Old Jun 27, 2012, 01:56 AM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
FPV Raptor at Benson Farm (9 min 41 sec)
needs some trimming and the DOSD needs setting up but it's flyable.
mudlark is offline Find More Posts by mudlark
Old Jun 27, 2012, 12:22 PM
sgrouts is online now
Find More Posts by sgrouts
Vote F5J Gracia for FPV
sgrouts's Avatar
Joined Jun 2012
motor suggestion
Originally Posted by richie967 View Post
Hi forum,
Still struggling with motor choices for this plane, The motor i bought a few weeks ago for the plane is too big, it was the Turnigy Aerodrive SK3 3536 1200kv. I probably should have read the dimensions before ordering! Its going to cost too much to send back, so i'm going to keep it on the bench for another project.
I just want to get this bird in the air! - I also have a skywalker motor but i dont think thats going to fit either - 3536 1450kv.
I have just found another motor from an old wing i used to have - its a 2217-6t 1500kv motor. Will this work? it had an 8 x 4 prop on it before?
They are very different in size! pics below...
I dont really want to hack about with the motor pylon as i am not that good with modifications, so a straight fit would be best, beginning to think i should have ordered a RTF!
Which of the above 3 motors would you use? Or should i go back on hobbyking and order the 2836 1500kv motor as ive since discovered it may fit and be okay for the 2m version.
Advice if possible! Cheers
I agree that a 35 36 motor will fit. I fitted Turnigy Park 480 1320KV. (maybe I'll post images later)
But I suggest this: http://www.lowpricerc.com/product_in...kywalker-p-991
As you can see it is affordable,
it weights only 99gr,
it produces 1.128 gr of thrust using a 8x5 prop, (so you don't have to lift your tower to fit a bigger prop)
the prop is not stalling at 13.209 rpms,
and most importantly in WOT it consumes only 14Amps.
So it gives you almost half an hour of flight time in a 390gr 3.700mAh 4S battery.
(I attach the e-calc image below)
sgrouts is online now Find More Posts by sgrouts
Old Jun 28, 2012, 06:02 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
My FPV Raptor Mods
My FPV Raptor Mods so far...
Servo Repacement
Description:
Push Rod Replacement
Description:
Description:
Name: FPV_Raptor_Mods_RearMiddle_Fuse_Hatch and_Pushrod_Support.jpg
Description:
Motor Mount Reinforcement for 10 Rimfire 1250kv
Description:
Forming balsa Canopy
Description:
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Jun 28, 2012, 06:12 PM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Push rod replacements look great Tom!
Daughter went down for a nap and had some time to work on the new Raptor. Almost finished and weather's looking good for this weekend
Alpha1actual is offline Find More Posts by Alpha1actual
Old Jun 29, 2012, 07:51 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi ,
The linked video proves how much Raptor is strong. Last Sunday, The clouds were so low and I could have a chance to fly in a clouds and also drill it up. Suddenly I turned panic and amde a sharp dive. The air speed reached to 160km/h and wings proved that they were stong eneugh.
2 yrs ago I used tot have a Skywalker and it coulnd stand to much softer dive. You can see also in my other videos.
The Falcon video is at the link. The cloud surfing is between 02:00 and 05:00
Enjoy
Kısırkaya, Alçak Bulutlar / Low clouds (16 min 50 sec)
Firatp is offline Find More Posts by Firatp
Old Jun 29, 2012, 09:56 AM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
Originally Posted by Firatp View Post
Hi ,
Enjoy
Are you using stock or have you replaced all the electronics?
ror1 is offline Find More Posts by ror1
Old Jun 29, 2012, 10:29 AM
Firatp is offline
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
I have replaced all electronics and added flaps.
Cheers
Old Jun 29, 2012, 10:44 AM
Joined Mar 2012
FPV Raptor Balsa Canopy Make
FPV Raptor Balsa Canopy Make:
Description:
Description:
Description:
Description:
Description:
Old Jun 30, 2012, 10:08 AM
Joined May 2012
Someone had a good morning
Old Jun 30, 2012, 11:08 AM
Joined Mar 2012
Painting FPV Raptor
How did you paint the Raptor. The color looks wonderful Please advise what paint and what procedure. Thanks, Tom
Old Jun 30, 2012, 01:25 PM
ror1 is offline
FPV'r
ror1's Avatar
Joined May 2011
why 2 antennas?
Old Jun 30, 2012, 06:06 PM
ror1 is offline
FPV'r
ror1's Avatar
Joined May 2011
replaced cheap link with dubro mini kwik-link and threaded rod for 1/16
- remove pushrod wire from plane
- cut off cheap end and tin wire with solder
- have to use acid flux to make solder stick to wire..
- install tinned wire
- solder threaded rod to wire with 140watt soldering gun
Old Jun 30, 2012, 06:11 PM
Joined May 2012
why 2 antennas?
EzUHF diversity receiver. Similar to a video diversity setup on a groundstation (I use RangeVideo's diversity rx) , the receiver will monitor and automatically switch to the antenna that has the best signal. RSSI for both antennas are shown on-screen with Immersion's EzOsd.
Old Jun 30, 2012, 06:40 PM
Joined May 2012
Thank you! I was going for a US drone color scheme and I'm pretty happy with the final product. I maidened this plane this morning with the Power 10. As expected, the plane is difficult to see when flying LOS against blue skies. But who s flying LOS anyway?
I lightly sanded all pieces, foam and pvc to prep it for 2 coats of plastic primer, followed by 2 coats of Krylon "Mountain View". Sanding and primer help tremendously with adhesion. Keep in mind that painting will create extra weight, to the tune of 20g or more depending on model size how many coats you apply.
Old Jun 30, 2012, 09:14 PM
damoz is offline
Find More Posts by damoz
damoz's Avatar
Australia, VIC, San Remo
Joined May 2010
Hi,
Just browsing the posts here and thought I mIght add my motor choice after trying a few.
I ended up liking the following and not mods needed.
NTM 2826A -1200kv on 8x4 prop with Turnigy AE 45a esc.I like long distance flying so set up with 2x2200mah 3S. Doesn't climb anywhere near vertical, but with Batts, Osd, flight controller, Vx batt and Tx etc I get 50mins cruising at 4-5amps and 20km+. The trade off is climb performance and speed.
I found finding much info hard so just went trial and error. Hope that helps someone.
damoz is offline Find More Posts by damoz
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11269 Today 10:34 AM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Feb 10, 2016 01:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 05:29 PM
