Old Dec 09, 2012, 05:42 PM
ecworks is online now
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Originally Posted by Alpha1actual View Post
Good luck EC, we're all hoping you get your plane back. You're one lucky bastard
Called Lost in OC this afternoon and had a nice conversation. He apparently works with the person who found the Twin Raptor in the water while surfing. It looks like he'll be able to speak to him tomorrow at work and hopefully we can make the connection.
Great little community we've got here don't you think!
ecworks is online now Find More Posts by ecworks
Old Dec 09, 2012, 05:50 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Dont forget the guys $200.00 reward!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 09, 2012, 07:05 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
How many times has this happened to you?
(This isn't me)
First IT DONT COUNT flight (3 min 17 sec)
Alpha1actual is offline Find More Posts by Alpha1actual
Old Dec 09, 2012, 07:17 PM
Joined Mar 2012
I got this glue for my Raptor http://www.hobbyking.com/hobbyking/s...idProduct=7525 do ya all think this stuff works?
Old Dec 09, 2012, 07:27 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
(This isn't me)
First of all it looks like alot of aileron throw. I do experience ia diving action when hand launching the model but being aware of it pull a strong elevator action to counter act the initial dive. Looks like the model still pretty much survived.
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Dec 09, 2012, 07:30 PM
Joined Mar 2012
What type of glue do you use on the fuselage
What type of glue have you had success with on the fuse??? I have tried to used 5 and 15 minute epoxie with a little PVC pipe welding cement mixed in. It works to a limited degree. Any recommendations please let me know what sticks really strong to the PVC fuse???
Old Dec 09, 2012, 07:47 PM
Joined Mar 2012
Old Dec 09, 2012, 08:00 PM
Joined May 2012
@Tom -I've yet to find anything that truly bonds to the pvc fuse. Not even Gorilla glue will bond to it. JB weld and also the weld-sticks (2 part putty in a tube) will harden like steel and stick fairly well, but under heavy strain I wouldn't trust it. 6 min. epoxy has failed me on several occasions. The fuselage is tough!
@Goldsworthy
Medium CA glue works wonders on foam. Great Planes makes the glue I use, it's available on Amazon. Anything else may melt the foam.
Old Dec 09, 2012, 08:22 PM
Joined Mar 2012
Originally Posted by Tom.in.Maryland View Post
I have built it and tried it without success but I haven't given up on it yet I am on Revision 3 of the glider trolley. I am having problems on the grass because of drag, caused by the grass and unevenness of the field
Perhaps a RC driven motor for the unit? Some kind of remote driven power unit to make it run fast and hard for a boost?
Old Dec 09, 2012, 08:23 PM
Joined May 2012
Or use a bungee
140" scratch built classic glider (0 min 15 sec)
Old Dec 10, 2012, 01:39 AM
gtrick90 is offline
Find More Posts by gtrick90
aka Nigel Uno
Italia, Lazio, Monterotondo
Joined Sep 2004
Very good job with the post Thanks and keep us up with how its working out.
Looks like your using the PLUSH 40A ESC ??? Is that correct? I am using that ESC on my Easystar 2.
Is that a 28mm can motor or a 35mm size?
Tom
Yes, it's correct PLUSH 40A
The motor is the 35-36a with an APC E 8x6 (35/36 max Amps at WOT)
Ciao
Luca
gtrick90 is offline Find More Posts by gtrick90
Old Dec 10, 2012, 01:58 AM
sgrouts is offline
Find More Posts by sgrouts
I love my HammerHead wing...
sgrouts's Avatar
Joined Jun 2012
Gtrick, thanks for the images.
I like how clean you kept everything.
I am almost convinced to change my servos with digital ones to support my Fy31Ap.
I agree that raptor, as any plane, are built to fly,
But I discovered the hard way that you must plan and implement any design having the crash on mind.
The above do not apply if you have trees that grow euros in your back yard!
I really liked your setup. Keep us posted with the wii project.
Sakis
P.S after installing wheels on my raptor, I am now using metal wire skids on wings and fuse for take off. It was either that or a trolly. Hand launches belong to the past for me...
sgrouts is offline Find More Posts by sgrouts
Old Dec 10, 2012, 02:07 AM
sgrouts is offline
sgrouts's Avatar
Joined Jun 2012
I forgot to mention that I also made a new elevator surface to support my raptor.
It is slightly bigger and stiffer that the original 2m version elevator I am using with my 1.6 raptor.
Sakis
Old Dec 10, 2012, 08:02 AM
Joined Mar 2012
Originally Posted by greedyg76 View Post
I took the stock aileron servos and moved them to the flap positions which is a less critical control surface. Then used HXT900's for the ailerons.
This sounds like a good Idea! at least untill a couple of better quality servos come your way!. I am new, but want the flaps as well. Can any one direct me to a video on how the flaps are cut out and conected to servos? THANKS!
Old Dec 10, 2012, 08:11 AM
Joined Mar 2012
(This isn't me)
http://www.youtube.com/watch?v=vdwz7LFjBbg
BOY! if this happens to you I dont stand a chance!. We have a lot of hills here with sloping sides. I wonder if this plane could be tossed and launched easy seeing these hills? a good example is the hill in the extreme right of this photo.
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Today 02:49 PM
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 04:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
