Old Jul 17, 2012, 10:39 AM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Testimony to the strength of the Raptors wings:
RaptorGoodVibrations (1 min 23 sec)
ecworks is offline Find More Posts by ecworks
Old Jul 17, 2012, 10:40 AM
ecworks is offline
Joined Sep 2011
What a Raptor can do:
RaptorRacing (3 min 56 sec)
Old Jul 17, 2012, 11:05 AM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
Originally Posted by ands View Post
Hay Guys, greetings from the UK. Have my 2m heading this way; few days I hope. Bought it as a kit version and will be my first attempt at FPV. Have read most of the posts on here and you giys have been really helpful but I am still stumped at what motor to get.
I will be using a 50amp esc with a separate BEC and want a decent motor that will fit into the frame as per stock with out any mods and that I can purchase here in the UK. Hay I am impatient lol
Thanks in advance
Ands
anybody there that will help with some advice re: motor. Want to have lots of power but dont want it hanging out the fuse. Tried that with the SS and it flexed to much. Any advice most welcome...and needed
Ands
ands is offline Find More Posts by ands
Old Jul 17, 2012, 11:17 AM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Ands
You might want to look at my posts on the rimfire 10 motor I added, seems like most people that upgrade the motor are adding a brushless motor that has a outside diameter of 35mm and a kv range of 1000 to 1400. Also when you up the motor the ECS should be upgraded too.
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Jul 17, 2012, 11:19 AM
Joined Mar 2012
Foam wing glue
Raptor owners, what type of glue are you using on the foam wings? I poped the tip of the wing spar out on a twisted landing. I glued it back with RC-56 glue which worked but its a little gummy.
Old Jul 17, 2012, 12:17 PM
sgrouts is offline
Find More Posts by sgrouts
I love my HammerHead wing...
sgrouts's Avatar
Joined Jun 2012
Wheels on Raptor EX...
Lets see...
PS the wheel base stays on the raptor using 4 short wood screws (you tighten them from inside the fuselage). So in case of a hard landing ( or accident) the screws just pop out and stay on the wheel base.
Everything in theory of course. I will inform the thread with test results and video documents.
sgrouts is offline Find More Posts by sgrouts
Old Jul 17, 2012, 12:19 PM
sgrouts is offline
sgrouts's Avatar
Joined Jun 2012
I snapped my wings in half!
Hotglued them and used a wooden spoon on still hot glue to level the wing surface....
It still holds perfectly!
(I am almost certain that I own the ugliest, most beaten up Raptor EX!)
Old Jul 17, 2012, 12:43 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Lulz!! I spit my coffee! You guys are too funny. Beware the deadly hand launch! I ripped that damn decal off the plane after my first hand launch fail. I swear it was laughing at me
Alpha1actual is offline Find More Posts by Alpha1actual
Old Jul 17, 2012, 01:44 PM
Joined May 2012
Epoxy and/or white gorilla glue.
Old Jul 17, 2012, 02:36 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
One video from myself.
Captured by HK wing camera.
watch 2:00-2:50 when I was excited most
By the way my 3 years daughter calls my plane by ANGRY PLANE.
Orhanlı HD FPV (11 min 50 sec)
Firatp is offline Find More Posts by Firatp
Old Jul 17, 2012, 05:37 PM
sgrouts is offline
sgrouts's Avatar
Joined Jun 2012
Firatp,
Very nice flight. Thank you for the vid.
Wheelset ready and tested on ground. The Raptor is turning with rudder controls.
Will it take off?
Hopefully I'll test tomorrow.
Old Jul 17, 2012, 07:55 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
I use weldbond...it dries clear and is light.
ror1 is offline Find More Posts by ror1
Old Jul 17, 2012, 08:49 PM
Joined Mar 2012
Originally Posted by sgrouts View Post
Firatp,
Will it take off?
nice!
Old Jul 18, 2012, 06:59 PM
ror1 is offline
FPV'r
ror1's Avatar
Joined May 2011
Originally Posted by penpen View Post
If it could help, i have tested different power setup, (fpv gear and all, weight ~1.5Kg, 4000mah 3S)
- 2826/10 1400KV (ebay blue motor) + 8x4 + 30A => Fried (plastic's wire melt, shortcircuit). First setup, it was ok on several flight but....
- BC2826/10 1400KV (rctimer) + 8x4 + 40A => Ok, but i found it a little bit underpowered, hard with windy day and diffilcult to get a good climbing rate
- BC2836/6 1500KV (rctimer) + 8x5 + 40A => Ok, current setup
- 2215/20 1100KV (EMAX) + 8x6 + 40A => Ok too, didn't notice the difference with previous, maybe lower amps consumption.... have to check
Thanks, I installed 2836/6 with stock prop and it works great. I simply used the 3 of the 4mm screws that came with it to mount it to the stock mount...no mods required. I am going to try 8*6 prop and check current draw but it has much more pulling power than stock. Motor gets hot(70c) but ESC(40) is ok.
Current at full static throttle=27A=304W on 3S and stock prop 8*4
Old Jul 19, 2012, 05:07 PM
sgrouts is offline
sgrouts's Avatar
Joined Jun 2012
Firatp,
Will it take off?
still trying to find time for testing.
This week was a marathon!
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 141 Dec 27, 2013 09:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 04:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
