Old Jan 26, 2013, 11:15 AM
Alpha1actual's Avatar
Joined May 2012
Originally Posted by Pasi Maraste View Post
Engine Turnigy Aerodrive SK3 - 2836-1500 Brushless
Plush 60A Brushless Speed Controller
Servo Hitec HS-55
Rangelink system
Great paint scheme. Love to see people customizing the plane, it's so boring when it's naked/white
I caught hell from friends for painting mine with stealth colors because it cannot be seen against the sky well when flying LOS. It was built specifically for FPV, why would I need to ever see it?!
G25 in background still getting good use?
Alpha1actual is online now Find More Posts by Alpha1actual
Old Jan 26, 2013, 03:00 PM
United States, AZ, Tucson
Joined Mar 2012
Well, the rest of my FPV assembly station arrived in the mail today!. Soon my new Raptor will be ready to fly!. I used to do this stuff on my wifes dining room table (when she was not home). But now with this assembly station ready to go I bet these type of jobs will be a little easier! . I have all the factory servos replaced with digital ones. I wish to paint the bottom of my Raptor black so it can be seen easter in the sky. Does anyone know of a black spray paint that can be used on foam without damage?. I would use a air brush as to use as little paint as I can to save weight . I will be installing the FrSky 8 channel Receiver and the Guardian stabilization system this week. Then all that's left is to figure out how to do all the settings on my 9X radio to control it all.
VID00456 (0 min 36 sec)
goldsworthy is offline Find More Posts by goldsworthy
Old Jan 26, 2013, 04:07 PM
Joined May 2012
Krylon Fusion works well. I'd still use a plastic primer but it's not truly necessary w/ Fusion paint. Research the black paint before spraying. Certain black paints contain carbon. Carbon can block video signals.
Old Jan 26, 2013, 04:12 PM
Joined Mar 2012
I wish there were some frame by frame photos of the settings for this Raptor using the 9X radio. It would be nice to be able to view a step by step photo or video of all the settings.
Old Jan 26, 2013, 08:34 PM
Joined Nov 2012
There is nothing specific about the raptor when it comes to radio settings. If you didn't have the flight stabilizer, then you should just look for a generic 4 channel setup.
I see this TX is a bit more complicated to set up than most.. I found a manual for it..
Check the FILES tab for the ENGLISH manual in this link:
http://www.hobbyking.com/hobbyking/s...Firmware_.html
Is the 9x radio you have, compatible with the FrSky receiver? I think you need some type of module that plugs into the TX for that.
Anyway, would this link help http://9xforums.com/forum/viewtopic.php?f=37&t=1456
If that one doesn't maybe other searches in that 9x forum will help you.
InFocus is offline Find More Posts by InFocus
Old Jan 27, 2013, 03:29 AM
Sweden Malmoe
Joined Dec 2012
Thx m8
Yes the G27 getting good use here GranTurismo 5
Pasi Maraste is offline Find More Posts by Pasi Maraste
Old Jan 27, 2013, 04:29 AM
Joined Mar 2012
I guess you didn't notice the added monitor in the video. My 9X already has the FrSky module installed. How else could I use the receiver in the video? I really don't plan on long distance FPV I would be happy with LOS flying and recording. I believe the equipment I have now, should be more than enough for my intentions. I am using the Guardian stabilization system so it will be working the poor servos hard and fast. This is why I installed the digital servos I have 2 batteries that will be running together to power everything . I hope to have at least a 10- 20 minute flight when fully charged. I know the equipment I installed will use more power than a stock Raptor does but the plane should give me less trouble flying in windy conditions, and the Guardian should also help with smooth landings and take offs even with a strong cross wind. The added external BEC should help with power to all components and make it less likely to have a "brownout" during flight. If my ESC fails in flight the BEC also will provide me power to all servos so I can have a dead stick safe landing. The ESC provided power is only 3 amps where the added BEC will provide 5 amps with a 7+ amp short peak voltage. I am new to this and this is my first plane so I have much to learn from all you experts here!. I have been taking my time collecting these components and hope that I will be rewarded with a fun and trouble free flight or 2 before I crash it!!!
