Old Feb 03, 2013, 07:24 AM
motofox is offline
Find More Posts by motofox
United Kingdom, England, Nottingham
Joined Aug 2012
Originally Posted by Alpha1actual View Post
Love the flybys too, very smooth, i carnt do that here even on a calm day, the turbulance around 15 foot is mad. What happened to the skywalker, did the tree move ?
motofox is offline Find More Posts by motofox
Old Feb 03, 2013, 10:52 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Thanks guys. Skywalker was swallowed by the tree as my friend chose a new landing approach, coming in over the road. As he came in low over the treetops, a branch reached out and pulled him in (his story) Zero damage.
Alpha1actual is offline Find More Posts by Alpha1actual
Old Feb 04, 2013, 09:57 AM
urbansniper is offline
Find More Posts by urbansniper
United States, TX, Houston
Joined Nov 2012
For those who are building a FPV raptor and are going with the NTM 28-36 1800KV motor from the US warehouse...here is the buddy code for that engine ($14.58)...
http://www.hobbyking.com/buddy.asp?c...9-1258471E01FC
Originally Posted by kozack View Post
Not recommended, since high throttle has a downward vector.
So as you said, 45 degrees, 75% throttle, throw, elevator up, 100% throttle.
The strength of your arms is the key
thanks for chiming in! seems like it launches pretty much like the AXN Floater.
urbansniper is offline Find More Posts by urbansniper
Old Feb 04, 2013, 02:33 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Hi Guys, Just about to pull the trigger.
Anybody know if the Rap just in at the UK HK site is the new version?
Bought the 2m kit only; direct from Lanyu. Arrived with wings damaged!!! Yet to fix, build and fly.
Anyone got any suggestions on a simpler/more secure way of attaching wings on the smaller version?
Anybody attached a wheel. (just one up front)
Kinda tossing between the Rap and a Penguin. Although the Peng seems a bit over priced 110 Kit only from a supplier here in the UK!!!...(8.00 for a control horn?!!!)
I am yet to fly fpv but want a plane that I can, with practice; fly in my sleep and then with same plane progress with fpv rather than getting a whole new model and learning again...It seams the peng has lots of spares readily available.
Any advice needed and welcome.
Ands
ands is offline Find More Posts by ands
Old Feb 06, 2013, 01:43 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
HEY!~ anyone here use a Frsky reciever with the Raptor?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Feb 06, 2013, 10:09 PM
ilipin is offline
Find More Posts by ilipin
ilipin's Avatar
Россия, Пермский край, город Пермь
Joined Jul 2011
I'm. Have FrSky DFT Tx with D8R-XP and D8R-II plus Rx
I use a 1W booster, so max range since not discovered I'm flying up to 3 km.
2 tips about two way Frsky.
Do not place Rx close to GPS, you GPS will not find any satellites.
If you use a 900mhz-1300mhz video Tx, 1.4 Ghz filter must be on you video Tx, else Frsky range drops to 100-200-300 meters. Or use 5.8 Ghz without any problems.
ilipin is offline Find More Posts by ilipin
Old Feb 09, 2013, 05:55 AM
Joined Mar 2012
If you use a 900 mhz-1300mhz video Tf1.4 Ghz filter must be on you video Tx, else Frsky range drops to 100-200-300 meters. Or use 5.8 Ghz without any problems.
What I need to know is the order that you plugged in your servos into the Frsky receiver? Any info on the plug order will be appreciated!
Old Feb 09, 2013, 06:23 AM
Joined May 2012
Get High, Get Low (5 min 2 sec)
Old Feb 09, 2013, 07:01 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Outstanding..............loved it.
Dave
dav3uk is offline Find More Posts by dav3uk
Old Feb 09, 2013, 07:10 AM
krytikul is offline
Find More Posts by krytikul
S.R.V.
krytikul's Avatar
United States, FL, Melbourne Beach
Joined Nov 2012
Just ordered one from HK US, looking forward to testing it out!
krytikul is offline Find More Posts by krytikul
Old Feb 09, 2013, 09:37 AM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Alpha1 is that GoPro footage?
Dave
Old Feb 09, 2013, 10:56 AM
ilipin is offline
ilipin's Avatar
Joined Jul 2011
Plug order is standard for all receivers. I'm not use flaps, and ailerons connected to one channel.
1 ail
2 ele
3 thr
4 rud
all other is auxiliary channels
5 and 6 - for fyetech AP
7 - Sony Nex camera shift
8 - IR camera switch video/photo
Old Feb 09, 2013, 11:05 AM
Joined May 2012
Thanks Dave. Yes, Hero2 1080p/30fps.
Old Feb 09, 2013, 11:40 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Very nice alpha.
blueprint is offline Find More Posts by blueprint
Old Feb 09, 2013, 11:44 AM
Euwan is offline
Find More Posts by Euwan
Joined Jul 2011
Hi, Guys
So today was my first FPV flight using the Raptor and the fatshark gear, with ezosd. I could fly for about a minute then my goggles would get those wavy lines and the picture never comes back. I have to land wait a bit then it comes back, even if I fly really close the picture goes. Also sometimes the screen just goes black but I am still able to see the osd information. I tried with both a 100mw + 600mw tx cloverleaf and the pole thing and it still does the same thing. Please could anyone help me figure out what is wrong?
Euwan is offline Find More Posts by Euwan
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11045 Yesterday 02:59 AM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Feb 10, 2016 01:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 05:29 PM
