraft - Electric - Airplanes (FS/W) 2 Sep 07, 2011 03:05 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 11:08 AM
Found Old ALL American Aircraft - Electric - Airplanes (FS/W) 0 Apr 05, 2011 02:40 PM
