Old Nov 21, 2012, 06:49 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Just cut or twist the other end of the shielding then heat shrink it to ensure it doesn't make contact with any other wires. Yes, you should be able to tap into the ground and use it for other components. Test everything on the ground before you fly it to be sure all is wired up correctly. Be careful of creating ground loops. I'd create the harness first (vtx to osd) with the shielding, test, fly, test again (be thorough), and once you've verified all is well, then move onto wiring other components into it, and test again.
Alpha1actual is offline Find More Posts by Alpha1actual
Old Nov 21, 2012, 07:06 PM
Joined May 2012
Also, don't forget to give yourself enough cable length to wrap 5x (minimum) through a ferrite ring, as close to your vtx as possible.
Old Nov 21, 2012, 07:12 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Originally Posted by Alpha1actual View Post
Raptor just met her little sister (she's a bit jealous). Look what just arrived :-)
http://flic.kr/p/dv9UFp
http://flic.kr/p/dv9UrF
And the night missions begin...
Love the twin star! Dont forget this.
http://www.readymaderc.com/store/ind...products_id=44
blueprint is offline Find More Posts by blueprint
Old Nov 21, 2012, 08:29 PM
Joined May 2012
Sweeeeet! Looks perfect for my needs and the price isn't horrible. RMRC rocks.
Old Nov 21, 2012, 08:42 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Thanks so much Alpha. Just one last question regarding the power and ground wires. Should I have them on the same twisted pair or should they be on separate pairs? Does it make a difference? Will any method in particular increase quality and minimize rf noise?
thanks
williamjames is offline Find More Posts by williamjames
Old Nov 21, 2012, 08:54 PM
Joined May 2012
No problem. I've kept power and ground on the same pair with no problems.
Old Nov 21, 2012, 09:15 PM
BennyBagems is offline
Find More Posts by BennyBagems
Australia, TAS, Hobart
Joined Aug 2008
Can anyone tell me where I can get spares for this plane?
I am going to maiden mine tomorrow with FPV but would also like to have a spare lid for LOS flight.
BennyBagems is offline Find More Posts by BennyBagems
Old Nov 22, 2012, 03:41 AM
Joined May 2012
To the Sea
To the Sea (10 min 43 sec)
Old Nov 23, 2012, 10:38 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Just received my 2m Raptor and started by fitting the 35-36 1400 motor.
But i have two questions:
Did you horns came with back plates to bolt on or not.
Mine are just horns that are supposed to be screwed on the wing surfaces but there is no plastic piece on the other side for the screw to bolt on.
Hope i make sense.
And second: is there any picture showing the fpv equipment layout for a correct CG?
Regards
teopbako is offline Find More Posts by teopbako
Old Nov 23, 2012, 11:11 AM
ror1 is online now
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
Hope i make sense.
Regards
my 1.6m came with back plates. glue them in as well as screw..
ror1 is online now Find More Posts by ror1
Old Nov 23, 2012, 11:30 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
Some photos from my motor mod
Old Nov 23, 2012, 11:56 AM
Joined May 2012
Looking good teopbako. That black plastic piece always made me nervous. Motors generate heat, heat + plastic = melting. Just keep an eye on it. D35/36 is a good motor.
Peep the brown pants moment from a recent flight.
Miscalculated angle to ground station and broke LOS with a cliff between the plane and GS. Doesn't get much closer than this.
Coastal link footage (12 min 33 sec)
Old Nov 23, 2012, 06:00 PM
motofox is offline
Find More Posts by motofox
United Kingdom, England, Nottingham
Joined Aug 2012
umm so all you have done by the looks of the photo is make a longer plastic pillar ? how is it held in place ?
motofox is offline Find More Posts by motofox
Old Nov 24, 2012, 03:01 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
The pylar is aluminum and it snug fits in the original position.
To secure it i use the screws that held the plastic part as-well.
Old Nov 24, 2012, 10:08 AM
SimpsonJ is offline
Find More Posts by SimpsonJ
SimpsonJ's Avatar
Virginia Beach
Joined Dec 2010
http://www.youtube.com/watch?v=RUYQAIMxCMU
Interesting video. I'm still waiting on parts.
Your pretty brave to fly over water. I hope to be there some day.
Any chance you are still going to make the mission to the rig station?
SimpsonJ is offline Find More Posts by SimpsonJ
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 141 Dec 27, 2013 09:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 04:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
