Old Apr 23, 2012, 07:03 PM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
More and more people using these, that's great
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Apr 23, 2012, 07:13 PM
louiealadph is offline
Find More Posts by louiealadph
Joined Apr 2011
Originally Posted by louiealadph View Post
guys! How about if i will use the 3 bladed prop. 8x6 3 blade prop?? And a 4s bat? Will these add more power?? I check the web on h-king and i found tsome good motor to use...now im finding what motor to be used without modifying its mounting.. These is my choice that i found..can anyone give me idea. What is the best option to choose.
My setup will go around 2kg - 2.5 using fpv raptor 1.6m and can soon fit on 2m..
Hope someone give me.what is the best. That already tested and proven.
These my options..
On ntm series.
http://www.hobbyking.com/hobbyking/s...00kv_560w.html
http://www.hobbyking.com/hobbyking/s...00kv_875w.html
http://www.hobbyking.com/hobbyking/s...50kv_310w.html
and for turnigy.
http://www.hobbyking.com/hobbyking/s...dproduct=19038
these are my option.. I want to use 3 bladed props.at 8x6 size.. And i will use my esc, 55a turnigy trust. And i want some advice also.what is the best esc. If i use 4s battery. Hope someone help me..
need some help..up
louiealadph is offline Find More Posts by louiealadph
Old Apr 24, 2012, 09:55 PM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
need some help..up
Check out e-calc:
http://www.ecalc.ch/motorcalc_e.htm?ecalc
henkvdw is offline Find More Posts by henkvdw
Old Apr 28, 2012, 12:30 AM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Today, I have ordered this motor. The stock one vibrates much. It kills my auto pilot.
I hope I will be happy
Cheers
Firatp is offline Find More Posts by Firatp
Old May 07, 2012, 09:33 AM
Hallmark is offline
Find More Posts by Hallmark
Australia, SA, Munno Para
Joined Feb 2012
FPV Raptro Build
Hi All,
I have my plane built up, Spektrum H3020 digital MG servos, Eflite 420 heli motor and Dualsky 45A ESC.
The damned elevator control rod is on a 45* angle has anyone got any suggestions please? If I mount the servo at the rear where is best and please if anyone has photos direct me to where I can see them. This is a real problem and ANY advice will be appreciated.
Thanks in advance...
Hallmark is offline Find More Posts by Hallmark
Old May 07, 2012, 05:49 PM
Rick B is offline
Find More Posts by Rick B
Always looking towards the sky
Rick B's Avatar
Joined Nov 2005
I just bent mine to a better angle. The horns are crap. Be sure to put some fuel tubing to hold the clamp tight. Works ok.
Rick B is offline Find More Posts by Rick B
Old May 08, 2012, 12:20 AM
Hallmark is offline
Joined Feb 2012
Okay thanks. I already replaced all the horns with DuBro's and I'll see if any other ideas come in, but bending sounds fair. I have some tubing ready to go, but was also thinking of putting better rods with metal clevises - what do you think?
Did bending it affect the control much or at all?
thanks again...
Old May 08, 2012, 12:56 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
AS this is a slow flier and not a kilo-watt powered aerobatic/speed-racer, the rods are good enough. As long as you don't go over 30-45 deg bends, I doubt that the bends will affect it at all. I have mine bent to fit also.
chewy
chewytm is offline Find More Posts by chewytm
Old May 08, 2012, 07:10 AM
Rick B is offline
Rick B's Avatar
Joined Nov 2005
Yes. I still have stock stuff. I can pull tight loops if needed.
Old May 09, 2012, 03:35 AM
Hallmark is offline
Joined Feb 2012
chewy
Thanks mate I didn't look at it like that. Have also been told I can bend it near the end to reduce the load so maybe a little from column A and a bit from column B...
Old May 09, 2012, 06:59 AM
schusterjo is offline
Find More Posts by schusterjo
United States, IN, Lebanon
Joined Oct 2011
Ya, pictures of rear mounted servo's would be nice if anyone has them...
schusterjo is offline Find More Posts by schusterjo
Old May 09, 2012, 09:18 AM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
Originally Posted by seedo View Post
no that motor is perfect, but much modding required and dremeling
http://youtu.be/E8odThPWKpY
Seedo, do you have any pictures of how you have the motor mounted? or what you had to modify to get it to fit the tower?
Charlie
charlienofun is offline Find More Posts by charlienofun
Old May 11, 2012, 07:33 AM
WhiteNite1971 is offline
Find More Posts by WhiteNite1971
Joined Sep 2011
Hey Gang
Has anyone played with setting the ESC? I noticed it goes through three settings.
Regards
Jason
WhiteNite1971 is offline Find More Posts by WhiteNite1971
Old May 11, 2012, 08:06 AM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Originally Posted by WhiteNite1971 View Post
Hey Gang
Regards
Jason
If it's the one that comes with the Raptor put it in the bin..Have 2 Raptors and both ESC failed
cody069 is offline Find More Posts by cody069
Old May 11, 2012, 08:21 AM
Joined Sep 2011
Hi cody069
Thanks for the reply. I haven't had any trouble with the original at this stage. Just curious how to go about setting it? What brand is it?
Regards
Jason
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11003 Yesterday 02:47 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 142 Feb 10, 2016 01:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 03:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 05:29 PM