VID00452 (1 min 16 sec)
Old Jan 27, 2013, 09:50 AM
Joined Nov 2012
Sorry, I don't watch most of your videos. Just too many.. Its hard to determine which ones are asking a question and which one are general commentary..
From your repeated question on setup of the 9x, I had assumed you didn't have it working yet. Often 'general' request for help are difficult to answer because there is no starting point of reference. If you try to do the setup, and run into a specific issue, then it is easier for others to give guidance. Since no one else responded I thought I'd try to help, even though I don't own the 9x, and I don't own the Guardian.. But I do own a raptor, and also have experience setting up systems that have flight controllers/stabilizers. So we may not be able to give you a fish, but maybe we can teach you to fish.
Maybe a first step for you is to plug the RX into the BEC, ESC, rudder, elevator, and aileron servo y cable. (no need to install it in the plane permanently just plug it in). Remove 2 of the 3 motor wires for safety for now.
If you installed flaps, go ahead and hook that up too.
At this time I would have the servos installed/mounted, but not have the servos connected to the control surfaces just yet.
When you have this all plugged in, do all of the servos work? In the proper direction?
When the sticks are centered, no trim, and no sub trim (elevator, rudder, aileron), the servo horns should be as close to 90 degrees as possible, so that you'll get equal throw in both directions.. Flaps are exception because you generally only have them move in one direction, from normal postion to down.
If the horn is way off, remove it, and re-attach it as close to 90 as possible.
Once they are close to 90, then you use sub-trim in the radio to make them 90 degrees.
Check the servo moves in the correct direction. I may require reversing in the radio..
Then you can connect the servos up to the control surfaces..
The next part is to generally ensure the servos don't try to throw to far and bind up. This is where you use end point limits in the TX..
Now that you have all of this working, insert the guardian into the equation. I see that there is a manual and setup video for it here : http://eagletreesystems.com/guardian/
If you run into problems or things are not working the way you think they should, then let us know what your symptom is. Your experience with capturing videos will also be huge help.
Old Jan 27, 2013, 10:35 AM
Joined Mar 2012
HEY! what is the little black soft piece in the Raptor kit? where does it go?
Old Jan 27, 2013, 10:52 AM
Joined May 2012
Posting and You (4 min 8 sec)
Old Jan 27, 2013, 11:12 AM
SimpsonJ's Avatar
Virginia Beach
Joined Dec 2010
Hey Alpha1actual, I think we both use EZosd?
Can you help me out a bit if so?
What does the information on the right of the RSSI mean?
There is a picture of an antenna that displays 100 most of the time. Is that the signal reception or do I watch the RSSI value?
Then there is a number in the middle with the word "bad"?
I can't figure out what my RC signal reception really is... how does it look?
Raptor Plane Testing Winter 2013 (0 min 0 sec)
SimpsonJ is online now Find More Posts by SimpsonJ
Old Jan 27, 2013, 12:01 PM
Joined Mar 2012
What is the little black soft piece in the Raptor kit shown here and where does it go to on the plane? THANKS!
VID00459 (0 min 15 sec)
Old Jan 27, 2013, 12:05 PM
Joined Mar 2012
http://www.youtube.com/watch?v=EtRGkt5zyVc
Looks to me that you might be over the legal altitude of 400 feet!
Old Jan 27, 2013, 12:31 PM
Sweden Malmoe
Joined Dec 2012
What is the little black soft piece in the Raptor kit shown here and where does it go to on the plane? THANKS! http://www.youtube.com/watch?v=iUXRW...ature=youtu.be
I think it is anti vibration between the camera mount and aircraft
Old Jan 27, 2013, 12:36 PM
Joined Mar 2012
I think it is anti-vibration between the camera mount and aircraft
Thanks! I guess I wont be useing it then.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 Video Piloting (FPV/RPV) 4419 Yesterday 06:54 AM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao Video Piloting (FPV/RPV) 139 Oct 10, 2012 12:57 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 Video Piloting (FPV/RPV) 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 05:29 PM
