Old Apr 10, 2012, 03:49 PM
France, IdF, Paris
Joined May 2010
sunny day but very windy !
01-04-2012 (3 min 30 sec)
2M Ex version, 5/6th fpv flight
penpen is offline Find More Posts by penpen
Old Apr 10, 2012, 11:43 PM
Always looking towards the sky
Rick B's Avatar
Joined Nov 2005
Are yall using the stock 4 bolts on the wing? Have any pulled out from the stress of a hard pull back on the stick? Thinking about adding longer screws and washers. The plane with the stock motor and a 3 cell 2300 seems to be tail heavy. No camera equip yet. Is it normal to add nose weight? I`m thinking when i mount the VT in the center fuselage spot and the camera upfront they should cancel each other out on the CG.tks
Rick B is offline Find More Posts by Rick B
Old Apr 10, 2012, 11:46 PM
Joined Dec 2008
With the tx on the little flat part on the rear fuselage I can have a 3s 5000 mah in the front
cody069 is offline Find More Posts by cody069
Joined Dec 2008
Stock wing bols are fine..Have spun it in to the ground and the wing didn't rip off
Old Apr 14, 2012, 09:23 AM
Rick B's Avatar
Joined Nov 2005
Teejay. Is that the stock motor? What size battery?
Old Apr 14, 2012, 09:27 AM
Rick B's Avatar
Joined Nov 2005
Any pic`s of the camera mounts. I was thinking of cutting a large circle in the black canopy then mount my fatshark pan and tilt in it on the mount. It may look better with the sleek black cover.But i do worry i may catch wind drag? Has anyone done this?
Old Apr 14, 2012, 11:54 AM
United Kingdom, Swansea
Joined Mar 2011
Stock motor and esc but with a Turnigy Ubec and a 3000mah Turnigy Nanotech
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Apr 14, 2012, 12:46 PM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Today my one became ready for maiden. I hope rain will stop soon..
My total weight with FPV gear and a 5000mah 3S battery is 1750gr.
The max rpm is 12.260 and theoretical trust is 780gr.
So, I am worrying the stock motor will not be enough for this plane..
How is yours weigh?
Firatp is offline Find More Posts by Firatp
Old Apr 14, 2012, 12:56 PM
Joined Mar 2011
How is yours weigh?
At the moment the weight of mine is negligable as those flights above are without any FPV gear (no camera, no osd etc)
I am currently in the process of installing OSD and camera, I'll also likely use a 5000mah 3S and don't envisage any problems
WARNING !
Make sure that if you're loading it up that you change the ESC for something more reliable or at least fit a UBEC to take some of the strain
I have fitted a UBEC and moved the standard ESC into the motor pod where it will get some cooling air, I'm hoping that is enough to keep me safe
Old Apr 14, 2012, 01:24 PM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
WARNING !
Thanks to God, My ESC was burned out at first power up. I also changed servos. Still suspicious on motor because it has not well balanced.
Old Apr 14, 2012, 01:39 PM
Joined Apr 2012
wat
fpv raptor is offline Find More Posts by fpv raptor
Old Apr 14, 2012, 04:56 PM
Joined Dec 2008
Stock motor is fine..ESC sucks.
Mine's around 1750gr, flys ok..Just a bit of a run on launch and a good hard throw
Old Apr 17, 2012, 08:18 PM
The Netherlands, OV, Steenwijk
Joined Apr 2011
Hi Firatp,
The stock ESC is not able to supply sufficient power for all the servos. My stock motor was shaking like hell so I replaced it too.
I run this motor: http://grafik.ws-modellbau.de/POLY-T...36/c30-36.html
I use a 11.1V 3S battery.
A friend of mine runs a E-flite Power10 in his FPVRaptor also using 3S batteries.
The Power10 is on the heavy side, but the additional wheight can be compensated nicely by a bigger battery(3S 5000mAh).
Every Motor with 1100 up to 1250kV, approximately 100 gram mass and 35mm maximum outer diameter should do the job.
We run a 8x6APCe prop with these motors.
An AXI 2814/16 (830kV) should be fine too using 4S battery packs.
To show how to fit the motor see the pic.
Cheers.
Reg electronics, my esc was burned at first attempt. Servos are so noisy and weak. By the way I couldn't pull out wing servos.
Can you advice motor which you have.
VRquaeler is offline Find More Posts by VRquaeler
Old Apr 18, 2012, 10:49 PM
Plane crasher
seedo's Avatar
Joined Jun 2007
Originally Posted by VRquaeler View Post
Hi Firatp,
Cheers.
you will regret this motor mount
seedo is offline Find More Posts by seedo
Old Apr 19, 2012, 10:01 PM
Rick B's Avatar
Joined Nov 2005
Did my first flight today. Stock motor with replaced Turnigy 30 ESC. Using 3 cell 2300. I have the ESC mounted in the engine pod for cooling. No FPV stuff mounted yet. The plane flew great. The motor is not a power house but it serves it`s purpose as a FPV stable platform. It will do rolls and nice loops. But can fall out of the loop if not enough speed is kept up.
I have 3d plane`s for that. I just want a stable light camera mount plane, which this motor is perfect. Keep the weight down with light wing loading. I did add some nose weight for CG. The plane cruises level at mid throttle. But at WOT the nose rises. I`m not sure if this is a CG problem or because the motor is so far on the back of the plane it pushes the plane`s nose upward at WOT. Hmmmm?
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 Video Piloting (FPV/RPV) 4413 Today 09:19 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao Video Piloting (FPV/RPV) 139 Oct 10, 2012 12:57 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 Video Piloting (FPV/RPV) 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 05:29 PM
