Old May 11, 2012, 09:44 AM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Mine was the one that came with the kit..Just set the high / low Throttle setting.
Both failed, 1 after 2 flights the other lasted about 25 flights . Stock motor and prop
cody069 is offline Find More Posts by cody069
Old May 11, 2012, 06:22 PM
Rick B is offline
Find More Posts by Rick B
Always looking towards the sky
Rick B's Avatar
Joined Nov 2005
I saved the org. ESC to put in a foamy. Still using stock more though.
Rick B is offline Find More Posts by Rick B
Old May 12, 2012, 01:25 AM
seedo is offline
Find More Posts by seedo
Plane crasher
seedo's Avatar
Joined Jun 2007
Originally Posted by charlienofun View Post
Seedo, do you have any pictures of how you have the motor mounted? or what you had to modify to get it to fit the tower?
Charlie
i have no pix but if you have a dremel its easy just sand the hole and make space for the motor and after installing the motor reinforce the tower with fiberglass tape to prevent the tower from bending.
Regards
seedo is offline Find More Posts by seedo
Old May 12, 2012, 09:28 PM
Rick B is offline
Rick B's Avatar
Joined Nov 2005
Raptor with Fatshark Predator.100mW VT
Oh yeah! You can clap now. Full Gyro, pan and tilt built in the goggles.LOL
Old May 13, 2012, 08:54 AM
Alpha1actual is offline
Find More Posts by Alpha1actual
Alpha1actual's Avatar
Joined May 2012
Hey guys. Just finished with my build. When looking at the motor from the rear of the plane, should the motor be rotating counter-clockwise?
Alpha1actual is offline Find More Posts by Alpha1actual
Old May 13, 2012, 11:48 AM
Rick B is offline
Rick B's Avatar
Joined Nov 2005
I looked at the picture on the box to figure out which way the prop goes on. Then i swapped my ECS wires to get it turning in the right direction. I could send you a pic later tonight.go in . Wording facing the motor.You want it to pull like it was on the front the plane, if that makes sense.
Old May 13, 2012, 05:15 PM
mguilbau1 is offline
Find More Posts by mguilbau1
Joined Mar 2011
FPV Raptor Build Log
Hi Folks,
Can anyone point me to the build instructions for the Raptor. I suppose I can figure it out but I have learned if there is an easy way that I should probably try to take it. I am concerned about the tail assembly at this point.
Many thanks
Marc
mguilbau1 is offline Find More Posts by mguilbau1
Old May 13, 2012, 08:27 PM
schusterjo is offline
Find More Posts by schusterjo
United States, IN, Lebanon
Joined Oct 2011
Where are you guys getting the 2M version that has servo's an motor already?
schusterjo is offline Find More Posts by schusterjo
Old May 13, 2012, 08:28 PM
Joined Oct 2011
Also where can you order replacement parts?
Old May 14, 2012, 12:50 AM
bearpants is offline
Find More Posts by bearpants
United States, NJ
Joined Apr 2012
anyone try flying this thing with a go pro mounted on it?
bearpants is offline Find More Posts by bearpants
Old May 14, 2012, 03:28 AM
cody069 is offline
cody069's Avatar
Joined Dec 2008
Yes ..can handle a Go Pro
Old May 14, 2012, 06:16 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
İ thing the best thing is to buy a new one for replacement. I ordered second one to HK.
Firatp is offline Find More Posts by Firatp
Old May 14, 2012, 11:20 AM
United States, NJ
Joined Apr 2012
Any pictures of mounting locations?
Old May 14, 2012, 05:04 PM
cody069 is offline
cody069's Avatar
Joined Dec 2008
I mounted it on the flat part at the front .Will post a photot later
Old May 14, 2012, 05:22 PM
United States, NJ
Joined Apr 2012
Appreciate it
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Feb 10, 2016 02:49 PM
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 04:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
